Pressure Jump Correction. Actuator Disc Model and numerical wiggles |
June 4, 2014, 05:50 |
#1 | |
M. Montero
Rep Power: 17 |
Hi all,
I am working over the rotorDisk model implemented over OpenFoam and I have found a critical issue related to the SIMPLE algorithm. The issue is described in the next paper: http://orbit.dtu.dk/fedora/objects/o...190785/content Quote:
In the report, he modifies the Rhie-Chow/SIMPLE pressure correction algorithm, but it is possible to overcome this issue by distributing the force around the cell. I think that the amplitude of the oscillation near the rotor plane is aleatory but could depend on TI, mesh discretization, schemes.... With a TI = 10%, that wiggle is still there but the amplitude of the oscillation is not so high so the error when calculating the angle of attack is not high. Best Regards Marcelino |
June 4, 2014, 07:16 |
Niels Nielsen
Rep Power: 27 |
Hi Marcelino
regarding the rotorDisk, do you have a simple test case? I have made a simple case, but I cannot for the life of me find you why I do not get any radial/tangential vectors from the disk. There is only axial thrust and everything looks to be fine, but just no radial/tangential vectors. I can post my case here if you want to have a look.
Linnemann PS. I do not do personal support, so please post in the forums. |
June 4, 2014, 08:39 |
M. Montero
Rep Power: 17 |
Hi Linnemann,
What OF version do you use? There were some bugs in OF2.3.0 and before about rotorDiskSource. http://www.openfoam.org/mantisbt/vie...d=708#bugnotes Be sure to use last OF2.3.x where this issue was solved and another one about the forces proyection. I do not have a simple test case that I could share, but feel free to post your case and if I can, I will help you. About the main topic of the post, it seems it is in relation to this other topic: http://www.cfd-online.com/Forums/ope...-pressure.html and http://www.cfd-online.com/Forums/ope...rce-model.html. In this latter topic, you posted also. The same problem was seen by tstovall But I do not know how to modify simpleFoam to manage correctly body forces. It would be great if someone could give some support Best Regards |
June 4, 2014, 08:46 |
Niels Nielsen
Rep Power: 27 |
Ahh
Well I am using 2.3.x but not nearly that new a commit. I will update and see where that leaves me. I will also post a simple case for you/others to investigate.
June 4, 2014, 17:20 |
Niels Nielsen
Rep Power: 27 |
Hi
After the update i get some tangential velocities. But everything looks very strange, on the old code i got some ok axial thrust. Now its just a mess. The propeller rotates around the y axis with the flow direction in the positive y-direction. Here is a Drive link to the case.
June 5, 2014, 06:59 |
M. Montero
Rep Power: 17 |
Hi.
I have been using a "personal" updated version of OF2.3.0 where velocity and forces are correctly proyected ( vectors from cartesian CS to cylindrical CS) http://www.cfd-online.com/Forums/ope...read-file.html In this post it is included the solution proposed by GDTech that works for me. I attach you a picture where the flow seems ok. Using OF2.3.x, I thought that the bug fixed proposed by the official site would solve the problem but.....I have used it and I obtain strange AoA distribution and forces like you so .... I will reopen the bug report. |
June 6, 2014, 02:33 |
Niels Nielsen
Rep Power: 27 |
Hi
was that picture made with my small case?
June 6, 2014, 04:55 |
M. Montero
Rep Power: 17 |
yes, it was but with my own OF2.3.0, not OF2.3.x.
I have modified a little bit the fvOptions file to rotate it as a propeller. Last edited by be_inspired; June 9, 2014 at 06:01. |
October 21, 2014, 15:11 |
#9 |
Rep Power: 13 |
Dear be_inspired,
I am somewhat new to openFoam and I am trying to set up a case with a main rotor similar to what you have. Would it be posible to ask for some guidance on the set up as there are no examples on how to use this function. I started by modifying heatExchanger, changing fvOption from MFRSource to rotorDisk with its coefficients, and removing the excess. I appreciate your time and I think I can work it out from an example of the ./Allrun and any additional dict file if that is possible. Thanks |
April 19, 2017, 16:47 |
#10 | |
CFD
Rep Power: 17 |
Look forward to hearing from you. |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 08:18 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
pipe model numerical integration | datle | Main CFD Forum | 11 | November 26, 2013 13:26 |
numerical prediction of Pressure fluctuations in hydraulic jump | masoud197 | CFX | 1 | January 22, 2012 18:58 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 14:57 |
