Surface interpolation scheme with tensors as weighting factors |
August 27, 2007, 09:43 |
Hi everybody,
I have a prob
Jutta Adelsberger
Rep Power: 17 |
Hi everybody,
I have a problem with the surface interpolation, in particular with the weighting factors of owner and neighbour cell values, for they are always scalars. But I need tensors as weighting factors for my interpolation of the velocity U. OpenFOAM doesn't provide such an option or am I missing something? I'm quite new here. Does someone already use such a scheme? And how can I use these weighting tensors for constructing the fvVectorMatrix of the convection term? By the way, I'm working with OpenFOAM-1.3. Thanks for your help. Jutta |
August 27, 2007, 12:00 |
As I said in the other posting
Hrvoje Jasak
Rep Power: 33 |
As I said in the other postings, you have to be very very careful with this sort of thing:
- is the thing you are interpolating actually a vector? If so, having different interpolation factors for each component would violate Galilean invariance. Think about rotating your reference coordinate system by 30 deg and doing the same thing again: will you get the same result? - do you wish to make ANYTHING related to your interpolation implicit? If so, this implies a block-coupled matrix and this is something I am still working on. I assume you are on the wrong track if what you do has any relation with fluid flows, heat transfer or any other "standard" physics. If not, drop me an E-mail and let's talk. Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
Which interpolation scheme is used for velocity | Chen Fangzhi | FLUENT | 1 | July 27, 2015 16:53 |
Where exactly to set up interpolation scheme | ceyrows | OpenFOAM Running, Solving & CFD | 0 | April 4, 2008 10:48 |
Surface interpolation of tensors | andebjor | OpenFOAM Pre-Processing | 2 | August 23, 2007 04:08 |
Spray interpolation scheme | chris1980 | OpenFOAM Running, Solving & CFD | 1 | June 16, 2006 14:58 |
interpolation scheme? | HADD | Siemens | 9 | September 16, 2005 14:08 |
