OpenFOAM-1.6 install cookbook
Like Tree1Likes
Old   October 19, 2009, 03:42
MadsR's Avatar
Mads Reck
MadsR is on a distinguished road
It's odd, it should work on a non-altered Ubuntu. If you are updating stuff (libs) in the middle of a compile-error-recompile loop, you might get into trouble. Maybe you want to remove OpenFOAM-1.6.x completely and redo the git-part and then the ./Allwmake once more to be sure that linking is done correctly ? This might also be a complete waste of time :-/ but if you do not have anything else to try, it might be worth it.
/Mads
Online free airfoil-mesher for OpenFOAM here
MadsR is offline   Reply With Quote
Old   October 19, 2009, 04:19
toto
ronaldo is on a distinguished road
kate .bashrc &
ronaldo is offline   Reply With Quote
Old   October 19, 2009, 04:47
suitup is on a distinguished road
Hey guys, i tried mads script and all works fine. I thought everything worked, but if I look into the make.log I see an error-msg in the end. I tried it twice, each try with the same results.
OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt \
-lspecie -lOpenFOAM -liberty -ldl -lm -o /home/fx/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/mixtureAdiabaticFlameT
make[2]: Verlasse Verzeichnis '/home/fx/OpenFOAM/OpenFOAM-1.6.x/applications/utilities/thermophysical/mixtureAdiabaticFlameT'
make[1]: Verlasse Verzeichnis '/home/fx/OpenFOAM/OpenFOAM-1.6.x/applications/utilities/thermophysical'
make: Das Target »application« wurde wegen Fehlern nicht aktualisiert.
in english:
-lspecie-lOpenFOAM-liberty-ldl-lm-o / home/fx/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/mixtureAdiabaticFlameT
make [2]: Leaving directory `/ home/fx/OpenFOAM/OpenFOAM-1.6.x/applications/utilities/thermophysical/mixtureAdiabaticFlameT '
make [1]: Leaving directory `/ home/fx/OpenFOAM/OpenFOAM-1.6.x/applications/utilities/thermophysical '
make: The target "application" was not updated due to errors.
After installing openssh-server, i could check the installtion with foamInstallionTest
sudo apt-get install openssh-server
The result was:
Checking basic setup...
Shell:              bash
Host:               ubuntu
OS:                 Linux version 2.6.28-15-generic
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory                Valid      Crit
$WM_PROJECT_INST_DIR /home/fx/OpenFOAM                        yes       yes
$WM_PROJECT_USER_DIR /home/fx/OpenFOAM/fx-1.6.x               yes       no
$WM_THIRD_PARTY_DIR  /home/fx/OpenFOAM/ThirdParty-1.6.x       yes       yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory                Valid Path Crit
$WM_PROJECT_DIR      /home/fx/OpenFOAM/OpenFOAM-1.6.x         yes  yes  yes
$FOAM_APPBIN         ...6.x/applications/bin/linux64GccDPOpt  yes  yes  yes
$FOAM_SITE_APPBIN    ...nFOAM/site/1.6.x/bin/linux64GccDPOpt  no        no
$FOAM_USER_APPBIN    ...6.x/applications/bin/linux64GccDPOpt  yes  yes  no
$WM_DIR              /home/fx/OpenFOAM/OpenFOAM-1.6.x/wmake   yes  yes  yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN         ...M/OpenFOAM-1.6.x/lib/linux64GccDPOpt  yes  yes  yes
$FOAM_SITE_LIBBIN    ...nFOAM/site/1.6.x/lib/linux64GccDPOpt  no        no
$FOAM_USER_LIBBIN    ...penFOAM/fx-1.6.x/lib/linux64GccDPOpt  no        no
$MPI_ARCH_PATH       ...nmpi-1.3.3/platforms/linux64GccDPOpt  yes  yes  yes
Third party software
Software Version   Location
gcc      4.3.3     ...M/ThirdParty-1.6.x/gcc-4.3.3/platforms/linux64/bin/gcc
gzip     1.3.12    /bin/gzip
tar      1.20      /bin/tar
icoFoam  1.6.x     ...penFOAM-1.6.x/applications/bin/linux64GccDPOpt/icoFoam
Summary
Base configuration ok.
Critical systems ok.
done.
no errors.
so i startet the cavity case with blockMesh and icoFoam, all worked without any problems, but after starting paraView i got the same massage like sarajags and the programm crashed after choosing OpenFoam-Files.
Originally Posted by sarajags_89 View Post
hi it took 3hrs .. When I start paraview from the cavity case file I get the following msg " A reader for cavity.Openfoam could not be found" please select one of the following.
1.protein data bank files
plot 3d files
digital elevation map files
stereo lithography
gaussian cube files
raw(binary files)
pop ocean files
AVS UCD binary /ASCII files
SESAME
comma -separated grid files
MFIX unstructured grid files
fluent case files
openfoam files
cosmology files
Which one do i select
thanks in adv
cheers
sarang
I red at another thread that i could use the command foamToVTK to convert the openfoam-files and load them into paraView. It worked. But by converting to vtk i miss the properties in the Object Inspector and cavity may not be able to be updated. Or can i use vtk without concern.
Sorry for my english, perhaps someone can help me
edit: I forgot announcing that i tried, without any changes:
cd $FOAM_UTILITIES/postProcessing/graphics/PV3FoamReader
./Allwclean
    ./Allwmake
edit2: i checked the size of make.log, it is 1,8 MB (1936494 Bytes), so maybe we could compare the size with yours, may be there are missing a few compiling files.
edit3: by starting paraView i get these massages in the terminal:
fx@ubuntu:~/OpenFOAM/OpenFOAM-1.6.x/tutorials/incompressible/icoFoam$ paraFoam -case cavity
created temporary 'cavity.OpenFOAM'
unknown chip id 0x9442, can't guess.
Read float past end of buffer
after choosing openfoam-file and crashing paraView these massages appear:
Qt has caught an exception thrown from an event handler. Throwing
exceptions from an event handler is not supported in Qt. You must
reimplement QApplication::notify() and catch all exceptions there.
terminate called after throwing an instance of 'std::length_error'
  what():  basic_string::_S_create
Aborted
i hope my last edit: i use ubuntu 9.04 64bit and mads 64bit-script
suitup is offline   Reply With Quote
Old   October 19, 2009, 05:36
MadsR's Avatar
Mads Reck
Hi Suitup. heavy post you made there, but are you saying that after installing openssh, you got rid of the "make: The target "application" was not updated due to errors." -error??
/Mads
Old   October 19, 2009, 07:30
hi mad sry yes big post of me
i expressed me bad, i was not able to start foamInstallcheck, so i looked into some forumthreads and red that its able to start after installing openssh-server.
so openssh just solved the problem starting foarminstallcheck not more
so i ve just the issue that paraview has a bug.
I just postet the make.log, hoping that u can compare it to your log if you have the same last commands and to solve the issue, maybe there is a compiling probleme i dont know, i jsut started your script. But foaminstallcheck seems to say that everything is ok. so i wrote as summery that there appear no errors
Old   October 19, 2009, 10:12
MadsR's Avatar
Mads Reck
This just in :-) I've heard that running
apt-get install cmake
may help the "make: The target "application" was not updated due to errors." go away on 64-bit systems. This makes no sense to me as cmake is already distributed with OpenFOAM. My source says that it helped him, but that OpenFOAM remains using the cmake-version delivered together with OpenFOAM-thirdparty, so it should pose no harm to do this.
/Mads
Old   October 19, 2009, 11:56
HA!
It worked, Mads! After installing cmake, startet allwmake in the applicationsfolder, it compiled the rest without problems, now i can read the openfoam-cases.
1000 thanks, I still dont believe it
Old   October 19, 2009, 12:15
Ok, don't halloo till you're out of the wood!
ParaView can now load the files without any crashes, but is not able to display the case and cannot read the timu-files, it stucks at time 0s.
Like written before with foamToVTK and loading the vtk-filecase into ParaView, ParaView is able to load the case and the timing-files and can display everything. I ve no clue.
OpenFoam-File
VTK-File
Should I switch to Ubuntu 32bit and OpenFoam 32bit? Wont there be any issues?
Old   October 19, 2009, 13:46
akidess's Avatar
Anton Kidess
/Mads
A possible explanation is that at that point of the setup the $PATH variable is not yet set to the OpenFOAM thirdparty stuff (or at least not to cmake), so it is not found by the system. If encountering that error, either installing cmake, or manually changing $PATH to include the cmake that comes with OpenFOAM.
Old   October 19, 2009, 17:41
Default OpenFOAM-1.6 on Mac OS X 10.6.1
  #70
Elvis Dowson
elvisjohndowson is on a distinguished road
I just downloaded OpenFOAM-1.6 and ThirdParty-1.6 sources, and applied the v2 patches. I am trying to compile OpenFOAM on Mac OS X 1.6.1, using the default gcc compiler. What I did was modify the OpenFOAM patch and change all the entries for gcc-mp-4.3 to gcc, g++-mp-4.3 to g++ and cpp-mp-4.3 to cpp, since those compiler versions are not part of the standard distribution for 10.6.1.
When I try to run ./Allwmake, I get the following errors:
Making dependency list for source file hoard-371/src/libhoard.cpp
SOURCE=hoard-371/src/libhoard.cpp ; g++ -m64 -DdarwinIntel64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -DNDEBUG -D_REENTRANT=1 -IlnInclude -I. -I/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64DPOpt/libhoard.o
In file included from /usr/include/c++/4.2.1/bits/char_traits.h:45,
from /usr/include/c++/4.2.1/string:47,
from /Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/string.h:52,
from lnInclude/ansiwrapper.h:7,
from hoard-371/src/libhoard.cpp:92:
/usr/include/c++/4.2.1/cstring:80: error: ‘::memcpy’ has not been declared
/usr/include/c++/4.2.1/cstring:81: error: ‘::memmove’ has not been declared
/usr/include/c++/4.2.1/cstring:82: error: ‘::strcpy’ has not been declared
/usr/include/c++/4.2.1/cstring:83: error: ‘::strncpy’ has not been declared
Best regards,
Elvis
elvisjohndowson is offline   Reply With Quote
Old   October 19, 2009, 17:46
akidess's Avatar
Anton Kidess
Elvis, I don't see how your post is related to the cookbook. You might be better off reading threads / the wiki for hints on a MacOS installation or creating a new thread.
Old   October 20, 2009, 03:40
MadsR's Avatar
Mads Reck
@Akidess:
Quite possible indeed, nice. So maybe I should put an
echo "export PATH=$PATH:~/OpenFOAM/ThirdParty-1.6.x/cmake-2.6.4/platforms/linux/bin/ " >> ~/.bashrc
into the script?
/Mads
Old   October 20, 2009, 03:42
Default need help
  #73
dandiwijaya
dandiwijaya is on a distinguished road
Hi all
I was just installing openFoam and try installing using the your script .The installation successful, but when I try blockmesh at cases cavity at tutorials there is perform the following message appears:
--> FOAM FATAL ERROR:
Failed writing polyMesh.
From function blockMesh
in file blockMeshApp.C at line 346.
one more thing, when I try to check the installation after trying the case had the following message appears:
gcc 4.3.3
WARNING: Conflicting installations:
OpenFOAM settings : /home/dandiwijaya/OpenFOAM/ThirdParty-1.6.x/gcc-4.3.3/platforms/linux/bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
tar 1.20 /bin/tar
Aborted
icoFoam 1.6.x .../OpenFOAM-1.6.x/applications/bin/linuxGccDPOpt/icoFoam
Summary
The foam installation contains 1 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
done.
please help me guys, I'm still newbie in using openFoam
thanks
dandiwijaya is offline   Reply With Quote
Old   October 20, 2009, 15:15
Ok to update you.
I tried installing OF 64bit with openSuse and i works.
Best regards.
Now I just have to get salome working.
Old   October 20, 2009, 15:50
akidess's Avatar
Anton Kidess
@Akidess:
into the script?
/Mads
First off, you can call me Anton.
I don't think adding the path permanently to bashrc is the best solution. I think it would be better to either add cmake to apt-get (cmake probably doesn't change so much a different version will break it), or just export the path to the OpenFOAM cmake temporarily for the script, as it should be there once the OpenFOAM .bashrc is sourced: "export PATH=$PATH:~/OpenFOAM/ThirdParty-1.6.x/cmake-2.6.4/platforms/linux/bin/ "
Also, did you remember to include "set -e" into the script?
Old   October 20, 2009, 15:51
MadsR's Avatar
Mads Reck
Okay...64 bit Ubuntu should also work with the script, according to above posts. I think that Ubuntu is way easier to use (having used Linux since mid '90) but that's probably a matter of taste more than anything else.
Main thing: you got OF running :-) happy foaming!
/Mads
Old   October 21, 2009, 09:54
MadsR's Avatar
Mads Reck
Hi Anton!
Actually I already did add cmake to the apt-get as an easy solution, so I'll just stick to that, as you suggest. Yes, set -e has been included :-)
Cheers!
Mads
Old   October 21, 2009, 23:17
Jinbiao Xiong
JinBiao is on a distinguished road
Send a message via MSN to JinBiao
Hi Mads and Akidess. Thanks a lot for the help. Yes, I did update the libs during the compile-error-recompile process. It can be reason. And the error I got when I compile the applications has been settled by apt-get install cmake.
Jin
/Mads
JinBiao is offline   Reply With Quote
Old   October 25, 2009, 21:06
Default wiki vs. cookbook
  #79
Kurt Pudniks
skinduptruk is on a distinguished road
thanks for the cookbook
i have a few questions mostly related to linux knowledge (lack thereof)
the wiki has a different git address, this one worked for me, the cookbook one didn't (something about socket error). note the path with 'r'
git clone http://repo.or.cz/r/OpenFOAM-1.6.x.git/
i then needed to do a git merge origin/master command that the cookbook didn't have. this gave me the dirs rather than the .git alone. is this to do with using a different git address as above? is what i've done going to work?
also the wiki has a compiler change from OpenFOAM to System - is this still needed? i did this just in case.
finally the wiki says to compile the 3rd party stuff, but i note the OF makefile does this already
anyway, i'm now at the end of the cookbook and have run the wmake and it seems to be ok so far using tail make.log, i know it takes hours.
thanks again, i wouldn't have built from source without this cookbook.
skinduptruk is offline   Reply With Quote
Old   October 26, 2009, 04:13
MadsR's Avatar
Mads Reck
Hi Kurt.
I am glad the script worked out. I do not understand your git issue and why the r-directory should be added to the url :-) ?
With regards to the wiki I can't help, I guess everything should work when the script runs to the end without errors, no?
/Mads
install OpenFoam 1.6 by building source: how? niudie OpenFOAM Installation 13 April 26, 2011 01:48
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 15:43
install openfoam 1.6 on opensuse 11.0 andresbh OpenFOAM Installation 8 September 30, 2009 01:48
Install openFOAM 1.6 on debian 32bit - blockMesh: command not found fossy OpenFOAM Installation 1 August 28, 2009 05:06
Install of OpenFOAM 1.6 Error 1 Error 2 & run tutorial potac OpenFOAM Installation 3 August 27, 2009 10:04
