cuttingPlane + timeVaryingMappedFixedValue - channel flow
Old   August 7, 2013, 07:26
Default cuttingPlane + timeVaryingMappedFixedValue - channel flow
KYPCK444 is on a distinguished road
I am working with channel flow case.
I want to set as inlet conditions fields data obtained from a previous channel flow simulation, which has been left reaching fully developed features.
Referring to http://www.cfd-online.com/Forums/ope...tml#post264064 and http://www.cfd-online.com/Forums/ope...tingplane.html I am trying to apply the cuttingPlane method to the "previous-channel-flow", but I am new to openFoam and I'm not able to correctly edit the solver (I'm using channelFoam solver) in order to create a set of field files to be used (using timeVaryingMappedFixedValue patch such as in pitzDailyExptInlet tutorial) as inlet conditions for the "second-channel-flow".
I tried to edit channelFoam solver this way:
#include "fvCFD.H"
#include "singlePhaseTransportModel.H"
#include "LESModel.H"
#include "IFstream.H"
#include "OFstream.H"
#include "Random.H"
int main(int argc, char *argv[])
#include "setRootCase.H"
#include "createTime.H"
#include "createMesh.H"
#include "readTransportProperties.H"
#include "createFields.H"
#include "initContinuityErrs.H"
#include "createGradP.H"
point pnt(3,0,0);
vector direction(1,0,0);
plane pl1(pnt,direction);
cuttingPlane cutPlane(mesh,pl1);
const labelList& cutCells = cutPlane.cells();
cellSet someCells(mesh,"someCells",cutCells);
someCells.write();
(in bold the lines I added, taken from the aforementioned topics).
Trying to compile the new solver with wmake, I obtain what follows:
channelFoam_cuttingPlane.C:54:1: error: ‘plane’ was not declared in this scope
channelFoam_cuttingPlane.C:54:7: error: expected ‘;’ before ‘pl1’
channelFoam_cuttingPlane.C:55:1: error: ‘cuttingPlane’ was not declared in this scope
channelFoam_cuttingPlane.C:55:14: error: expected ‘;’ before ‘cutPlane’
channelFoam_cuttingPlane.C:56:29: error: ‘cutPlane’ was not declared in this scope
channelFoam_cuttingPlane.C:57:1: error: ‘cellSet’ was not declared in this scope
channelFoam_cuttingPlane.C:57:9: error: expected ‘;’ before ‘someCells’
channelFoam_cuttingPlane.C:58:1: error: ‘someCells’ was not declared in this scope
/opt/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude/readPISOControls.H:3:15: warning: unused variable ‘nOuterCorr’
/opt/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude/readPISOControls.H:15:16: warning: unused variable ‘transonic’
channelFoam_cuttingPlane.C:56:18: warning: unused variable ‘cutCells’
make: *** [Make/linux64GccDPOpt/channelFoam_cuttingPlane.o] Error 1
Does anyone know what and where I am failing?
I would also like to know if it is possible, once the data from the cuttingSurface have been taken, to map them as inlet conditions to the second channel if this one is discretized with a finer mesh.
I hope it's not a problem if I opened a new thread about the topic, because the reference ones are very old and inactive, I guess.
(I apologize if my questions are silly ^^)
Thank you very much in advance.
KYPCK444 is offline   Reply With Quote
Old   May 12, 2017, 16:40
Ashish Kumar
ashish.svm is on a distinguished road
Originally Posted by KYPCK444 View Post
#include "fvCFD.H"
#include "Random.H"
point pnt(3,0,0);
someCells.write();
I am also facing the same errors.
ashish.svm is offline   Reply With Quote
Channel flow using InterFOAM DanM OpenFOAM Running, Solving & CFD 49 July 31, 2020 12:43
rhoCentralFoam for channel flow fportela OpenFOAM Running, Solving & CFD 22 June 10, 2014 21:14
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 07:44
references for how to maintain a constant flow rate in turbulent channel flow amirrstg Main CFD Forum 0 October 25, 2011 04:17
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
