Easy lagrangian fluid particle tracking
Like Tree9Likes
Old   February 6, 2012, 12:49
Default Easy lagrangian fluid particle tracking
Michael Bruckner
michaelb is on a distinguished road
Hello Foamers,
I would like to know if there is a simple solver which could allow me to track a cloud of fluid particles ( size less : no drag & massless : no settling due to gravity) injected as a sphere of given position and diameter at t = 0 (only) with no initial velocity in an unsteady simulation.
Is there a way of doing such things with the icoLagrangianFoam solver in OpenFOAM-1.6-ext ? I couldn't figure out what would be the appropriate parameters in the kinematicCloudProperties dic file.
Actually, I need, for each saved timestep, the particles locations and their distances to wall patches.
If anybody could give me an hint on how to start here, I would be eternally thankful.
Best regards,
Michael
michaelb is offline   Reply With Quote
Old   February 9, 2012, 11:00
Default passiveParticle
Bernhard Grieser
BernhardGrieser is on a distinguished road
Hi Michael,
I'm trying the same at the moment: Massless tracer particles. So far, I've only succeeded to load two particles in a cloud, and to write out their positions in an object file. Still fiddling around with the particle movement, though.
That's my code, so far:
vector position1(0.00005, 0.0001, 0.000995);
vector position2(0.00005, 0.0001, 0.001005);
label celli1 = mesh.findCell(position1);
label celli2 = mesh.findCell(position2);
Info<< "celli1 = mesh.findCell(position1) = " << celli1 << endl;
Info<< "celli2 = mesh.findCell(position2) = " << celli2 << endl;
const IDLList<passiveParticle>& particles();
passiveParticleCloud cloud(mesh, "cloud", particles);
cloud.clear();
passiveParticle* ptr1 = new passiveParticle(cloud, position1, celli1);
cloud.addParticle(ptr1);
passiveParticle* ptr2 = new passiveParticle(cloud, position2, celli2);
cloud.addParticle(ptr2);
cloud.writePositions();
Did you already solve the issue? Can somebody else help us?
Best Regards,
Bernhard
BernhardGrieser is offline   Reply With Quote
Old   February 9, 2012, 11:10
Default move particle tracer with the flow
Bernhard Grieser
one question would be, for example:
1.) How to address the cloud member function move()?
Compiling with
cloud.move();
returns the error message:
error: no matching function for call to 'Foam::passiveParticleCloud::move()'
2.) How to interpret the following warning message?
warning: the address of 'const Foam::IDLList<Foam::passiveParticle>& particles()' will always evaluate as 'true'
Cheers,
Bernhard
Old   February 9, 2012, 12:55
Francesco Capuano
francesco_capuano is on a distinguished road
One guess for question #1: move is a member function of the base cloud class Cloud<ParticleType>, which is templated on particle type, see:
http://foam.sourceforge.net/docs/cpp...ce.html#l00181
You might try to define cloud as an object of Cloud<passiveParticle> and then try to call the move function.
Hope it helps,
Francesco
francesco_capuano is offline   Reply With Quote
Old   February 10, 2012, 04:03
Default template class TrackingData
Bernhard Grieser
Hi Francesco, thanks for the reply.
My cloud was already defined as a passiveParticleCloud (see previous post). While instantiating, it calls the constructor of Cloud<passiveParticle>. But the member function move(TrackingData&) still cannot be called, probably because I don't know which argument it needs to be fed with. I probably address it the wrong way, since I'm not that familiar with template classes. Here's the move implementation:
template<class ParticleType>
template<class TrackingData>
void Foam::Cloud<ParticleType>::move(TrackingData& td)
    const globalMeshData& pData = polyMesh_.globalData();
    const labelList& processorPatches = pData.processorPatches();
    const labelList& processorPatchIndices = pData.processorPatchIndices();
    const labelList& processorPatchNeighbours =
        pData.processorPatchNeighbours();
    // Initialise the setpFraction moved for the particles
    forAllIter(typename Cloud<ParticleType>, *this, pIter)
        pIter().stepFraction() = 0;
    // Assume there will be particles to transfer
    bool transfered = true;
    // While there are particles to transfer
    while (transfered)
        // List of lists of particles to be transfered for all the processor
        // patches
        List<IDLList<ParticleType> > transferList(processorPatches.size());
        // Loop over all particles
            ParticleType& p = pIter();
            // Move the particle
            bool keepParticle = p.move(td);
            // If the particle is to be kept
            // (i.e. it hasn't passed through an inlet or outlet)
            if (keepParticle)
                // If we are running in parallel and the particle is on a
                // boundary face
                if (Pstream::parRun() && p.facei_ >= pMesh().nInternalFaces())
                    label patchi = pMesh().boundaryMesh().whichPatch(p.facei_);
                    label n = processorPatchIndices[patchi];
                    // ... and the face is on a processor patch
                    // prepare it for transfer
                    if (n != -1)
                        p.prepareForParallelTransfer(patchi, td);
                        transferList[n].append(this->remove(&p));
            else
                deleteParticle(p);
        if (Pstream::parRun())
            // List of the numbers of particles to be transfered across the
            // processor patches
            labelList nsTransPs(transferList.size());
            forAll(transferList, i)
                nsTransPs[i] = transferList[i].size();
            // processor patches for all the processors
            labelListList allNTrans(Pstream::nProcs());
            allNTrans[Pstream::myProcNo()] = nsTransPs;
            combineReduce(allNTrans, combineNsTransPs());
            transfered = false;
            forAll(allNTrans, i)
                forAll(allNTrans[i], j)
                    if (allNTrans[i][j])
                        transfered = true;
                        break;
            if (!transfered)
                break;
                if (transferList[i].size())
                    OPstream particleStream
                        Pstream::blocking,
                        refCast<const processorPolyPatch>
                            pMesh().boundaryMesh()[processorPatches[i]]
                        ).neighbProcNo()
                    particleStream << transferList[i];
            forAll(processorPatches, i)
                label patchi = processorPatches[i];
                const processorPolyPatch& procPatch =
                    (pMesh().boundaryMesh()[patchi]);
                label neighbProci =
                    procPatch.neighbProcNo() - Pstream::masterNo();
                label neighbProcPatchi = processorPatchNeighbours[patchi];
                label nRecPs = allNTrans[neighbProci][neighbProcPatchi];
                if (nRecPs)
                    IPstream particleStream
                        Pstream::blocking,
                    IDLList<ParticleType> newParticles
                        particleStream,
                        typename ParticleType::iNew(*this)
                    forAllIter
                        newParticles,
                        newpIter
                        ParticleType& newp = newpIter();
                        newp.correctAfterParallelTransfer(patchi, td);
                        addParticle(newParticles.remove(&newp));
        else
            transfered = false;
How can I interpret the TrackingData template? Since move expects its argument to be of Type TrackingData, which tracking data are valid, then?
Thanks
nixiaonan likes this.
Old   February 10, 2012, 09:21
Francesco Capuano
Maybe you already know it, anyway the following reference could be useful:
http://www.tfd.chalmers.se/~hani/kur...LPT_120911.pdf
Cheers,
Francesco
calim_cfd likes this.
Old   February 10, 2012, 10:50
Michael Bruckner
Hi guys,
thanks for addressing the problem.
I've kept trying so far to use what is already implemented in the code and it really looks like that there are tons of material to deal with. ( Because I'm horrible at C++ coding... )
Unfortunately, I can't figure out what are meaning all the parameters available in a "kinematicCloudProperties" file.
I thought that I could specify a very low particle density leading me to a very small Stokes number therefore implying near to massless fluid particle tracking.
So until now, I've been playing around with the tutorials/lagrangian/icoLagrangianFoam/channelParticles of OpenFOAM-1.6-ext. Only three particles are injected at t=0, but are not moving unless I activate the gravity. Particles are then just settling downwards.
Here is my "kinematicCloudProperties" file :
| \\      /  F ield         | OpenFOAM Extend Project: Open Source CFD        |
|  \\    /   O peration     | Version:  1.6-ext                               |
|   \\  /    A nd           | Web:      www.extend-project.de                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      kinematicCloud1Properties;
active          yes;
InjectionModel  ManualInjection;
DragModel       none;
DispersionModel none;
PatchInteractionModel StandardWallInteraction;
PostProcessingModel none;
coupled         true;
cellValueSourceCorrection on;
parcelTypeId    2;
constantProperties
    rhoMin          rhoMin [ 1 -3 0 0 0 ] 1e-15;
    minParticleMass minParticleMass [ 1 0 0 0 0 ] 1e-15;
    rho0            rho0 [ 1 -3 0 0 0 ] 5000;
interpolationSchemes
    rho             cell;
    U               cellPoint;
    mu              cell;
integrationSchemes
    U               Euler;
particleForces
    gravity         off;
    virtualMass     off;
    pressureGradient off;
ManualInjectionCoeffs
    massTotal       massTotal [ 1 0 0 0 0 ] 0.0002;
    parcelBasisType mass;
    SOI             0;
    positionsFile   "kinematicCloudPositions";
    U0              ( 0 0 0 );
    parcelPDF
        pdfType         RosinRammler;
        RosinRammlerPDF
            minValue        5e-05;
            maxValue        0.0001;
            d               ( 7.5e-05 );
            n               ( 0.5 );
ConeInjectionCoeffs
    SOI             0.001;
    duration        0.005;
    position        ( 0.25 0.25 0.05 );
    direction       ( 0 -1 0 );
    parcelsPerSecond 10000;
    volumeFlowRate  Constant 0.01;
    Umag            Constant 50;
    thetaInner      Constant 0;
    thetaOuter      Constant 30;
    parcelPDF
        RosinRammlerPDF
            minValue        5e-05;
            maxValue        0.0001;
            d               ( 7.5e-05 );
            n               ( 0.5 );
StandardWallInteractionCoeffs
    type            rebound;
and the kinematicCloudPosition
FoamFile
    version     2.0;
    format      ascii;
    class       vectorField;
    object      kinematicCloud1Positions;
(0.05 0.025 0.005)
(0.05 0.05 0.005)
(0.05 0.075 0.005)
If nobody can give me an hint here, I think I'll just follow your way Bernhard...
Best,
Michael
Old   February 10, 2012, 10:59
Michael Bruckner
@Bernhard :
We might take advantage of the files associated with the pdf Francesco suggested :
http://www.tfd.chalmers.se/~hani/kur...olver_case.tgz
I'll have a look and keep you updated.
Best,
Michael
Old   February 10, 2012, 12:23
Bernhard Grieser
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD/OF_kurs_LPT_120911.pdf
Cheers,
Francesco
Nice Didn't know that one, thanks!
Still stuck with the problem, though... I'll dive back in the code, then.
Cheers, Bernhard
Old   February 14, 2012, 08:53
Michael Bruckner
Hi Bernhard,
I managed to inject some particles with kinematicCloud classes in the pimpleFoam transient solver. Here's an example with around 5000 particles in a 3D lid-driven cavity. Works fine in parallel too. Tell me if you want me to share.
However, I'm still wondering about the kinematicCloudProperties file, and yet not sure whether I specified correct parameters for massless fluid particles.
The reason I'm doubting is that when I turn off the particleForces, particles aren't moving anymore. And much of the parameters are still very obscure to me.
I'm doubting whether I should start I new thread about the correct use of "kinematicCloudProperties". Would somebody be able to tell us a little bit more about it ?
Cheers,
Michael
Old   February 14, 2012, 11:56
Default passive particle tracking simplistic approach
  #11
Bernhard Grieser
Hi Michael,
looks very promising, I'd like to have a look at your implementation, yes.
Meanwhile I succeeded in implementing my own particle tracking in a very simplistic approach. For my part, I only have a very small amount of tracer particles, so I do not take advantage of the stepwise particle tracking (stepFraction to next face, etc.) which was intended to avoid calling the mesh.findCell(position) for every particle at every timestep, from what I've understood.
Maybe you want to have a look at it:
// my solver C-file:
#include "fvCFD.H"
#include "volMesh.H"
#include "interpolationCellPoint.H"
#include "IFstream.H"
#include "OFstream.H"
int main(int argc, char *argv[])
    #include "setRootCase.H"
    #include "createTime.H"
    #include "createMesh.H"
    #include "createFields.H"
    #include "initContinuityErrs.H"
    // Load particle positions from dictionary
    IOdictionary particlePositionsDict
        IOobject
            "particlePositionsDict",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
    List<vector> particlePositions
        particlePositionsDict.lookup("particlePositions")
    // Initialize List for the interpolated particle velocity and the motion vector deltaX
    labelList particleCell(particlePositions.size());
    List<vector> Uint(particlePositions.size());
    List<vector> deltaX(particlePositions.size());
    // Initialize particleTracks
    std::fstream particleTracks;
    particleTracks.open("particleTracks",std::ios::out | std::ios::app);
    particleTracks << "#Time[s]\t\t";
    forAll(particlePositions, posI)
        Info<< "    Position of particle #" << posI+1 << ": " << particlePositions[posI] << endl;
        particleTracks << "particle" << posI+1 << ".x()\t"
               << "particle" << posI+1 << ".y()\t"
               << "particle" << posI+1 << ".z()\t\t";
    particleTracks << std::endl;
    Info<< "\nStarting time loop\n" << endl;
    while (runTime.loop())
        Info<< "Time = " << runTime.timeName() << nl << endl;
        #include "readPISOControls.H"
        #include "CourantNo.H"
        scalar deltaT = runTime.deltaT().value();
        interpolationCellPoint<vector> UInt_(U);
        particleTracks << runTime.time().value() << "\t\t";
            particleCell[posI] = mesh.findCell(particlePositions[posI]);
            Uint[posI] = UInt_.interpolate(particlePositions[posI], particleCell[posI]);
            deltaX[posI] = Uint[posI]*deltaT;
            particlePositions[posI] += deltaX[posI];
            particleTracks << particlePositions[posI].x() << "\t"
                      << particlePositions[posI].y() << "\t"
                      << particlePositions[posI].z() << "\t\t";
Basically, I create a restartable log file for the particle positions at every timestep ("particleTracks") as well as a restartable dictionary in the respective time folder which contains the particle positions (particlePositionsDict).
The latter one looks like this:
|  \\    /   O peration     | Version:  1.7.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "0";
    object      particlePositionsDict;
particlePositions
    (5e-05 0.0001 0.000993)
    (5e-05 0.0001 0.001013)
Best regards,
Bernhard
Old   February 14, 2012, 13:02
Michael Bruckner
attached is what I've done without any guarantee .
I compiled it under OpenFOAM-2.0.1 and for some reason, it required some libraries that were buried deep into the source code.
I like your implementation since you have a total control of what you're doing. How many particles do you think you could track ? Is there a limitation implied by the format ?
Do you have any idea if this is quicker and more/less accurate than what I've done?
I would be very interested in the results if you do some comparison.
cheers,
Michael
czhao86 likes this.
Old   February 15, 2012, 07:58
Bernhard Grieser
Hi Michael, the flaws of the simplistic approach are: nonparallel simulations only, particleTracks have to be transformed in order to be able to view them in paraview.
Thanks for your files, I'll check them.
Bernhard
Old   April 6, 2014, 07:41
CFDUser
CFDUser_ is on a distinguished road
Cheers,
Francesco
Dear Francesco,
This link is not working. May be it will be useful for me as well. Can you please re-upload.
Thanks
Regards
CFDUser_
CFDUser_ is offline   Reply With Quote
Old   April 6, 2014, 08:24
Retired Super Moderator
Bruno Santos
Quick answer - The current link is this one: http://www.tfd.chalmers.se/~hani/kur...LPT_120911.pdf
CorbinMG likes this.
Old   April 6, 2014, 08:29
CFDUser
Originally Posted by wyldckat View Post
Thanks for very quick and kind reply. Seems it will be very useful for me.
Regards
CFDUser_
Old   December 7, 2014, 05:35
CFDUser
Dear All,
Can somebody post LPTVOF case files Michaelb said about?
@Bernhard :
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD/LPTVOF_solver_case.tgz
Best,
Michael
Thanks & Regards,
CFDUser_
Old   December 8, 2014, 14:09
Bruno Santos
Quick answer: http://www.tfd.chalmers.se/~hani/kur...olver_case.tgz
PS: The course changes links with each new year: http://openfoamwiki.net/index.php/Ha...ource_software
Old   June 15, 2015, 07:19
Default different numbers of particle injection?
  #19
Mamadou Camara
camzis is on a distinguished road
Dear foamers,
I'm currently working with the solver "iconUncoupledKinematicParcelFoam (lagrangian)
I need to inject a different number of particles at each time step.
I'm currently using the model "patchInjection" in the file kinematicCloudProperties.
The problem is, I dont know how to make the number of particels vary.
Is there a way to force the number of particles to vary by wether providing a table (for number of particles vs. time) or as a function?
Any suggestions, ideas are very welcome.
Please, my master thesis depends on this.
camzis is offline   Reply With Quote
Old   August 26, 2015, 04:00
Albrecht vBoetticher
vonboett is on a distinguished road
Hi Mamadou,
Did you find something? I am stuck at the same place. I implemented a write-out control such that I can write the particle position in a higher frequency than the fluid field variables, and I would start to implement the same for reading in from particlePosition files at predefined times- but I am shure someone has solved this before!
vonboett is offline   Reply With Quote
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump scatman CFX 7 January 8, 2018 01:59
Lagrangian Particle Tracking Initial step Bruce Hartley OpenFOAM Programming & Development 4 September 2, 2015 06:32
Lagrangian particle tracking skabilan OpenFOAM Running, Solving & CFD 7 July 15, 2014 13:40
Particle tracking without "Particle interaction with continuous phase" Peter023 Fluent UDF and Scheme Programming 0 November 30, 2011 10:08
cod for lagrangian particle tracking mazdak Main CFD Forum 2 December 29, 2009 03:53
