how to set up wall function in bubbleFoam
Old   October 17, 2010, 04:05
Default how to set up wall function in bubbleFoam
trister
adouchihiitoko is on a distinguished road
Hi
I try to calculate turbulent bubbly flow by bubbleFoam. I don't know how to set up wall function in k and epsilon file in 0 folder since "bubbleColumn" tutorial doesn't treat turbulent flow and wall function. I suppose that "zeroGradient" is unreasonable. Can anyone help me?
adouchihiitoko is offline   Reply With Quote
Old   October 18, 2010, 15:51
Alberto Passalacqua
Please, check the code. Wall-functions in bubbleFoam are coded directly in the solver and automatically applied when the turbulence model is active.
Best,
Alberto Passalacqua
Old   October 24, 2010, 05:16
trister
Thanks.
I found all files related turbulence e.g. wallfunctions.* are in \applications\solvers\multiohase\bubbleFoam.
Old   November 4, 2010, 08:18
Franz Jacobsen
Franz_J is on a distinguished road
Hi Adouchihihiitoko
Did you manage to get bubbleFoam to solve with turbulence as the RASModel ? I get the following messages,
keyword laplacian(DepsilonEff,epsilon) is undefined in dictionary "/home/f/OpenFOAM/f-1.7.0/working2/sludge2D/test2/system/fvSchemes::laplacianSchemes"
file: /home/f/OpenFOAM/f-1.7.0/working2/test2/system/fvSchemes::laplacianSchemes from line 42 to line 45.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 395.
Franz_J is offline   Reply With Quote
Old   November 4, 2010, 08:57
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Just add the entry into system/fvSchemes, and be careful using the turbulence model, it's very basic! Remember it's not using the turbulence libraries that can be used for single phase flows, so the only entry it uses in the RAS dictionary is turbulence on/off.
If you look in kEpsilon.H:
    // Dissipation equation
    fvScalarMatrix epsEqn
        fvm::ddt(beta, epsilon)
      + fvm::div(phib, epsilon)
      - fvm::laplacian
            alphaEps*nuEffb, epsilon,
            "laplacian(DepsilonEff,epsilon)"
         C1*beta*G*epsilon/k
       - fvm::Sp(C2*beta*epsilon/k, epsilon)
You can see that for the laplacian discretisation the scheme is looked up in the fvSchemes dictionary.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   November 5, 2010, 06:59
Franz Jacobsen
thanks Laurence
I did that and it's working. Now I'm running some test cases and it crashes after abut 50 time steps, Ur Courant number tends to diverge, but I can fiddle with it,
thanks again
Pneumatic simulation - moving wall as a function of a pressure difference jbmackay OpenFOAM 0 September 22, 2010 16:51
Wall function formulation in CFX and Fluent gravis ANSYS 0 May 4, 2010 12:03
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
Wall function problem in Fluent mefpz FLUENT 1 October 10, 2007 14:43
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
