How to set up the velocity in the let boudary changing with time. |
June 3, 2009, 11:23 |
xinguang cui
Rep Power: 17 |
Hey Foamers:
I wish all of you have a nice day. I need to simulate a case that the velocity in the inlet changes with the time. How do I set up it ? Is there existed solver or text that could be referenced by me? Thanks and best wishes! |
June 3, 2009, 11:57 |
Leonardo Giampani Morita
Rep Power: 17 |
I've not used it yet, but it seems that timeVaryingMappedFixedValue can be useful for you. Regards, Leonardo |
June 3, 2009, 12:11 |
Niels Gjoel Jacobsen
Rep Power: 37 |
And if the time variation can be specified by a mathematical expression you would benefit from groovyBC (just search the forum).
Best regards, Niels |
June 3, 2009, 12:25 |
xinguang cui
Rep Power: 17 |
Thanks a lot to eonardo and Niels. I will try it.
June 4, 2009, 13:08 |
xinguang cui
Rep Power: 17 |
Hey Leonardo:
I have read the thread, but it is very sad that I know few thing about "timeVaryingMappedFixedValue". Is it a utility? How do I use it? And how could I generate the value for different time step? Thanks and Best wishes! |
June 4, 2009, 16:59 |
Rep Power: 17 |
Well, I know it's not extensively documented, but you can search for more info here in the forum. Try the keywords: transient boundary conditions, timeVarying, nonuniform boundary conditions etc. About your questions: "Is it a utility?" - it's a kind of boundary condition you can use with U, p etc (like fixedValue, zeroGradient...) "How do I use it?" - you can take a look into the simpleFoam/pitzDailyExptInlet tutorial for syntax and more "And how could I generate the value for different time step?" - as I don't know anything about your case and as I've never used it, it's a bit difficult to answer this one Regards, Leonardo |
June 5, 2009, 09:50 |
xinguang cui
Rep Power: 17 |
Thanks for your answer. I would like to know where I could see the source code for this boundary condition. I guess from the source code, I could get more information.
Best wishes! |
June 5, 2009, 10:26 |
Rep Power: 17 |
Here: OpenFOAM-1.5\src\finiteVolume\fields\fvPatchFields\derived
Changing deltaT of current time step | olwi | OpenFOAM Running, Solving & CFD | 1 | April 30, 2009 05:55 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 02:29 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 12:16 |
Modeling in micron scale using icoFoam | m9819348 | OpenFOAM Running, Solving & CFD | 7 | October 27, 2007 01:36 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
