The cavity Tutorial
Old   August 2, 2009, 11:56
Smile The cavity Tutorial
Ahmed
Ahmed is on a distinguished road
Being new to OpenFOAM, I tried the first tutorial, i.e., the cavity problem, a classic case found on most CFD solvers's tutorials, I tried to see how accurate is the solution obtained by OF, the initial mesh distribution is 20x20x1. I increased the mesh resolution to 40x40x1, 80x80x1 and 160x160x1. In each case I plotted both the pressure and U velocity magnitude. here they are
The only remark I can make is that the maximum/minimum pressure values double each time the mesh resolution is doubled.
A couple of questions come to my mind
1- Will I ever get a solution independent of the mesh resolution
2- How small should I go to reach that solution
Am I missing something?
N.B. The time step has been decreased in each case to maintain a courant number less than 1
Ahmed is offline   Reply With Quote
Urgent: Unsteady 3-D supersonic cavity flow Min-Sung Kang FLUENT 3 April 6, 2014 10:50
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 06:34
[OpenFOAM] Cavity tutorial visualization failure jabowery ParaView 6 March 7, 2007 00:40
[OpenFOAM] HI all I cant find display button in paraview when i execute cavity tutorial there is only parameter button in the paraview chan ParaView 2 February 13, 2006 08:37
Canbt run the tutorial cavity fengxs OpenFOAM Installation 4 May 10, 2005 14:18
