Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend"
Like Tree134Likes
Closed Thread
Old   September 4, 2013, 14:06
Daniel
Daniel_Khazaei will become famous soon enough
Originally Posted by sloti View Post
Hi everyone,
I had a look at Philips FSI solver and am especially excited about the possibility to run it in parallel, as icoFsiFoam is apparently not running in parallel yet.
However, I managed to run the HronTurekFsi case in parallel but I can't reconstruct the data.. the results of the processors are all stored under the fluid/processor*/"time" folder where also the solid results are located within another folder (fluid/processor*/"time"/solid). When I run reconstructPar that folder is ignored and only the fluid data is reconstructed.
Probably I just make a stupid fault.. Any help would be appreciated!
Regards, Anna
Update: problem solved. not sure whether this is the most elegant way, but I wrote a batch sorting things out!
Hi Anna
were you able to run the FSI case in parallel without any problem? (completely I mean, end of simulation time)
I have a problem you can see in this post : click
@ Dr. Cardiff
can FSI solver handle multiple FSI interfaces that are separate?
Daniel_Khazaei is offline
Old   September 4, 2013, 14:44
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi Daniel,
the solver currently setup to use only one FSI interface; however, it should be straight-forward to extend it to an arbitrary number if you don't mind a bit of coding.
Alternatively, you could merge your patch to make sure you have only one FSI interface (it doesn't matter is the FSI interface is discontinuous).
Philip
bigphil is offline
Old   September 9, 2013, 07:03
davidsblom is on a distinguished road
I've modified the settings of the test case to run the FSI2 case. However, after some simulation time the solver stops, and when I look into the mesh there is a large overlap at the tip of the flap.I have attached a couple of screenshots in order to visualize the problem.
https://dl.dropboxusercontent.com/u/...pshot3.png.zip
Any idea what is happening here? Is the interpolation between the solid and fluid mesh which is not correct? Or the problems lies somewhere else? Hints anyone?
Thanks alot!
Best regards,
David
davidsblom is offline
Old   September 11, 2013, 03:15
Vincent
VincentChai is on a distinguished road
Hi Philip,
I am trying to plot the displacement of the plate (at the plate back center point)
in paraView by create selection and "plot selection over time", however, the following error appear:
ERROR: In /home/vin-82/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.12.0/VTK/Charts/vtkContext2D.cxx, line 177
vtkContext2D (0x9ce0930): Attempted to paint a line with <2 points.
and there is no data appear on the plot.
May i know how to solve this problem?
Thanks
VincentChai is offline
Old   September 11, 2013, 11:19
bigphil's Avatar
Philip Cardiff
Originally Posted by VincentChai View Post
Hi Philip,
Thanks
Hi Vincent,
I have noticed problems using the ParaView filter "Plot selection over time" when there are a large number of time-steps.
So I would suggest you try a test case with about 10 time-steps and see if that works, then try large numbers of time-steps.
Best regards,
Philip
bigphil is offline
Old   September 15, 2013, 18:14
Daniel
@ Dr. Cardiff
I want to use dynamicRefineFvMesh as a dynamicFvMesh in dynamicMeshDict on FSI solver. I have changed what I think is necessary for dynamicRefineFvMesh.
But I am still getting this error:
Time = 1e-06, iteration: 3
Current fsi under-relaxation factor (Aitken): 0.999595
Maximal accumulated displacement of interface points: 0.0251937
--> FOAM FATAL ERROR:
Problem with mesh motion solver selection
    From function pimpleFsiElasticNonLinULSolidFoam
    in file moveFluidMesh.H at line 140.
FOAM aborting
Aborted (core dumped)
is it possible to use dynamicRefineFvMesh with FSI solver?
regards
Old   September 16, 2013, 06:12
bigphil's Avatar
Philip Cardiff
@Bruno
Nice work!
@Daniel
Sorry, I am not familiar with dynamicRefineFvMesh.
Philip
bigphil is offline
Old   September 16, 2013, 15:02
Daniel
Originally Posted by bigphil View Post
@Bruno
Nice work!
@Daniel
Philip
Hi Dr. Cardiff
sorry for lots of questions
Does FSI solver support topological changes in the fluid region?
I want to use dynamicTopoFvMesh for my test case, I have problems with PatchToPatchInterpolation.
this problem occurs after mesh refinement.
regards
Old   September 16, 2013, 22:14
Vincent
Hi Philip,
Good morning!
I have found a file "gpDeflection" in the tutorial, is this file for plotting the deflection of the plate? Thanks.
Regards,
Vincent
Old   September 24, 2013, 00:18
cutty4sark is on a distinguished road
I've been following this post for some time and having been playing around with trying to merge the CHT solver with the FSI solver. The problem I keep coming back to is how the different solvers handle the solid and fluid. In the FSI solver, there are separate directories for the different regions with separate meshes whereas the CHT solver seems to lump everything together into one mesh with different regions. Am I wrong in thinking that there will need to be some major reworking of how the CHT handles the fluid and solid since it does not match the FSI solver? Any pointers would certainly be appreciated and I will happily share results if there ever are any! Also, if I need to clarify anything, please let me know.
cutty4sark is offline
Old   September 24, 2013, 19:44
Daniel
Hi Dr. Cardiff
I am working on simulation of flexible pipe with FSI solver.
I have changed the fluid solver to use pimple algorithm.
I have a question about FSI outer corrector:
In my simulation, in each time step I get only 3 outer iteration for every time step. The solver also produces FSI under relaxation factor higher than 1 (e.g. 1.00078)
furthermore, FSI residual suddenly drop in iteration 3, it acts like:
iteration #1: fsi residual = 1
iteration #2: fsi residual = 0.997888
iteration #3: fsi residual = 5.4322e-5
Any suggestion would be appreciated, tell me if you need more information about case setup.
regards
Old   September 26, 2013, 22:41
Default Problem with analytical solution of hotCylinder : elasticThermalSolidFoam
  #112
Mohammad Shakil Ahmmed
ahmmedshakil is on a distinguished road
Hi Cardif,
I'm having problem with the analytical solution of the hot Cylinder case that is provided with the elasticThermalSolidFoam. When I run the case it gives error like this:
Create time
Create mesh for time = 0
Writing analytical solution for a plain strain cylinder with concentric hole,
where
inner radius = 0.5
outer radius = 0.7
inner temperature = 100
outer temperature = 0
inner pressure = 0
outer pressure = 0
E = 200e9
u = 0.3
alpha = 1e-5
Writing analytical termpature field
Writing analytical sigmaR field
Writing analytical sigmaTheta field
Writing analytical sigmaZ field
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
in "/home/adminuser/OpenFOAM/adminuser-2.1.0/platforms/linux64GccDPOpt/bin/analyticalHotCylinder"
#4 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Basically it creates the problem when calculating the sigmaZ. Will you please suggest me how to get rid of this??
Hi Sangeeta,
The solidMechanics solvers and library use a number of features (such as GGI) that are only found in the OpenFOAM Extend (not the standard OpenCFD OpenFOAM). Therefore, I would recommend you install OpenFOAM-1.6-ext if you want to use solidMechanics (Note: OpenFOAM-1.6.x is released by OpenCFD and OpenFOAM-1.6-ext is realised by the Extend Project).
It would probably be possible to compile the solvers in standard OpenFOAM but you would have to exclude quite a bit of the functionality. So it is much easier to install OpenFOAM-1.6-ext.
Philip
ahmmedshakil is offline
Old   September 27, 2013, 02:26
  #113
I solved the problem. It was coming from the atan(y/x) function. I am using OpenFoam 2.1.0 and for two argument passing through arc tan function -->the correct function is: atan2(y,x).
Originally Posted by ahmmedshakil View Post
Hi Cardif,
Create time
where
inner radius = 0.5
outer radius = 0.7
inner pressure = 0
outer pressure = 0
E = 200e9
u = 0.3
alpha = 1e-5
Old   September 29, 2013, 12:29
Daniel
Hello Dr. Cardiff
I have tested my case with fixedRelaxationFactor method with value of 0.2 and the solution will converge and FSI residual reduces smoothly and after 43 outer iterations it will reach to FSI convergence tolerance.
Is there anything special that I am missing with Aitken method?
I have found this old topic with the same problem that I have:
http://www.cfd-online.com/Forums/ope...ation-fsi.html
regards
Old   September 30, 2013, 14:25
bigphil's Avatar
Philip Cardiff
@Daniel
As regards topological changes, changes may be required but I do not have any experience with this.
As regards "Aitken" vs. "Fixed" relaxation, there is quite a bit of literature on this for FSI if you search google. For instance, the implemented Aitken procedure is presented here by Z. Tukovic.
@Vincent
The "gpDeflection" file is a gnuplot script; but it was used when the solver specifically wrote out the beam tip displacement to a file. It was removed to make the code more generic, it would have to be coded in to the solver.
@ahmmedshakil
Thanks for the fix!
Philip
bigphil is offline
Old   September 30, 2013, 14:50
Daniel
@Daniel
Philip
Nice to have you back
thanks for the answer.
well I have read 4 papers so far on coupling algorithm, Fixedrelaxation, Aitken and IQN-ILS. But I can not understand why fsi under relaxation factor goes higher than 1.
This is the case I am working on it for now: (you can see the geometry in attachment)
as for the fluid region:
fluid/0/motionU:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    FSI
        type            fixedValue;
        value           uniform (0 0 0);
    OUTLET
         type            zeroGradient;
    INLET
        type            zeroGradient;
fluid/0/p
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    FSI
        type            zeroGradient;
    OUTLET
        type            fixedValue;
        value           uniform 0;
    INLET
        type            fixedValue;
        value           uniform 50;
fluid/0/U
boundaryField
    FSI
        type            fixedValue;
    OUTLET
        type            zeroGradient;
    INLET
        type            pressureInletVelocity;
for the solid region (DU):
dimensions      [0 1 0 0 0 0 0];
boundaryField
    FSI
        type solidTraction;
        nonLinear updatedLagrangian;
        traction uniform ( 0 0 0 );
        pressure uniform 0;
    O_WALL
        type solidTraction;
        pressure uniform 0;
    INLET
       type            zeroGradent;
    OUTLET
       type            zeroGradent;
for coupling properties:
solidPatch FSI;
solidZone FSIZone;
fluidPatch FSI;
fluidZone FSIZone;
//movingRegion region0;
fsiRelaxationFactor 0.01;
interfaceDeformationLimit 0.01;
outerCorrTolerance 1e-4;
couplingScheme Aitken;
fsi yes;
for dynamicMesh settings:
dynamicFvMesh   dynamicMotionSolverFvMesh;
twoDMotion      no;
//solver          velocityLaplacian;
solver          laplaceFaceDecomposition;
diffusivity quadratic inverseDistance 1(FSI);
frozenDiffusion yes;
distancePatches
    FSI
what movingWallVelocity actually does? when I use it in my case I get floating point exception error. (instead I am using fixedValue)
Is there anything obviously wrong with my setup? Actually I dont know what kind of boundary condition should I use for patch which is shown by arrow in the attachment.
sorry for long question!
regards
iqbalsk8 likes this.
Old   October 1, 2013, 06:11
Default Appropriate boundary condition for displacement U
  #117
I'm solving similar problem as arc welding in thin plate. I'm using elasticThermalSolidFoam solver. In my cases, I have to impose the boundary condition for U as follows (given in diagram also),
(a) At X=0 and X= L ------------> sigmaxx = 0, sigmaxy =0,
(b) At Y=0 -------------> du/dy =0, v=0,
(c) At Y =H ---------------> sigmayx =0, sigmayy=0.
As I am new to solid mechanics solver in OpenFoam, I'm wondering which boundary condition should I use.... either it
(1) fixedDisplacement boundary with value (0 0 0) OR
(2) fixedDisplacementZeroShare with value (0 0 0) OR anything else
Anyone have idea which boundary condition I can use??
| Y sigmayx=0, sigmayy=0
sigmaxx=0 | | sigmaxx=0
sigmaxy=0 | | sigmaxy=0
|---------------------------------------------------------|-------------->X
du/dy =0, v=0
The problem is similar to the case 4.4 mentioned by the paper: "I. Demirdžić, D. Martinović Finite volume method for thermo-elasto-plastic stress analysis, Computer Methods in Applied Mechanics and Engineering, vol 109, 331-349".
Old   October 1, 2013, 06:28
Sorry, the image will be as attached (above the diagram a bit disfigured)..
du/dy =0, v=0
Old   October 3, 2013, 13:16
bigphil's Avatar
Philip Cardiff
Hi ahmmedshakil,
For your boundary conditions, the left, top and right are traction boundaries so use solidTraction with zero pressure and traction.
For the bottom boundary, it is effectively a symmetryPlane (zero normal displacement, zero normal gradient of shear displacements). directionMixed can be also be used but is only necessary when the normal displacement is non-zero.
Philip
bigphil is offline
Old   October 3, 2013, 13:27
bigphil's Avatar
Philip Cardiff
Hi Daniel,
If you search for "Aitken acceleration" on google, you will finds lots of explanations, but essentially the acceleration factor does not have to be limited to be less than 1 or even positive.
As regards application of the Aitken's method to under-relaxation in FSI procedure, sometimes people may limit it but I am not sure of the reasoning (maybe they feel uncomfortable with relaxation factor >1 and/or <0)
You should be able to find descriptions of movingWallVelocity on the forum or at least in the code.
As far as I know, it is a boundary condition for the fluid velocity field for a wall that is moving.
This should not be used as a solid boundary condition.
I don't think you have set the correct boundary condition types for FSI in U and DU.
As regards what boundary condition to use for the patch shown, this depends on what physical condition you want to enforce. Typically you don't use zeroGradient as a solid boundary as it does not really correspond to a physical condition (it's kind of like zero strain).
Philip
bigphil is offline
Closed Thread
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 15:22
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread wyldckat OpenFOAM Installation 2 July 11, 2012 17:01
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 14:50
