Improve simpleFoam convergence
Like Tree8Likes
Old   November 5, 2010, 17:04
Daniele
Daniele111 is on a distinguished road
Thanks you Martin, it works fine. I'll go to Germany and I'll offer you a good beer! Do you get correct syntax also for turbolent case this time in the code? For single core I wrote code coping it from OpenFoam utility.
Daniele
Daniele111 is offline   Reply With Quote
Old   November 5, 2010, 18:15
Martin
MartinB will become famous soon enough
Beer is fine
If you need more data to be written, just post your single core code, I'll have a look at it. I don't use turbulence for my simulations here, so I'm not sure if it will work with turbulent flow. But if you can provide a simple test case for simpleFoam we can check it...
See you in Germany
Martin
MartinB is offline   Reply With Quote
Old   November 6, 2010, 10:02
Daniele
I changed fot single core your old code in this way:
#include "RASModel.H"
// write matlab file
Info << "Writing wall shear stress for matlab" << endl;
word wallPatchName = "bottom";
Info << "Searching for patch " << wallPatchName << endl;
// Check, if the patch name exists:
label patchID = mesh.boundaryMesh().findPatchID(wallPatchName);
if (patchID < 0)
Info << "No patch found with name \"" << wallPatchName << "\"!"
<< endl;
else
/* for laminar case:
Info<< "Reading viscosity nu\n" << endl;
dimensionedScalar nu_
laminarTransport.lookup("nu")
// calculating wall shear rate
#include "createFields2.H"
mesh.readUpdate();
volSymmTensorField Reff(RASModel->devReff());
volVectorField tau
IOobject
"tau",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh,
dimensionedVector
"tau",
Reff.dimensions(),
vector::zero
forAll(tau.boundaryField(), patchi)
tau.boundaryField()[patchi] =
-mesh.Sf().boundaryField()[patchi]
/mesh.magSf().boundaryField()[patchi]
) & Reff.boundaryField()[patchi];
// Pointer to the patch we want to have shear stress for:
const polyPatch& cPatch = mesh.boundaryMesh()[patchID];
label nFaces = cPatch.size();
pointField faceCenterCoords(nFaces, vector(0,0,0));
pointField faceAreas(nFaces, vector(0,0,0));
pointField wallShearStress(nFaces, vector(0,0,0));
label runFaces = 0;
// collecting the interesting data
for (int i=0; i<nFaces; i++)
faceCenterCoords[runFaces] = mesh.Cf().boundaryField()[patchID][i];
faceAreas[runFaces] = mesh.Sf().boundaryField()[patchID][i];
wallShearStress[runFaces] = tau.boundaryField()[patchID][i];
runFaces++;
// make a cute filename
fileName casePath = cwd();//casePath.name();
fileName caseName = casePath.name();
fileName myFile = "tau.dat";
Info << "Data is written to file " << myFile << endl;
// create a new file
OFstream *myStream = NULL;
myStream = new OFstream(myFile);
*myStream << i << " "
// coordinates on face centers:
<< mesh.Cf().boundaryField()[patchID][i].component(0) << " "
<< mesh.Cf().boundaryField()[patchID][i].component(1) << " "
<< mesh.Cf().boundaryField()[patchID][i].component(2) << " "
// wall shear stress as a vector:
<< tau.boundaryField()[patchID][i].component(0) << " "
<< tau.boundaryField()[patchID][i].component(1) << " "
<< tau.boundaryField()[patchID][i].component(2) << " "
// magnitude of wall shear stress:
<< mag(tau.boundaryField()[patchID][i]) << endl;
Old   November 6, 2010, 12:50
Martin
I merged your version and my parallel one, so can you try this:
    Info << "Writing wall shear stress for matlab!" << endl;
    if (patchID < 0)
             << endl;
    else
        // calculating tau
#       include "createFields2.H"
        mesh.readUpdate();
        volVectorField tau
            IOobject
                "tau",
                runTime.timeName(),
                mesh,
                IOobject::NO_READ,
            mesh,
            dimensionedVector
                "tau",
                Reff.dimensions(),
                vector::zero
        label runFaces = 0;
            runFaces++;
        // for parallel
        reduce(nFaces, sumOp<label>());
        Info << "Number of global faces: " << nFaces << endl;
        if (Pstream::master())
        // slaves send data to master, master writes data to file
        if (Pstream::parRun())
            if (Pstream::myProcNo() != Pstream::masterNo())
                OPstream toMaster(Pstream::blocking, Pstream::masterNo());
                toMaster << faceCenterCoords;
                toMaster << faceAreas;
                toMaster << wallShearStress;
            else // master part
                // first write own data
                for (int i=0; i<faceCenterCoords.size(); i++)
                    *myStream << i << ";"
                        << faceCenterCoords[i].component(0) << "; "
                        << faceCenterCoords[i].component(1) << "; "
                        << faceCenterCoords[i].component(2) << "; "
                        << wallShearStress[i].component(0) << "; "
                        << wallShearStress[i].component(1) << "; "
                        << wallShearStress[i].component(2) << "; "
                        << mag(wallShearStress[i]) << endl;
                label run = faceCenterCoords.size();
                // then receive slave data and write
                pointField bufferFaceCenterCoords;
                pointField bufferFaceAreas;
                pointField bufferWallShearStress;
                for (int slave=Pstream::firstSlave(); slave <= Pstream::lastSlave(); slave++)
                    IPstream fromSlave(Pstream::blocking, slave);
                    fromSlave >> bufferFaceCenterCoords;
                    fromSlave >> bufferFaceAreas;
                    fromSlave >> bufferWallShearStress;
                    for (int i=0; i<bufferFaceCenterCoords.size(); i++)
                        *myStream << run << ";"
                            << bufferFaceCenterCoords[i].component(0) << "; "
                            << bufferFaceCenterCoords[i].component(1) << "; "
                            << bufferFaceCenterCoords[i].component(2) << "; "
                            << bufferWallShearStress[i].component(0) << "; "
                            << bufferWallShearStress[i].component(1) << "; "
                            << bufferWallShearStress[i].component(2) << "; "
                            << mag(bufferWallShearStress[i]) << endl;
                        run++;
        else // single processor only
                *myStream << i << "; "
                        << mesh.Cf().boundaryField()[patchID][i].component(0) << "; "
                        << mesh.Cf().boundaryField()[patchID][i].component(1) << "; "
                        << mesh.Cf().boundaryField()[patchID][i].component(2) << "; "
                        << tau.boundaryField()[patchID][i].component(0) << "; "
                        << tau.boundaryField()[patchID][i].component(1) << "; "
                        << tau.boundaryField()[patchID][i].component(2) << "; "
Martin
Convergence Problems SimpleFOAM Kutti OpenFOAM 16 June 14, 2010 09:12
Getting faster convergence in simpleFoam basneb OpenFOAM 8 February 9, 2010 05:20
Definition of convergence criterion in simpleFoam titio OpenFOAM Running, Solving & CFD 1 February 6, 2010 02:34
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
to improve convergence Mohamed FLUENT 0 May 14, 2003 06:43
