Compile calcMassFlowC
Old   May 22, 2006, 09:37
Default Compile calcMassFlowC
aurore
Has anybody compiled calcMassFlow.C with OpenFoam 1.3 or does a new version of this file which is compatible with OpenFoam 1.3 exist?
I need help. Thank you
Old   May 22, 2006, 10:27
Default Where is the file located ?
Rolf Hansen
rogn is on a distinguished road
Rolf
rogn is offline   Reply With Quote
Old   May 22, 2006, 20:29
Default @aurore: the file still works
Assistant Moderator
Bernhard Gschaider
@aurore: the file still works for 1.3 you only have to change the fie Make/options (see http://openfoamwiki.net/index.php/HowTo_port_from _older_versions_to_13)
(to be honest, I just wrote this, hope it helps)
@rolf: my guess is that aurore is refering to http://openfoamwiki.net/index.php/Contrib_calcMas sFlow
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   May 23, 2006, 03:57
Default Hello Bernhard I cannot com
Rolf Hansen
Hello Bernhard
I cannot compile calcMassFlow, as I don't have the neccesary libraries. I can see a link to FaceSetUtilities in Make/options:
-I$(WM_PROJECT_USER_DIR)/Libraries/cellFaceSetUtilities/lnInclude
This is obviously not a standard OpenFOAM library.
Thanks
Rolf
Old   May 23, 2006, 06:23
Default Hello Bernhard, I have alwa
aurore
Hello Bernhard,
I have always an error when I compile calcMassFlow.c
This is the message :
SOURCE=calcMassFlow.C ; g++ -m32 -Dlinux -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast
-O3 -DNoRepository -ftemplate-depth-30
-I/home/aurore/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude
-I/home/aurore/OpenFOAM/OpenFOAM-1.3/src/cfdTools/general/lnInclude
-I/home/aurore/OpenFOAM/OpenFOAM-1.3/src/meshTools/lnInclude
-I/home/aurore/OpenFOAM/aurore-1.3/Libraries/cellFaceSetUtilities/lnInclude
-I/home/aurore/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -c $SOURCE -o Make/linuxGcc4DPOpt/calcMassFlow.o
calcMassFlow.C:36:30: error: FaceSetUtilities.H: No such file or directory
calcMassFlow.C:37: error: ´FaceSetUtilities´ is not a namespace-name
calcMassFlow.C:37: error: expected namespace-name before ´;´ token
calcMassFlow.C: In function ´int main(int, char**)´:
calcMassFlow.C:105: error: ´flipSet´ was not declared in this scope
calcMassFlow.C:105: error: template argument 1 is invalid
calcMassFlow.C:105: error: invalid type in declaration before ´=´ token
calcMassFlow.C:105: error: ´checkFaceSetSides´ was not declared in this scope
calcMassFlow.C:111: error: ´flips´cannot be used as a function
make: *** [Make/linuxGcc4DPOpt/calcMassFlow.o] Error 1
Thank you for your help
Aurore
Old   May 23, 2006, 07:17
Default Sorry Aurore, Sorry Rolf! Y
Assistant Moderator
Bernhard Gschaider
You are absolutely right and it's my fault. Let me explain the chronology of things
1. I posted the original calcMassFlow (then everything worked)
2. I separated some things concerning faceSets into a library
3. I forgot about the library and posted the updated calcMassFlow (I even checked by downloading and recompiling, but of course I've got the library installed so .....)
I will update that (should be available today or tomorrow)
Old   May 23, 2006, 10:23
Default OK. The library can be downloa
Assistant Moderator
Bernhard Gschaider
OK. The library can be downloaded from the Wiki-Page of calcMassFlow.
(The library currently only consists of only one function so if you want to you can copy the function to the main source file instead of installing the library)
Old   July 11, 2006, 03:30
Default Hi, I still have the problem.
Dihao Tang
tangd is on a distinguished road
Hi, I still have the problem. First of all, if I downloaded the files, where should I store these files? I put both files in /workdir/flux1/e7guest/OpenFOAM/OpenFOAM-1.3/src. Because it complained that FaceSetUtilities.H cannot be found, I copied FaceSetUtilities.H from library to the source file calcMassFlow, then compilation was ok. I moved calcMassFlowDict to the system directory of my solver case, say sonicTurbFoam/testCase/system, specified the patches in this dictionary. Last I ran the case, but no information was output. I am confused about this. Did I do something wrong? Thank you!
tangd is offline   Reply With Quote
Old   July 11, 2006, 05:02
Default Sorry, forget about the questi
Dihao Tang
Sorry, forget about the question
Old   July 3, 2008, 14:16
Default I'm having trouble compiling y
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
I'm having trouble compiling your code, too.
I have download the tool and the library and put them in seperated directories in /postProcessing/
I did a wmake libso in the cellFaceSetUtilities directory and a wmake in the calcMassFlow dirctory.
The last one is reading like this:
SOURCE=calcMassFlow.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/cfdTools/lnInclude -I/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/cfdTools/general/lnInclude -I/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/meshTools/lnInclude -I/home/sega/OpenFOAM/sega-1.4.1/Libraries/cellFaceSetUtilities/lnInclude -IlnInclude -I. -I/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/calcMassFlow.o
calcMassFlow.C:33:19: error: fvCFD.H: No such file or directory
calcMassFlow.C:37: error: 'FaceSetUtilities' is not a namespace-name
calcMassFlow.C:37: error: expected namespace-name before ';' token
In file included from /home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/addTimeOptions.H:1,
from calcMassFlow.C:45:
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/addConstantOption.H: In function 'int main(int, char**)':
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/addConstantOption.H:1: error: 'argList' has not been declared
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/addConstantOption.H:2: error: 'argList' has not been declared
In file included from /home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/addTimeOptions.H:2,
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/addTimeOption.H:1: error: 'argList' has not been declared
In file included from /home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/addTimeOptions.H:3,
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/addLatestTimeOption.H: 1: error: 'argList' has not been declared
In file included from calcMassFlow.C:47:
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/setRootCase.H:1: error: 'argList' was not declared in this scope
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/setRootCase.H:1: error: expected `;' before 'args'
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/setRootCase.H:3: error: 'args' was not declared in this scope
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/setRootCase.H:5: error: 'FatalError' was not declared in this scope
In file included from calcMassFlow.C:48:
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/createTime.H:1: error: 'Info' was not declared in this scope
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/createTime.H:1: error: 'endl' was not declared in this scope
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/createTime.H:5: error: variable 'Foam::Time runTime' has initializer but incomplete type
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/createTime.H:5: error: incomplete type 'Foam::Time' used in nested name specifier
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/createTime.H:6: error: 'args' was not declared in this scope
In file included from calcMassFlow.C:49:
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/createMesh.H:2: error: 'nl' was not declared in this scope
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/createMesh.H:4: error: 'fvMesh' was not declared in this scope
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/createMesh.H:4: error: expected `;' before 'mesh'
calcMassFlow.C:52: error: 'IOdictionary' was not declared in this scope
calcMassFlow.C:52: error: expected `;' before 'calcMassFlowDict'
calcMassFlow.C:64: error: 'wordList' does not name a type
calcMassFlow.C:66: error: 'dimensionedScalar' was not declared in this scope
calcMassFlow.C:66: error: expected `;' before 'rho'
calcMassFlow.C:68: error: 'calcMassFlowDict' was not declared in this scope
calcMassFlow.C:70: error: expected `;' before 'tmp'
calcMassFlow.C:71: error: 'rho' was not declared in this scope
calcMassFlow.C:71: error: 'tmp' was not declared in this scope
calcMassFlow.C:77: error: 'scalar' was not declared in this scope
calcMassFlow.C:77: error: expected `;' before 'scaleFactor'
calcMassFlow.C:78: error: 'calcMassFlowDict' was not declared in this scope
calcMassFlow.C:79: error: 'scaleFactor' was not declared in this scope
calcMassFlow.C:79: error: 'readScalar' was not declared in this scope
calcMassFlow.C:83: error: 'instantList' was not declared in this scope
calcMassFlow.C:83: error: expected `;' before 'Times'
In file included from calcMassFlow.C:86:
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/checkTimeOptions.H:1: error: 'label' was not declared in this scope
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/checkTimeOptions.H:1: error: expected `;' before 'startTime'
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/checkTimeOptions.H:2: error: expected `;' before 'endTime'
In file included from /home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/checkTimeOptions.H:4,
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/checkConstantOption.H: 4: error: 'Times' was not declared in this scope
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/checkConstantOption.H: 7: error: 'startTime' was not declared in this scope
In file included from /home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/checkTimeOptions.H:5,
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/checkTimeOption.H:3: error: expected `;' before 'time'
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/checkTimeOption.H:6: error: expected `;' before 'nearestDiff'
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/checkTimeOption.H:8: error: 'Times' was not declared in this scope
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/checkTimeOption.H:12: error: expected `;' before 'diff'
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/checkTimeOption.H:13: error: 'diff' was not declared in this scope
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/checkTimeOption.H:13: error: 'nearestDiff' was not declared in this scope
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/checkTimeOption.H:20: error: 'startTime' was not declared in this scope
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/checkTimeOption.H:21: error: 'endTime' was not declared in this scope
In file included from /home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/checkTimeOptions.H:6,
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/checkLatestTimeOption. H:3: error: 'startTime' was not declared in this scope
/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/checkLatestTimeOption. H:3: error: 'Times' was not declared in this scope
calcMassFlow.C:88: error: expected `;' before 'i'
calcMassFlow.C:88: error: 'i' was not declared in this scope
calcMassFlow.C:88: error: 'endTime' was not declared in this scope
calcMassFlow.C:90: error: 'Times' was not declared in this scope
In file included from calcMassFlow.C:94:
createPhi.H:5: error: 'IOobject' was not declared in this scope
createPhi.H:5: error: expected `;' before 'testPhi'
createPhi.H:13: error: 'testPhi' was not declared in this scope
createPhi.H:13: error: 'exists' was not declared in this scope
createPhi.H:18: error: 'surfaceScalarField' was not declared in this scope
createPhi.H:18: error: expected `;' before 'phi'
calcMassFlow.C:96: error: 'bcNames' was not declared in this scope
calcMassFlow.C:97: error: expected `;' before 'flux'
calcMassFlow.C:100: error: expected `;' before 'patchIndex'
calcMassFlow.C:101: error: 'patchIndex' was not declared in this scope
calcMassFlow.C:102: error: 'flux' was not declared in this scope
calcMassFlow.C:102: error: 'phi' was not declared in this scope
calcMassFlow.C:102: error: 'sum' was not declared in this scope
calcMassFlow.C:104: error: 'faceSet' was not declared in this scope
calcMassFlow.C:104: error: expected `;' before 'bcSet'
calcMassFlow.C:105: error: 'autoPtr' was not declared in this scope
calcMassFlow.C:105: error: 'flipSet' was not declared in this scope
calcMassFlow.C:105: error: 'flips' was not declared in this scope
calcMassFlow.C:105: error: 'mesh' was not declared in this scope
calcMassFlow.C:105: error: 'bcSet' was not declared in this scope
calcMassFlow.C:105: error: 'checkFaceSetSides' was not declared in this scope
calcMassFlow.C:109: error: 'faceSet' is not a class or namespace
calcMassFlow.C:109: error: expected `;' before 'faceI'
calcMassFlow.C:109: error: 'faceI' was not declared in this scope
calcMassFlow.C:111: error: expected `;' before 'factor'
calcMassFlow.C:112: error: 'flux' was not declared in this scope
calcMassFlow.C:112: error: 'factor' was not declared in this scope
calcMassFlow.C:112: error: 'phi' was not declared in this scope
calcMassFlow.C:119: error: expected `;' before 'fluxOut'
calcMassFlow.C:120: error: 'fluxOut' was not declared in this scope
make: *** [Make/linuxGccDPOpt/calcMassFlow.o] Fehler 1
Whats wrong?
Maybe the problem is, that I don't understand the following:
Make sure that the lnInclude is in the INCLUDE-path when compiling programs that use the library. The library itself is automagically used because it goes to the $FOAM_USER_LIBBIN.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   July 3, 2008, 15:15
Default Hi Sebastian! Don't bother.
  #11
Assistant Moderator
Bernhard Gschaider
Hi Sebastian!
Don't bother.
fvCFD.H is a strong hint, that this is a pre-1.3 source. It won't compile on a current OF-installation.
I think someone here on the MessageBoard posted an improved version a couple of months ago
Maybe I'll put the current version on the SVN one of these days, but don't hold your breath.
BTW: I never tried, but maybe the stock-utilities patchIntegrate/patchAverage might help you.
Bernhard
Old   July 11, 2008, 08:48
Default Hello Bernhard. Yes, the pa
  #12
sega's Avatar
Sebastian Gatzka
Hello Bernhard.
Yes, the patchAverage worked.
After calculating the Ucomponents I was able to calculate the average velocity and so the average mass flow rate.
If you remember my post at your setParabolicInlet I used a nonuniform list to create a parabolic inflow.
After comparing the desired average flow rate with the calculated value I have an error of about 0.8%.
Do you think this is small enough?
Sebastian
Old   March 18, 2014, 05:22
Post calcMassFlow.C:36:30: fatal error: FaceSetUtilities.H: No such file or directory
  #13
sam.ho is on a distinguished road
I am trying to compile calcMassFlow. I have followed wiki calcMassFlow instructions but I am getting the following error.
sml5kor@BMH301562:~/OpenFOAM/OpenFOAM-2.3.0/applications/calcMassFlow$ wmake
Making dependency list for source file calcMassFlow.C
could not open file FaceSetUtilities.H for source file calcMassFlow.C due to No such file or directory
SOURCE=calcMassFlow.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/sml5kor/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude -I/home/sml5kor/OpenFOAM/OpenFOAM-2.3.0/src/cfdTools/general/lnInclude      -I/home/sml5kor/OpenFOAM/OpenFOAM-2.3.0/src/meshTools/lnInclude      -I/home/sml5kor/OpenFOAM/sml5kor-2.3.0/Libraries/cellFaceSetUtilities/lnInclude -IlnInclude -I. -I/home/sml5kor/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude -I/home/sml5kor/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/calcMassFlow.o
compilation terminated.
make: *** [Make/linux64GccDPOpt/calcMassFlow.o] Error 1
Anybody is there to help me ?
sam.ho is offline   Reply With Quote
Old   March 23, 2018, 08:43
Arturo González
Arturo81 is on a distinguished road
Hello sam.ho
How did you correct the error message?
Can somebody help me? I'm using foam 4.0
Arturo81 is offline   Reply With Quote
Compile the UDF Eric FLUENT 7 August 18, 2006 15:46
F77 Compile. CFD User. Main CFD Forum 9 November 19, 2004 15:58
Help to Compile UDF chiph FLUENT 2 November 2, 2003 10:14
compile the UDF Li Jingping FLUENT 2 April 14, 2003 22:18
udf c compile Rat FLUENT 2 January 14, 2003 11:05
