melting problem: looking for appropriate solvers
Like Tree186Likes
Old   January 16, 2014, 12:14
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Concerning your dimension problem, if you take a look at for ex. EulerDdtScheme.C, definition for fvc::ddt is
EulerDdtScheme<Type>::fvcDdt
    const volScalarField& rho,
    const GeometricField<Type, fvPatchField, volMesh>& vf
    else
        return tmp<GeometricField<Type, fvPatchField, volMesh> >
            new GeometricField<Type, fvPatchField, volMesh>
                ddtIOobject,
                rDeltaT*(rho*vf - rho.oldTime()*vf.oldTime())
in your case rho is cp, while for fvm::ddt is
template<class Type>
tmp<fvMatrix<Type> >
EulerDdtScheme<Type>::fvmDdt
        fvm.source() = rDeltaT
            *rho.oldTime().internalField()
            *vf.oldTime().internalField()*mesh().V();
Guess it's where dimensions difference comes from.
About radiation term addition:
Can't you just write it like:
cp*radiation->Sh(thermo)
as you enthalpy equation is basically temperature equation times specific heat?
alexeym is offline   Reply With Quote
Old   January 17, 2014, 07:11
dzi
dzi is on a distinguished road
thank you alexeym, for your hints!
Originally Posted by alexeym View Post
-> that is also what I thought.
To test the way via another variable, in buoyantSimpleRadiationFoam i defined
Foam::fvScalarMatrix fsm_radiationSource =  radiation->Sh(thermo) ;
and in the solver hEqn.H
  fvScalarMatrix hEqn
        fvm::div(phi, h)
      - fvm::Sp(fvc::div(phi), h)
      - fvm::laplacian(turbulence->alphaEff(), h)
      - fvc::div(phi, 0.5*magSqr(U), "div(phi,K)")
      + fsm_radiationSource
which works.
but when I use radiation in melt solver in similar way:
    Foam::fvScalarMatrix fsm_radiationSource =  radiation->Sh(thermo);
    fvScalarMatrix hEqn
        fvm::ddt(cp, T)
      + fvm::div(phi*fvc::interpolate(cp), T)
      + hs*exp(-pow((T-Tmelt)/Tdim,2))/Foam::sqrt(constant::mathematical::pi)/Tdim*fvm::ddt(T)
      + hs*exp(-pow((T-Tmelt)/Tdim,2))/Foam::sqrt(constant::mathematical::pi)/Tdim*(U & fvc::grad(T))
      - fvm::laplacian(lambda/rho, T)
      +  cp*fsm_radiationSource
it runs into this (dimension? field?) error
--> FOAM FATAL ERROR:
incompatible fields for operation
    [T] + [h]
    From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&)
    in file /opt/openfoam211/src/finiteVolume/lnInclude/fvMatrix.C at line 1303.
FOAM aborting
thanks again, i think i will try something else...
dzi is offline   Reply With Quote
Old   January 27, 2014, 08:36
Robert mellema
Dostoyefsky is on a distinguished road
Hello everyone,
I am trying to include species eqn to the enthalpy porosity solver and I want to add a loop in case of 0 < alpha < 1 (by using if statement?).
Since I am new to openfoam, I don't know how to do it.
Can somebody help me? Thanks in advance
Robert
Kummi likes this.
Dostoyefsky is offline   Reply With Quote
Old   January 27, 2014, 09:58
Mohammad Shakil Ahmmed
ahmmedshakil is on a distinguished road
Would please write down the species equation and condition you want to impose?
ahmmedshakil is offline   Reply With Quote
Old   January 27, 2014, 10:14
Robert mellema
Well, actually I am using solver created by Mr. Fabian Roesler (convMeltFoam).
After solving the energy equation, I want to calculate the equilibrium concentration at the interface (0<alpha1<1) by using phase diagram.
Would you give me some advice please?
Regards
Robert
Kummi likes this.
Old   January 30, 2014, 11:52
Thomas Vossel
ThomasV is on a distinguished road
Hi!
I'd like to ask for advice for a solver problem of mine. I'm looking into an alloy phase change problem and ran into some problems with the energy equation. What works so far is this:
   fvScalarMatrix TEqn
        sensibleH * fvm::ddt(Temp)
      + fvm::div(phiMix * fvc::interpolate(sensibleH), Temp, "div(phib*specificH,Temp)")
      - fvm::laplacian(lambda / rhob, Temp, "laplacian(lambda|rhob,Temp)")
      - Lb * deltaFracSol / oldTimestep
This gives me the graph I want as can be seen here with nice primary and eutectic solidification:
The problem now is that the above simulation was done for a single cell. When doing simulations with multiple cells and convection this won't work and give strange results. So one has to use a source term just like the first to lines of code with a time derivation and a divergence. I'll leave convection aside for now and do this:
   fvScalarMatrix TEqn
      + Lb * deltaFracSol / temperatureChange * fvm::ddt(Temp)
This unfortunately gives me this result I also had presented in an early post of mine:
Primary and eutectic solidification sort of exist but the entire recalescence aspect is gone...
I now would like to know if you have any suggestions as to what I should do or give advice as to why the second result is so different. By design both should be the same equation as one might say:
fvm::ddt(Temp) = \frac{\partial T}{\partial t} = \frac{\Delta T}{\Delta t} = \frac{temperatureChange}{oldTimestep} \quad \Rightarrow \frac{L \cdot \Delta f_s}{\Delta T} \cdot \frac{\Delta T}{\Delta t} = \frac{L \cdot \Delta f_s}{\Delta t}
So the source term expression for both approaches should be pretty much the same or am I mistaken here? Another difference is the sign of the source term one has to add or subtract depending on which variant is used (EDIT: This is ok though as I simply defined my temperatureChange field the other way round.)...
Does anyone have an idea what is wrong with the approach with OpenFOAM's fvm::ddt(Temp) and why the temperature won't rise but stay the same?
shuisheng likes this.
ThomasV is offline   Reply With Quote
Old   February 19, 2014, 08:10
Default melting/solidification with temperature dependent thermo-properties
  #107
Has anyone working with melting/solidification modelling considering temperature dependent thermo physical properties (i.e. Cp = Cp(T), K=K(T)) ?
Please give some advice how to deal with this type of problem ? I have used the source based enthalpy method as Fabian, but the problem happens when I make thermophysical properties as variable
Thanks in advance
Old   February 19, 2014, 08:33
Anja Miehe
AnjaMiehe is on a distinguished road
Hello Shakil,
I am so sorry, I almost forgot about you. At present, I am writing my things together for my PhD and my contract is running out, so I am bit blinkered.
For the implementation of temperature dependent thermophysical properties in general, please take a look here:
http://www.cfd-online.com/Forums/ope...ies-false.html
Then, going on from post #56, use the interpolation procedure within the do-loop. When you implement it, start with the thermophysical post and get that one to run. After that, if you go for solidification / melting with dependent properties, start with a weak dependence and build up from there.
I am going to publish my code as soon as I have my PhD ready, but that might take some months.
Best Regards, Anja
AnjaMiehe is offline   Reply With Quote
Old   February 26, 2014, 02:23
Default Anybody can help me?when I compile meltFoam with wmake command,i face a problem.
  #109
wumin
wumin is on a distinguished road
Anybody can help me?when I compile meltFoam with wmake command,i face a problem about compiling meltFoam:
fuguang@fuguang-Veriton-D630:~/Downloads/meltFoam_solver$ wmake
SOURCE=meltFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam230/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/meltFoam.o
In file included from meltFoam.C:83:0:
pEqn.H: In function ‘int main(int, char**)’:
pEqn.H:8:11: error: ‘ddtPhiCorr’ is not a member of ‘Foam::fvc’
/opt/openfoam230/src/finiteVolume/lnInclude/readTimeControls.H:38:8: warning: unused variable ‘maxDeltaT’ [-Wunused-variable]
make: *** [Make/linux64GccDPOpt/meltFoam.o] Error 1
wumin is offline   Reply With Quote
Old   February 26, 2014, 03:40
Default Version mismatch
  #110
Fabian Roesler
fabian_roesler is on a distinguished road
Hi wumin
This sounds to me like a version mismatch. Which OpenFOAM version do you use? I bet you use OpenFOAM 2.3.x since the ddtPhiCorr in pEqn was changed to a more general ddtCorr. Have a look into other pEqn of standard solvers in OF and check for differences
Regards
Fabian
fabian_roesler is offline   Reply With Quote
Old   February 26, 2014, 08:13
wumin
Hi Fabian,
thanks for your reply.You are right! The version I now use is OpenFoam-2.3.0.
My work is mainly to simulate the melting and solidification of selective laser melting(3D printing).
I want to compile the meltFoam,but always fail.Can you tell me how to deal with the problem?
the system I install is ubuntu 12.04.
Old   February 28, 2014, 02:57
Hi Wumin,
Have tried with the meltFoam version provided by Fabian in post#19 (http://www.cfd-online.com/Forums/ope...g-problem.html) ?
Old   March 6, 2014, 04:35
Default Enthalpy linearization
  #113
Rohith
RaghavendraRohith is on a distinguished road
Hi
I have been working on the melting problem for one month and more. I am using the solver from Fabian as a test bed to implement the enthalpy linearization. while in this method, it is a bit complex to implement it in OpenFOAM. Somebody has gone through this method in the past?
Best Regards
Rohith
RaghavendraRohith is offline   Reply With Quote
Old   March 6, 2014, 07:36
Hi RaghavendraRohith,
It sounds cool that someone also trying with the enthalpy linearization method. I'm using linearization method based on Voller's source based method i.e. linearization of the \frac{d\gamma}{dt} term. I have also validated my case with the gallium melting and the results are cool! But now stuck with different types of problem...
#shakil
Old   March 6, 2014, 07:42
Rohith
Hi Shakil
Actually I am not asking for source based method
Please go through it, let me know your idea if so.
Regards
Rohith
Old   March 8, 2014, 03:31
Default a wmake problem
  #116
houwy
houwy is on a distinguished road
Originally Posted by fabian_roesler View Post
Hi all
I posted that it might take some time to review the meltFoam solver and port it from OF_1.7 to OF_2.1 but I felt like doing it instantly. So here you go . I hope you enjoy it.
Regards
Fabian
Hello! Fabian
I have some problem to wmake meltFoam on OF2.2.0. Can you help me to solve this problem. I'm a new user and I want to know if I can use this Foam to simulate a solid particle dissolution in liquid.
Thanks very much!
Making dependency list for source file meltFoam.C
SOURCE=meltFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam220/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/meltFoam.o
/opt/openfoam220/src/finiteVolume/lnInclude/readTimeControls.H: In function ‘int main(int, char**)’:
/opt/openfoam220/src/finiteVolume/lnInclude/readTimeControls.H:38:8: warning: unused variable ‘maxDeltaT’ [-Wunused-variable]
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam220/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/meltFoam.o -L/opt/openfoam220/platforms/linux64GccDPOpt/lib \
-lfiniteVolume -lOpenFOAM -ldl -lm -o /home/hwy/OpenFOAM/hwy-2.2.0/platforms/linux64GccDPOpt/bin/meltFoam
houwy is offline   Reply With Quote
Old   March 8, 2014, 03:34
houwy
hello! Have your problem been solved?
Old   March 8, 2014, 04:05
Rohith
Hello Houwy
This is not fabian, but i can help you in this aspect
I do not see what actually is your problem, the solver is compiled now and may be you can simulate your case, yes meltFoam is a solver to solve melting of a solid particle or a solid body.
Go forward with your simulation once
Regards
Rohith
Old   April 9, 2014, 04:56
Default Solver Update Fabian Rösler OF2.3.0
  #119
Anja Miehe
Hello everyone,
here is Fabians convMeltFoam solver of post #81 for you compiling in OpenFOAM 2.3.0 with the test case, as one boundary condition for the pressure changed its name. Have fun using it.
Regards, Anja
Old   April 17, 2014, 03:59
Default help
  #120
Zhipeng Zhou
zhouzhipeng77 is on a distinguished road
Hi all
Regards
Fabian
Fabian.Thank you for your solver about melting.But I have some questions with your solver. In the UEqn.H , you use a symbol "DC" calculated form DCl,DCs and alpha. Can you explain what are their meanings ? And can you give me your mathematical model?
zhouzhipeng77 is offline   Reply With Quote
melting openfoam
Melting and solidification with free surface problem? cqlwj123 CFX 6 July 25, 2013 03:46
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 06:29
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Melting Problem M FLUENT 0 April 29, 2007 17:07
