nonzero boundary conditions in attachDetachFvMesh |
October 25, 2010, 08:16 |
#1 | ||
Patricia
Rep Power: 16 |
I am asking for help about the setup of a driven cavity example, where at certain trigger times an internal barrier is attached. The wall velocity of the barrier is opposite to the lid movement, so that I expect one clockwise convection cell and one counterclockwise.
Instead the result (see attached screenshot) shows only convection above the barrier, which is located at half the vertical extent. The lower half is not circulating. The following entries in 0/U specify U=(-1,0,0) at the barrier (patches "attachTop","attachBottom"). Why is this velocity not reached in the solution? Quote:
Patricia |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 13:58 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 10:38 |
Pressure boundary conditions | Lionel S. | Main CFD Forum | 1 | August 24, 2007 19:03 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 19:29 |
