Can we restart the simulation from a different time in OpenFoam
Like Tree17Likes
Old   May 20, 2016, 17:08
Default how iteration number is calculated in steady state calculation?
  #21
Jeff
jf_vt is on a distinguished road
Hi Foamers
this is quite a silly question but I am at loss:
If I run a simulation with a simple algorithm with:
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 1000;
deltaT 1;
the log file state as expected that it will run for 1000 iterations ( no convergence criteria)
When I continue the simulation ( after remapping on a finer mesh)
startTime 1000;
stopAt endTime;
endTime 2000;
deltaT 1;
The log file then report that it will run for 2000 iterations while 1000 will be expected.
what do i miss?
Thanks
JF
jf_vt is offline   Reply With Quote
Old   May 20, 2016, 18:06
Matthias
aeroMatze is on a distinguished road
sorry, my reply was nonsense
aeroMatze is offline   Reply With Quote
Old   May 21, 2016, 19:09
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
@jf_vt
Since your message lacks exact OpenFOAM message, I suppose it is something like:
SIMPLE: no convergence criteria found. Calculations will run for 2000  steps.
And it is a result of not quite precise wording in simpleControl class constructor:
if (residualControl_.empty())
    Info<< algorithmName_ << ": no convergence criteria found. "
        << "Calculations will run for " << mesh_.time().endTime().value()
        << " steps." << nl << endl;
Since your endTime is 2000, message says that it will run for 2000 steps.
Maybe it is worth reporting bug (http://bugs.openfoam.org), since for SIMPLE mesh_.time().endTime().value() can be changed to mesh_.time().endTime().value() - mesh_.time().startTime().value().
Yet simpleFoam simulations without convergence criterion is something ridiculous.
alexeym is offline   Reply With Quote
Old   May 21, 2016, 19:21
Jeff
Thanks
Sorry for the lack of accuracy in my message (As you can easily guess I am pretty new to the forum) but you get it right of course..
As for interrest running simple without convergence algorithm, I agree with you in general but at the moment I am investigating convergence speed while inserting remeshing and field mapping in the process ( this is research not sure where it leads) but in a simplified form:
I run a cas for 1000 step remesh it finer, map fields and run it for another 1000 step ... and so forth... and compare solution quality vs cputime if i run on the finer mesh all the time.
I dont need convergence test for that and this is why I stumbled on this and found it annoying in the context of the work described above.
I reported it as a (small) bug
Thanks for your reply
JF
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
(chtMultiRegionFoam) reducing gravity increase the simulation time ! openfoam1 OpenFOAM 7 March 10, 2010 10:41
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 10:15
influence of time step in insationary simulation Sascha Behrens FLUENT 0 December 1, 2005 10:08
