GGI bug??
Old   April 25, 2010, 01:39
Default GGI bug??
Pavan
rieuk is on a distinguished road
Hey guys, a couple of things firstly,
does moveDynamicMesh work with GGI? Not working for me. Output is:
[pab565@vayu1 pitchEllipse4]$ moveDynamicMesh
|  \\    /   O peration     | Version:  1.5-dev                               |
|   \\  /    A nd           | Revision: 1669                                  |
|    \\/     M anipulation  | Web:      http://www.OpenFOAM.org               |
Exec   : moveDynamicMesh
Date   : Apr 25 2010
Time   : 14:31:01
Host   : vayu1
PID    : 6875
Case   : /short/g75/Pavan_FYP/pitchEllipse4
nProcs : 1
Create time
Create dynamic mesh for time = 0
Selecting dynamicFvMesh mixerGgiFvMesh
void mixerGgiFvMesh::addZonesAndModifiers() : Zones and modifiers already present.  Skipping.
Mixer mesh:
    origin: (0 0 0)
    axis  : (0 0 1)
    rpm   : 1
--> FOAM Warning :
    From function dlLibraryTable::open(const dictionary& dict, const word& libsEntry, const TablePtr tablePtr)
    in file lnInclude/dlLibraryTableTemplates.C at line 68
    library "libsampling.so" did not introduce any new entries
Creating ggi check
Time = 0.002
Clear VTK directory
Initializing the GGI interpolator between master/shadow patches: insideSlider/outsideSlider
Evaluation of GGI weighting factors:
  Largest slave weighting factor correction : 2.22045e-16 average: 7.51536e-17
  Largest master weighting factor correction: 2.66454e-15 average: 1.34081e-16
volume continuity errors : volume = 2.62147e-05, max error = 6.07437e-12, sum local = 1.78474e-15, global = -1.30073e-17
ExecutionTime = 0.2 s  ClockTime = 0 s
    request for surfaceScalarField phi from objectRegistry region0 failed
    available objects of type surfaceScalarField are
2
weightingFactors
meshPhi
    From function objectRegistry::lookupObject<Type>(const word&) const
    in file /home/565/pab565/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 142.
FOAM aborting
Abort
Secondly, I'm trying to use sinusoidal rotation and to this end I add this line in the bool Foam::mixerGgiFvMesh::update() function of the mixerGgiFvMesh.C file in the mixerGgiFvMesh folder:
rpm_=10/9*pi*cos(pi/6*time().value());
Upon compiling, this works fine and rotates my mesh sinusoidally as expected - HOWEVER when I change this line to:
rpm_=5/9*pi*cos(pi/6*time().value());
and compile, the code solves and everything, says it's doing the GGI interpolation and all - but the mesh does not move at all. What the???
rieuk is offline   Reply With Quote
Old   April 25, 2010, 06:24
Henrik Rusche
henrik is on a distinguished road
Dear rieuk,
a) Try switching off the ggiCheck function object.
b) You may be a victim of implicit conversion. Try:
rpm_=5.0/9.0*pi*cos(pi/6.0*time().value());
Best Regards,
Henrik
henrik is offline   Reply With Quote
Old   April 25, 2010, 11:47
Pavan
Solved and solved. Cheers, Henrik! And sorry about crying wolf in the thread topic
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 22:51
Difference between ggi and overlapGgi? GGI Tips and Tricks? philippose OpenFOAM Running, Solving & CFD 7 January 16, 2013 10:40
Performance of GGI case in parallel hannes OpenFOAM Running, Solving & CFD 26 August 3, 2011 04:07
BCs for parallel ggi NickG OpenFOAM 1 March 15, 2010 12:12
CFX GGI Interface Error (non-overlapping) surge519 CFX 1 August 3, 2009 19:54
