OpenFOAM-1.6 install cookbook
Like Tree1Likes
Old   March 9, 2010, 11:40
83_Ale_83's Avatar
Alessandro
83_Ale_83 is on a distinguished road
This way right?
echo "FIX up for Ubuntu 9.10"
cd ~/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64
mv libstdc++.so.6 libstdc++.so.6.orig
ln -s `locate libstdc++.so.6.0 | grep "^/usr/lib" | head -n 1
mv libgcc_s.so.1 libgcc_s.so.1.orig
locate libgcc_s.so. | grep "^/lib" | head -n 1
cd ~/OpenFOAM
echo "Fix up done"
83_Ale_83 is offline   Reply With Quote
Old   March 9, 2010, 11:47
Retired Super Moderator
Bruno Santos
Sorry, no, I should have also posted the fix too
This is how it should be:
ln -s `locate libstdc++.so.6.0 | grep "^/usr/lib" | head -n 1` libstdc++.so.6
ln -s `locate libgcc_s.so. | grep "^/lib" | head -n 1` libgcc_s.so.1
cd ~/OpenFOAM
echo "Fix up done"
I know, it looks a bit weird, but now it should work and be a bit more bullet proof
Disclaimer: this change might not work in a reinstall over an existing OpenFOAM installation It should nonetheless work well in a clean install!
Old   March 10, 2010, 04:06
Sandy Lee
sandy is on a distinguished road
cd ~/OpenFOAM
echo "Fix up done"
Hi, wyldckat, if I want to install 32bit OpenFoam-1.6.x in Ubunto 9.10, I guess I just need to change your above lines into
cd ~/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux/lib
cd ~/OpenFOAM
Is it right or wrong? Thanks.
In addition, if I does not fix up Ubunto 9.10, and install those steps the same as in Ubunto 9.04, what will happen?
Why we need to
What is it meanings, you think? Moreover, if I do above steps, it seems that I can not plot the residue. Who can give some light?
sandy is offline   Reply With Quote
Old   March 10, 2010, 07:06
Bruno Santos
Greetings sandy,
cd ~/OpenFOAM
Yep, that should do the trick for the 32bit version.
If you had Ubuntu 9.04 and then upgraded to 9.10, without erasing the 9.04 version, then the script for 9.04 might work in your upgraded 9.10 installation.
Why we need to
These steps do a backup of 2 unpacked library files (libstdc++.so.6 and libgcc_s.so.1) from the ThirdParty tgz package and replace those libraries with links to Ubuntu's 9.10 up-to-date libraries. Ubuntu 9.04 doesn't need this replacement step, because it comes with gcc-4.3.3, the same version as OpenFOAM's ThirdParty packaged gcc; while Ubuntu 9.10 comes with gcc-4.4.1, if I'm not mistaken.
By what I vaguely remember from this thread, this "update" was necessary, due to some incompatibilities with the system's libraries, when compiling or running OpenFOAM applications or Paraview... you'll have to look back to previous posts for more specific information
Well, that depends on the script you're using for plotting residuals! Personally, I have yet to use any one of those scripts, since I've only needed to look at the raw output of the solvers
Best regards,
Bruno
Old   March 10, 2010, 08:22
Sandy Lee
Swe**, thanks Bruno.
Yep, that should do the trick for the 32bit version .
I just found there are no two "libstdc++.so.6.0" or "libgcc_s.so." in the 32bit version, so we actually need not worry about them.
You knew everything, Bruno. However if the raw output of solvers also looks wrong, it will be very difficult to get the correctly final results, right? So, firstly we just need to watch.
Old   March 10, 2010, 08:33
Bruno Santos
Apparently, no I didn't know everything:
Hold on, I found these files in my Kubuntu 9.04 32bit! It was updated since 7.10, I think... So there is something strange with one of our (K)Ubuntu installations...
True enough... garbage in, garbage out! But can you specify which solver and tutorial case is outputting bad values, just to verify if they're bad or not? There might be more to it than bad libraries!
Old   March 10, 2010, 08:41
83_Ale_83's Avatar
Alessandro
Thank you Bruno, you have solved my problem
Old   March 10, 2010, 08:48
Sandy Lee
I knew you deeply involve in those experiments. How many bad libraries did you dig? Why are they "more to it than bad libraries!"?? It looks like those linux error messages to me .... chaos ....
Old   March 10, 2010, 08:58
Bruno Santos
You're welcome Alessandro
Mads, you've got some additional tweaking there to do
Yes, it could be library linking issues... the same for which that tweak in the Mads cookbook script was made for, i.e., force libraries to link to something that works.
My question was more about the bad results you are getting with the solvers, not the libraries themselves!
Old   March 15, 2010, 06:04
MadsR's Avatar
Mads Reck
MadsR is on a distinguished road
Hi All.
I am sorry, I haven't followed this thread for a while (I didn't get notifications. Weird.). Very good work Bruno, I have added your new fix up section. We need some testers now :-)
/Mads
Online free airfoil-mesher for OpenFOAM here
MadsR is offline   Reply With Quote
Old   March 15, 2010, 06:34
Sandy Lee
Hi Mads, you need not to change the line
ln -s `locate libstdc++.so.6.0` libstdc++.so.6
ln -s `locate libgcc_s.so.` libgcc_s.so.1
into
in Ubuntu 9.10 32bit, because there is only one "libstdc++.so.6.0" or "libgcc_s.so." in its library.
Sandy
Old   March 15, 2010, 07:29
Bruno Santos
Originally Posted by MadsR View Post
Hi All.
/Mads
Actually, the forum only alerts you once about a thread until the next time you login again. And you're welcome I've been wanting to help out a bit more, but haven't got around to it
Sandy
Sandy, it depends on how people use Ubuntu. If you install MATLAB in your 32bit Ubuntu installation, you'll get the same issues 83_Ale_83 had!
Best regards,
Bruno
Old   March 15, 2010, 07:39
MadsR's Avatar
Mads Reck
@Sandy, Bruno: Okay, so need not or shouldn't change the locate :-)? Is it okay that I leave it be (as it is now)? I haven't time to check it right now, but hopefully someone else would.
/Mads
Old   March 15, 2010, 18:07
jishnusoni is on a distinguished road
I am unable to get the script, can you please post it on here or give me a another link. I desperately need to install Openfoam. Thanks in advance.
Regards
jish
jishnusoni is offline   Reply With Quote
Old   March 16, 2010, 02:19
MadsR's Avatar
Mads Reck
It is right here. My webserver is acting a bit weird these days, I am working on it :-)
/Mads
Old   March 16, 2010, 04:10
Default Open foam insatallation
  #296
Javed
Javed is on a distinguished road
I m not able to install dt4-designer in ubuntu which is need for OF installation.
I m new in Linux.
Plz help me.
Javed is offline   Reply With Quote
Old   March 16, 2010, 19:19
Bruno Santos
Greetings Javed,
Are you following this thread's cookbook script? Because I'm not quite understanding what do you mean by "dt4-designer". Do you mean "qt4-designer"? Is it just the qt4 designer application or is it the whole Qt4 package you're managing to install?
Best regards,
Bruno
Old   March 17, 2010, 00:21
Javed
Thanks for the reply.
It is qt4-designer. typo mistake.
Old   March 17, 2010, 03:19
Javed
Hi, I am installing OF-1.6 on Ubuntu 8.1.
I have extracted files successfully into the Home/<username>/OpenFoam/
But not able to source bashrc file.
Also from the comments of previous forum had confused me, which file to edit bashrc i n home location or from OpenFoam/OpenFOAM-1.6/etc location.
I m getting following msg after using source bashrc command..
bash: /home/iyer/OpenFOAM/OpenFOAM-1.6/bin/foamCleanPath: No such file or directory
bash: /home/iyer/OpenFOAM/OpenFOAM-1.6/etc/settings.sh: No such file or directory
bash: /home/iyer/OpenFOAM/OpenFOAM-1.6/etc/aliases.sh: No such file or directory
bash: /home/iyer/OpenFOAM/OpenFOAM-1.6/etc/apps/paraview3/bashrc: No such file or directory
bash: /home/iyer/OpenFOAM/OpenFOAM-1.6/etc/apps/ensight/bashrc: No such file or directory
plz help me
Old   March 17, 2010, 05:18
Hi Javed,
I would suggest that, delete all the OpenFoam files from your Home menu and just follow the Openfoam cookbook script. I had a same problem. Enter each command in the command line one by one and you will able to install Openfoam without any difficulty.
regards
jish
install OpenFoam 1.6 by building source: how? niudie OpenFOAM Installation 13 April 26, 2011 01:48
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 15:43
install openfoam 1.6 on opensuse 11.0 andresbh OpenFOAM Installation 8 September 30, 2009 01:48
Install openFOAM 1.6 on debian 32bit - blockMesh: command not found fossy OpenFOAM Installation 1 August 28, 2009 05:06
Install of OpenFOAM 1.6 Error 1 Error 2 & run tutorial potac OpenFOAM Installation 3 August 27, 2009 10:04
