November 17, 2010, 08:36 |
#181 |
Antonio Liggieri
Rep Power: 15 |
...problem solved!
since alphaEff = alphat (turbulent alpha) + alpha (laminar alpha), and alphat as well as alpha is defined as volsclarfield in and thus present, the groovyBC expression can be modified as follows: SURFACE_SOURCE { type groovyBC; value uniform 283; valueExpression "283"; gradientExpression "gradT"; fractionExpression "0"; variables "heatFlux=0.00000001;Cp0=1005;rho0=1.18;gradT=heat Flux/((alphat + alpha) * Cp0 * rho0);"; timelines ( ); } thanx for the hint regarding the connection of alphaEff to turbulence models - it led me to the solution! Tony |
December 3, 2010, 05:37 |
groovy and turbulent boundary condition
#182 |
Hi bernhard,
I am using pisofoam and I want to model a three dimentional free turbulent planar jet with large eddy simulation. in inlet I want to use turbulentinlet for velocity fluctuations generation also I want to specify an equation for mean velocity with groovyBC but for each of them I must use their specific type.
can I use both of them at the same time? what I must specify as "type"? I would appreciate any help sincerely yours |
December 3, 2010, 10:12 |
#183 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
December 4, 2010, 04:20 |
#184 |
>>just write a class groovyTurbulentInlet that inherits from turbulentInlet, sets the fields according to expressions then calls the superclass for the actual evaluation.
Hi Bernhard, thanks for your response. unfortunately, I have not done that yet so I would appreciate it if you could give me more details. sincerely yours, Yashar |
December 4, 2010, 04:24 |
#185 | |
December 6, 2010, 06:25 |
#186 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
If your average velocity doesn't chnage over time you might want to try funkySetBoundaryField from the swak-suite Bernhard |
December 6, 2010, 11:25 |
#187 | |
thank you for your reply. I am trying to write a new boundary condition with those applications. my velocity is constant over time. do you think that funkySetBoundaryField can be used in turbulent flow? Regards, Yashar |
December 6, 2010, 17:54 |
#188 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Have a look at the example that comes with swak Bernhard |
December 6, 2010, 22:37 |
#189 |
Rep Power: 16 |
Hey,
I am a new user of OpenFoam 1.7.1. I am interested in wave simulation using OpenFoam. I came through this groovyBC utility recently. As illustrated on the "contrib groovyBC" wiki page, I was able to download the libraries for the groovyBC case.... I dowloaded the full "groovyBC" folder in the following directory: ..../OpenFOAM-1.7.1/applications/solvers/groovy/groovyBC Then I ran the "wmake libso" command; which I think worked fine as it didn't produce any error message. Now, I tried to run demo cases in the Demos folder but I couldn't. For example, for the case pulsedPitzDaily, I was able to create a mesh using blockMesh, but in the next step when I ran the simulation using oodles (application: oodles in ControlDict file) command, I found the following error: oodles: command not found I think I am doing sth wrong at this step. Please help me out....I appreciate your help in advance. Regards, Abhishek |
December 7, 2010, 15:43 |
#190 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
December 21, 2010, 08:38 |
#191 |
Andreas Schwärzle
Rep Power: 16 |
I am trying to use the groovy BC to create an Inlet, where a uniform velocity-field should change randomly for every time-step within a certain range. Since the function randNormal() gives a random skalar field, I get a non-uniform velocity distribution. Is it possible to use rand() or randNormal() to get a single random skalar? INLET { type groovyBC; variables "uMin=0.9*vector(13,0,0);deltaU=0.2*vector(13,0,0) ;"; valueExpression "uMin+randNormal()*deltaU"; value uniform (13 0 0); } Thanks in advance for your help /Andreas |
December 22, 2010, 05:25 |
#192 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The only way I can think of would be to (I know this means some extra computation) take the value from only one cell and use it for all. Something like (havn't tried it and I'm not quite sure whether id() is in the regular groovyBC-distro or only in the swak-variant): variables "singleRandom=max(id()==0?rand():-1);"; |
January 4, 2011, 01:13 |
#193 |
J. Cai
Rep Power: 17 |
Hi, Bernhard, happy new year. Thank you for the contribution. Is the GroovyBC able to be used in OpenFOAM Version 1.7.1?
Thanks a lot, Chiven |
January 4, 2011, 06:27 |
#194 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Bernhard |
February 1, 2011, 11:23 |
#195 |
Anton Kidess
Rep Power: 30 |
I'm trying to write a boundary condition in groovyBC that requires the tangential gradient of the associated field. Is it possible to calculate a gradient on a patch face (not an snGrad)?
February 2, 2011, 10:47 |
#196 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The only way I could think of would be to calculate the gradient for the whole field (expensive!) beforehand and then getting the patch value for that field. Calculation of that gradient-Field could be done with the expressionField-functionObject from swak4Foam but as this is only done at the end of a time-step it will probably lag behind. So if this is an issue for you you'll probably have to modify the solver Bernhard |
February 2, 2011, 14:31 |
#197 |
Anton Kidess
Rep Power: 30 |
Thanks Bernhard. I actually noticed that after posting and went on to look if I could calculate a gradient of fvPatchField in the code, but that's far from trivial. fvc::grad works on GeometricFields / volMeshes, but since patches aren't directly related to either I'd have to come up with a whole new machinery to do this. The easy way out is (just as you said) to calculate the gradient for the entire field, and that seems to be a common solution from what I found on the forums.
February 2, 2011, 17:57 |
#198 |
Rep Power: 16 |
Hi
I am new to OpenFoam, and was trying to implement the groovyBC in the XiFoam/pitzDaily case, for OF 1.7.1. I installed and compiled the groovy BC, and used the following in the 0/T file (for wall heat transfer): upperWall { type groovyBC; variables "htot=100.0;Tinf=298.15;rho=2700.0;cp=900.0;k=DT*r ho*cp;"; valueExpression "Tinf"; fractionExpression "1.0/(1.0 + k/(mag(delta())*htot))"; } lowerWall { type groovyBC; variables "htot=100.0;Tinf=298.15;rho=2700.0;cp=900.0;k=DT*r ho*cp;"; valueExpression "Tinf"; fractionExpression "1.0/(1.0 + k/(mag(delta())*htot))"; } However, I got the following error: attempt to use janafThermo<equationOfState> out of temperature range 200 -> 5000; T = 0 Any ideas why this could be happening? gk |
February 3, 2011, 04:36 |
#199 |
Anton Kidess
Rep Power: 30 |
How did you initialize the internal field?
February 3, 2011, 08:44 |
#200 |
Rep Power: 16 |
Hi
Thanks for your reply. Here is the 0/T file: dimensions [ 0 0 0 1 0 0 0 ]; internalField uniform 293; boundaryField { inlet { type fixedValue; value uniform 293; } outlet { type inletOutlet; inletValue uniform 293; value uniform 293; } upperWall { type groovyBC; variables "htot=100.0;Tinf=298.15;rho=2700.0;cp=900.0;k=DT*r ho*cp;"; valueExpression "Tinf"; fractionExpression "1.0/(1.0 + k/(mag(delta())*htot))"; } lowerWall { type groovyBC; variables "htot=100.0;Tinf=298.15;rho=2700.0;cp=900.0;k=DT*r ho*cp;"; valueExpression "Tinf"; fractionExpression "1.0/(1.0 + k/(mag(delta())*htot))"; } frontAndBack { type groovyBC; variables "htot=100.0;Tinf=298.15;rho=2700.0;cp=900.0;k=DT*r ho*cp;"; valueExpression "Tinf"; fractionExpression "1.0/(1.0 + k/(mag(delta())*htot))"; } } Please note that I have also changed frontAndBack boundary type from 'cyclic' to 'wall' so that I could give the groovyBC; the upperWall and lowerWall are also of boundary type 'wall'. When I change the BC at the walls to fixedValue (isothermal BC) simulations seem to run fine. Thanks, gk |
Ship resistance shows wiggles when using Overset mesh and dynamic mesh in Fluent | Qingsong | FLUENT | 2 | March 21, 2022 16:08 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
[ICEM] Dynamic mesh setup with ICEM | David121284 | ANSYS Meshing & Geometry | 0 | April 11, 2014 05:19 |
Dynamic Mesh "Shadow Wall" | thezack | FLUENT | 0 | June 4, 2013 23:09 |
dynamic mesh for drop interface | IndrajitW | FLUENT | 0 | March 30, 2013 09:03 |
