volum integral of mag(U)...?
Like Tree12Likes
Old   March 27, 2012, 07:39
Default Bug in coded function in parallel mode resolved
  #21
Eelco van Vliet
eelcovv is on a distinguished road
I just got a message that the bug has been resolved in OF 2.1.x.
http://www.openfoam.org/mantisbt/view.php?id=480
Regards
Eelco
eelcovv is offline   Reply With Quote
Old   September 12, 2012, 10:44
Michael
lithos is on a distinguished road
Originally Posted by akidess View Post
Eelco, did you use this link: https://code.google.com/p/foamcalcex/ ?
I'm attaching a tarball with the code to this post. Let me know if you have any troubles with it.
You're my hero of the day. Thanks a lot for this wonderful piece of code. It is working fine on Mac OS X 10.6.8 with OpenFOAM 2.0.x build 931a91d59a3a.
lithos is offline   Reply With Quote
Old   September 27, 2012, 01:56
neetu kumari
neetu kumari is on a distinguished road
You just compiled the post-processing libraries postCalc and foamCalcFunctionsEx, but not the application. I think you are in the wrong directory.
The directory tree should look like this:
foamcalcex
---- Allwmake
---- foamCalcExApp
-------- foamCalc.C
-------- Make
---- postProcessing
-------- Allwmake
-------- foamCalcFunctionsEx
-------- postCalc
Are you using the Allwmake script in the top level directory?
Hi!
I am Neetu. I have also downloaded the tar file foamCalcEx. I have compiled it correctly according to your instruction, but still it is not working. When I am running this function from my case directory then it showing that "foamClacEx command is not found". What should I do now? Give me the solution for this problem.
Thanks
neetu kumari is offline   Reply With Quote
Old   October 1, 2012, 08:41
akidess's Avatar
Anton Kidess
Originally Posted by neetu kumari View Post
Hi!
Thanks
Did you have any compilation errors?
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   October 2, 2012, 11:06
Michael
Hi!
Thanks
Dear Neetu,
please make sure that you correct each 'files' file in each of the three 'Make' directories. If you use a local user environment for compiling additional stuff for OpenFOAM they should be
foamCalc.C
EXE = $(FOAM_USER_APPBIN)/foamCalcEx
calcType/calcType.C
LIB = $(FOAM_USER_LIBBIN)/libfoamCalcFunctionsEx
postCalc.C
LIB = $(FOAM_USER_LIBBIN)/postCalc
That means you would have to set
FOAM_USER_APPBIN
FOAM_USER_LIBBIN.
Usually the structure in WM_PROJECT_USER_DIR should be like
WM_PROJECT_USER_DIR/run
WM_PROJECT_USER_DIR/lib
WM_PROJECT_USER_DIR/platforms/...your_system.../bin. You can find out the assigned directory by typing
echo $FOAM_USER_APPBIN
Have a nice day.
Cheers,
Michael
Old   October 2, 2012, 11:13
akidess's Avatar
Anton Kidess
The changes that Michael mentioned are already incorporated in the code repository (the tarball is not up to date). You can follow Michael's instructions, or get a copy using 'hg clone' (see previous posts or https://code.google.com/p/foamcalcex/source/checkout). Also do the same if you want to use foamCalcEx with OF-1.6-ext.
- Anton
Old   October 3, 2012, 00:45
neetu kumari
Thank you for the reply. Now I am able to compile the file correctly.
Thanks
Old   October 17, 2012, 03:44
Default please help me?
  #28
vahid
vahid.najafi is an unknown quantity at this point
Hi dear Foamers.
I want to calculate one equation(pics of it attachmented), im my case.
please help me ,and tell me how to do it???
thanks for your attention.
vahid.najafi is offline   Reply With Quote
Old   November 20, 2014, 00:11
Albert Tong
tfuwa is on a distinguished road
Dear Anton,
Thanks for the great tool.
Is it possible to average/integrate a certain parameter over a specific area, say num1<x<num2 & num3<y<num4?
Kind regards,
Albert
tfuwa is offline   Reply With Quote
Old   November 20, 2014, 04:50
akidess's Avatar
Anton Kidess
The way I would do that is to create a volScalarField (e.g. using funkySetFields) that is 1 in your area of interest and 0 elsewhere, multiply it with your field of interest using foamCalcEx, and then doing the integration or averaging. Alternatively, you can also have a look at funkyDoCalc which might be able to do what you want using a dictionary.
Old   October 5, 2015, 00:02
Dasein
Tellur is on a distinguished road
Hi Anton, I am trying to compile your utility under OpefFoam 2.4. I'm following the details on the wiki installation but I am getting the following error:
~/OpenFOAM/theodore-2.4.0/foamcalcex/postProcessing ~/OpenFOAM/theodore-2.4.0/foamcalcex
+ wmake libo postCalc
'/home/theodore/OpenFOAM/root-2.4.0/platforms/linux64GccDPOpt/lib/postCalc.o' is up to date.
+ wmake libso foamCalcFunctionsEx
make: *** No rule to make target `/opt/openfoam240/src/finiteVolume/lnInclude/cyclicAMILduInterface.H', needed by `calcType/calcType.dep'. Stop.
root@node3:~/OpenFOAM/theodore-2.4.0/foamcalcex# ./Allwmake
SOURCE=calcType/calcType.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam240/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam240/src/OpenFOAM/lnInclude -I/opt/openfoam240/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/calcType.o
In file included from /opt/openfoam240/src/finiteVolume/lnInclude/ddtScheme.C:30:0,
from /opt/openfoam240/src/finiteVolume/lnInclude/ddtScheme.H:325,
from /opt/openfoam240/src/finiteVolume/lnInclude/fvcDdt.C:28,
from /opt/openfoam240/src/finiteVolume/lnInclude/fvcDdt.H:199,
from /opt/openfoam240/src/finiteVolume/lnInclude/fvc.H:44,
from /opt/openfoam240/src/finiteVolume/lnInclude/fvCFD.H:8,
from calcType/calcType.H:48,
from calcType/calcType.C:26:
/opt/openfoam240/src/finiteVolume/lnInclude/cyclicAMIFvPatch.H:39:35: fatal error: cyclicAMILduInterface.H: No such file or directory
#include "cyclicAMILduInterface.H"
I tried looking around in the site for changes in the Make files but nothing worked so far. Any idea what it could be?
Thanks in advance!
Theodore.
Tellur is offline   Reply With Quote
Old   October 12, 2015, 06:26
akidess's Avatar
Anton Kidess
Sorry, I just noticed your post now. If you haven't solved it already, the solution is to modify Make/options for foamCalcFunctionsEx as follows (adding include and library references to meshTools):
ifdef FOAM_DEV
  FOAM_DEV_OPTION = -DFOAM_DEV
endif
EXE_INC = \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude \
   $(FOAM_DEV_OPTION)
EXE_LIBS = \
    -lfiniteVolume \
    -lmeshTools
Old   August 1, 2016, 07:06
sahm's Avatar
Seyyed Ali H.M.
sahm is on a distinguished road
Hi Anton
I am trying to compile the FoamCalcEx library on OpenFOAM v1606+ and I have added the meshtools in the options files, but I'm getting this error message:
Make/linux64GccDPInt32Opt/field/components/components.o
field/components/components.C: In member function ‘virtual void Foam::calcTypes::components::calc(const Foam::argList&, const Foam::Time&, const Foam::fvMesh&)’:
field/components/components.C:95:21: error: ‘class Foam::IOobject’ has no member named ‘headerOk’
if (fieldHeader.headerOk())
/home/sahm/OpenFOAM/OpenFOAM-v1606+/wmake/rules/General/transform:8: recipe for target 'Make/linux64GccDPInt32Opt/field/components/components.o' failed
make: *** [Make/linux64GccDPInt32Opt/field/components/components.o] Error 1
I'm trying to understand where this problem is rooting from. Apparently some other applications of openfoam have this headerOk function and they compiled fine. But this one is giving me error. Could you please help me with this? I need foamCalcEx to calculate average of a field in my project. In the meantime I will try working on it.
SAHM
sahm is offline   Reply With Quote
Old   January 24, 2019, 17:00
sahm's Avatar
Seyyed Ali H.M.
For my future reference: Change headerOk to typeHeaderOK
SAHM
Old   January 6, 2020, 11:39
X
mcfdma is on a distinguished road
Hello Anton, firstly, thank you for sharing your utility.
I would like to know if it's possible to use volIntegrate field across a line (one point to another) instead of the entire domain?
mcfdma is offline   Reply With Quote
Old   April 23, 2020, 08:32
Kabir Shariff
Kbshariff is on a distinguished road
If I may shamelessly promote my own utility here:
http://code.google.com/p/foamcalcex/
I extended the standard foamCalc tool to support min, max and volumeIntegrate calculations.
foamCalcEx mag U
foamCalcEx volIntegrate magU > data.txt
The above lines will write the volume integral into a text file data.txt.
I tried to use your uility on OF 7, but unfortunately i have this error.
Kindly assist please
~/foamcalcex/postProcessing ~/foamcalcex
wmake libo postCalc
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam7/src/finiteVolume/lnInclude  -IlnInclude -I. -I/opt/openfoam7/src/OpenFOAM/lnInclude -I/opt/openfoam7/src/OSspecific/POSIX/lnInclude   -fPIC -c calcType/calcType.C -o Make/linux64GccDPInt32Opt/calcType/calcType.o
In file included from /opt/openfoam7/src/finiteVolume/lnInclude/ddtScheme.C:30:0,
                 from /opt/openfoam7/src/finiteVolume/lnInclude/ddtScheme.H:357,
                 from /opt/openfoam7/src/finiteVolume/lnInclude/fvcDdt.C:28,
                 from /opt/openfoam7/src/finiteVolume/lnInclude/fvcDdt.H:250,
                 from /opt/openfoam7/src/finiteVolume/lnInclude/fvc.H:44,
                 from /opt/openfoam7/src/finiteVolume/lnInclude/fvCFD.H:8,
/opt/openfoam7/src/finiteVolume/lnInclude/cyclicAMIFvPatch.H:39:10: fatal error: cyclicAMILduInterface.H: No such file or directory
compilation terminated.
/opt/openfoam7/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/calcType/calcType.o' failed
make: *** [Make/linux64GccDPInt32Opt/calcType/calcType.o] Error 1
regards,
Kabir
Kbshariff is offline   Reply With Quote
RANS in integral form siw Main CFD Forum 0 August 17, 2010 04:18
please help to patch volum of secondary phase VOF zidouni FLUENT 1 February 27, 2008 06:46
monitor surface integral & report surface integral Ning FLUENT 0 March 18, 2007 13:51
Evaluation of boundary integral aunola Main CFD Forum 0 May 8, 2006 08:54
Von Karman Integral Length Scale Txingurri Main CFD Forum 0 May 2, 2002 13:05
