paraview doesn't run after upgrading to jaunty
Old   April 26, 2009, 10:24
Default paraview doesn't run after upgrading to jaunty
Emanuele Leoni
lions85 is on a distinguished road
I upgraded my ubuntu from 8.10 to 9.04. Before the upgrade my open foam was working very well, and paraview/parafoam too. My paraview was installed by a repository and so it was already compiled to run parafoam. Now, after the upgrade my paraview does not start and i can't find the way to solve it.
The errore message is:
paraview: symbol lookup error: /usr/lib/libmpi_cxx.so.0: undefined symbol: ompi_registered_datareps
I understand that probably the problem is with the package openmpi or something similar, but i really don't know how to fix it.
Maybe i need to come back to ubuntu 8.10 formatting my computer, but i'll do it only as the last way.
COuld anyone help me?
Thank you very much
EManuele Leoni
lions85 is offline   Reply With Quote
Old   April 27, 2009, 10:33
Damir Cavar
stomakos is on a distinguished road
I have exactly the same problem...
stomakos is offline   Reply With Quote
Old   April 27, 2009, 11:34
Damir Cavar
I found solution...
You have to download all packages that synaptick manager suggests as recommendation and as suggestion as well...
You will find this option if you write 'paraview' in synaptick manager and do right click on paraview...
Good luck!
Old   April 27, 2009, 18:39
Emanuele Leoni
Yes, now I manage to open paraview!!! The problem is that now my paraview doesn't work with the command parafoam, asking to select the way to open the file. This the same problem that I had when I didn't manage to compile paraview.
So I have to ask you if you find a solution.
Actually i took paraview from this repository:
deb http://ppa.launchpad.net/cae-team/ppa/ubuntu jaunty main
because the old one doesn't work with the installation of paraview for a problem of dependencies.
Thank you
Emanuele
Old   April 28, 2009, 03:25
Damir Cavar
When I install OpenFOAM, again same problem happend... But sovled
You can download Paraview from www.paraview.com and no installation is needed. Just run 'paraview' file from bin directory. When you finish your calculation in OpenFOAM just run command FoamToVTK and all your files will be read in paraview as VTK. (or VK)...
Damir
Old   April 28, 2009, 05:11
Emanuele Leoni
Yes, but this is not really a solution. Indeed you can change the files in vtk to open them but you can not open the entire sequence of files as in Parafoam.
Anyway I came back to ubuntu 8.10 that works fine. Maybe if a solution will be find i'll upgrade again.
Thank you
Emanuele
Old   May 22, 2009, 03:41
Su Xiaohui
sxhdhi is on a distinguished road
Send a message via Skype™ to sxhdhi
May I know the version of paraview in ubuntu 9.04 after you upgrade from 8.10 to 9.04
thanks.
Xiaohui
sxhdhi is offline   Reply With Quote
Old   May 22, 2009, 03:47
Damir Cavar
I made mistake, link is www.paraview.org and version is 3.4.0
Old   June 24, 2009, 18:49
Steve Hansel
hansel is on a distinguished road
Thank you very much
EManuele Leoni
I'm playing with the -dev version so it might not be exactly like your copy, but I found an openmpi directory in the ThirdParty directory. I built it and put the new libs in the Openfoam-1.5/libs/linux64GccDPOpt directory.
If you don't have it you could download it from www.openmpi.org. My copy was 1.2.6.
Paraview seems to look there first and I don't get the library error anymore.
Things still aren't perfect though, now it's confused about the reader.
hansel is offline   Reply With Quote
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
Paraview run problem ztdep OpenFOAM 1 April 21, 2009 03:52
Paraview installation troubles jjhall OpenFOAM Installation 3 April 17, 2008 13:59
[OpenFOAM] Problems with ParaView alejo ParaView 6 July 18, 2006 14:22
[OpenFOAM] Could anyone please help me in running the paraview in my Ubuntu system chanduksekhar ParaView 2 February 6, 2006 10:13
