VOF fraction in multiphaseInterFoam
Old   May 21, 2009, 11:26
Default VOF fraction in multiphaseInterFoam
Nugroho Adi
mahaputra is on a distinguished road
does somebody can explain,
how fluid fractions in multiphaseInterfoam are defined ?
i success to add heat transfer equation to interFoam , compressibleLesInterFoam and bubbleFoam solvers
for example this :
volScalarField k
IOobject
"k",
runTime.timeName(),
mesh,
IOobject::READ_IF_PRESENT
alpha1*k1 + alpha2*k2
volScalarField Cp
IOobject
"Cp",
runTime.timeName(),
mesh,
alpha1*Cp1 + alpha2*Cp2
but not for multiphaseInterFoam. i always fail. i can not use directly fluid fraction symbol (i.e alpha1 and alpha2) in this solver.
the fraction formula which defined in the multiphaseInterFoam/multiphaseMixture is not same as other interFoam family solvers.
please i really need help
that somebody can explain clearly the multiphaseMixture in multiphaseInterFoam
mahaputra is offline   Reply With Quote
Old   August 27, 2009, 09:15
J. Cai
chiven is on a distinguished road
Hi, Nugroho, have a good day!
How about your progress on the multiphaseInterFoam? My research will also include adding heat transfer equation to it. The research topic is shown on
http://www.cfd-online.com/Forums/ope...lculation.html
And now I try to use the RASModel rather than laminar, but I meet an error like follows. Any comments?
Thank you.
Chiven
Create time
Create mesh for time = 0
Reading g
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
#0 _ZN4Foam5error10printStackERNS_7OstreamE-0x1466af0
in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linuxIA64GccDPOpt/libOpenFOAM.so"
#1 _ZN4Foam6sigFpe13sigFpeHandlerEi-0x140cae0
#2 Uninterpreted:
#3 _ZNK4Foam14incompressible9RASModels33nutWallFuncti onFvPatchScalarField7calcNutEv-0x3267110
in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linuxIA64GccDPOpt/libincompressibleRASModels.so"
#4 _ZN4Foam14incompressible9RASModels33nutWallFunctio nFvPatchScalarField12updateCoeffsEv-0x326aab0
#5 Foam::fvPatchField<double>::evaluate(Foam::Pstream ::commsTypes) in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxIA64GccDPOpt/multiphaseInterFoam"
#6 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxIA64GccDPOpt/multiphaseInterFoam"
#7 _ZN4Foam14incompressible9RASModels8kEpsilonC1ERKNS _14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldE NS_7volMeshEEERKNS3_IdNS_13fvsPatchFieldENS_11surf aceMeshEEERNS_14transportModelE-0x345ea40
#8 _ZN4Foam14incompressible8RASModel31adddictionaryCo nstructorToTableINS0_9RASModels8kEpsilonEE3NewERKN S_14GeometricFieldINS_6VectorIdEENS_12fvPatchField ENS_7volMeshEEERKNS6_IdNS_13fvsPatchFieldENS_11sur faceMeshEEERNS_14transportModelE-0x3410a70
#9 _ZN4Foam14incompressible8RASModel3NewERKNS_14Geome tricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volM eshEEERKNS2_IdNS_13fvsPatchFieldENS_11surfaceMeshE EERNS_14transportModelE-0x34d6870
#10 _ZN4Foam14incompressible15turbulenceModel36addturb ulenceModelConstructorToTableINS0_8RASModelEE18New turbulenceModelERKNS_14GeometricFieldINS_6VectorId EENS_12fvPatchFieldENS_7volMeshEEERKNS5_IdNS_13fvs PatchFieldENS_11surfaceMeshEEERNS_14transportModel E-0x34c0310
#11 _ZN4Foam14incompressible15turbulenceModel3NewERKNS _14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldE NS_7volMeshEEERKNS2_IdNS_13fvsPatchFieldENS_11surf aceMeshEEERNS_14transportModelE-0xe414a0
in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linuxIA64GccDPOpt/libincompressibleTurbulenceModel.so"
#12 main in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxIA64GccDPOpt/multiphaseInterFoam"
#13 __libc_start_main-0x10608e0
in "/lib/tls/libc.so.6.1"
#14 _start in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxIA64GccDPOpt/multiphaseInterFoam"
Floating exception
chiven is offline   Reply With Quote
volume fraction in mixture model and VOF???? multiphase-flow FLUENT 4 August 7, 2014 11:35
VOF model - volume fraction residual question Wim Heirwegh FLUENT 9 July 8, 2013 14:44
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
