August 16, 2005, 00:55 |
I compute the motion of threee
I compute the motion of threee bubbles with interFoam. The cGamma is 1.5 for 3D case. From the following jpg figure, we can find some dirty fragments. These fragments may be introduced by the algorithm embedded in interFoam? I have not got idea to solve this problem. Can anyone give me any advie?
time=0.1s and time=.35s: Thanks. |
August 16, 2005, 01:05 |
The result for the single mode
The result for the single mode RT instability is as follows:
The interface is beautiful, yet. |
August 16, 2005, 05:22 |
It is not clear that those fra
Rep Power: 22 |
It is not clear that those fragments are incorrect, they may be a natural consequence of a break-up process caused by the up-draft in the wake of the middle bubble but they may also be numerical as you suggest. What schemes are you using for the terms of the U an gamma equations?
August 16, 2005, 05:36 |
The scheme list:
ddtSchemes
The scheme list:
ddtSchemes { // Default scheme default Euler; } // Gradient discretisation schemes gradSchemes { // Default gradient scheme default Gauss linear; grad(U) Gauss linear; grad(gamma) Gauss linear; } // Convection discretisation schemes divSchemes { div(rho*phi,U) Gauss upwind; div(phi,gamma) Gauss Gamma201 0.2; div(phirb,gamma) Gauss Gamma201 1; } // Laplacian discretisation schemes laplacianSchemes { // Default scheme default Gauss linear corrected; } // Interpolation schemes interpolationSchemes { // Default scheme default linear; } // Surface normal gradient schemes snGradSchemes { // Default scheme default corrected; } // Calculation of flux fluxRequired { // Create storage for flux for all solved variables? default no; pd; pcorr; gamma; } I will try to do some tests with different schemes. Thanks. |
August 16, 2005, 05:49 |
I don't think your choice of s
Rep Power: 22 |
I don't think your choice of schemes are appropriate for thise case, in particular upwind on U will cause a lot of unnecessary damping and given that your case is low Re you could probably use linear of if that gives trouble Gamma2V 1. However, this will not affect the fragmentation of the interface, to see if this is real or numerical try with
div(phi,gamma) Gauss Gamma01 1; div(phirb,gamma) Gauss Gamma01 1; |
Fluent Result | Mustafa Ayad | FLUENT | 8 | June 10, 2009 08:58 |
VWT Unable to get reasonable results | dyroffk | OpenFOAM Running, Solving & CFD | 17 | February 19, 2009 03:02 |
reasonable mixing rate for C2H6 Oxygen mixture | N. Schiepel | CFX | 0 | September 12, 2008 05:57 |
reasonable result for air flow in city buildings? | George | FLUENT | 0 | August 21, 2006 21:36 |
Cannot get the right result | Eric | Main CFD Forum | 1 | September 30, 2005 15:08 |
