Fluid Structure Interaction using icoFsiFoam Problems |
November 25, 2010, 12:10 |
#62 |
Rep Power: 16 |
Hey Takuy,
that is indeed pretty worrying. I will test it with my icoFsiFoam-solver and report, if I find the same problem. I actually built it from scratch, referring to Karl Jacob Maus manual. I guess it yet is exactly the same as jasaks solver. @matteo, I am trying very hard to run icoFsiFoam parallel. However, I am very new to all the parallelization stuff in openFoam and hence find it hard to start. If I decompose both the fluid and the structure to the same numbers of processors from the .fluid-folder, the solver starts, but stops immediately before having finished the first time step. Code:
Courant Number mean: 0.01309 max: 0.12 velocity magnitude: 4 Time = 0.0003 Setting pressure Total pressure force = (0 0 0) PCG: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0 PCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0 *** Process received signal *** Signal: Segmentation fault (11) Signal code: (-6) Failing at address: 0x3ea0000081a [ 0] /lib/libc.so.6(+0x33af0) [0x7f7a7dbf2af0] [ 1] /lib/libc.so.6(gsignal+0x35) [0x7f7a7dbf2a75] [ 2] /lib/libc.so.6(+0x33af0) [0x7f7a7dbf2af0] [ 3] /lib/libc.so.6(+0x7b726) [0x7f7a7dc3a726] [ 4] /lib/libc.so.6(__libc_malloc+0x6e) [0x7f7a7dc3b58e] [ 5] /usr/lib/libstdc++.so.6(_Znwm+0x1d) [0x7f7a7e4a726d] [ 6] /usr/lib/libstdc++.so.6(_Znam+0x9) [0x7f7a7e4a7389] [ 7] /home/cfd/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libfaceDecompFiniteElement.so(_ZN4Foam4ListIcE7setSizeEi+0x33) [0x7f7a7f6b62d3] [ 8] /home/cfd/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam8OPstreamC1ENS_7Pstream10commsTypesEiiNS_8IOstream12streamFormatENS3_13versionNumberE+0xcc) [0x7f7a7ead33fc] [bionik205:02074] [ 9] /home/cfd/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam18processorPolyPatch12initGeometryEv+0xb7) [0x7f7a7eb9a427] [10] /home/cfd/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam16polyBoundaryMesh10movePointsERKNS_5FieldINS_6VectorIdEEEE+0x109) [0x7f7a7ebc2209] [11] /home/cfd/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam8polyMesh10movePointsERKNS_5FieldINS_6VectorIdEEEE+0x243) [0x7f7a7ebfadf3] [bionik205:02074] [12] /home/cfd/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam6fvMesh10movePointsERKNS_5FieldINS_6VectorIdEEEE+0x141) [0x7f7a804e39d1] [13] icoFsiFoam() [0x43c2c6] [14] /lib/libc.so.6(__libc_start_main+0xfd) [0x7f7a7dbddc4d] [15] icoFsiFoam() [0x425669] *** End of error message *** You mentioned that the patch-to-patch interpolation is the problem. However, googling did not result in any useful information, so if you have got some suggestions, that'd be great! Kind regards. *D |
November 27, 2010, 09:38 |
#63 |
Takuya OSHIMA
Rep Power: 20 |
Hi Thriceguy,
In fact we're finding the problem is not so simple and straightforward as I've reported (fixing the surface-to-surface interpolation caused another problem). In any case 1.6-ext has just been released; let's see how the "Updated fluid-structure interaction solver with parallelisation support" works Takuya |
November 27, 2010, 09:49 |
#64 |
Rep Power: 16 |
Hey Takuya,
that's good news. I will run some simulations with it, too. We'll see and hope the best ;-)! David |
April 15, 2011, 15:09 |
#65 |
Oliver Borm
Rep Power: 17 |
are there any updates with the parallelization of the icoFsiFoam solver? I tried the last version from the 1.6-ext git and the flappingConsole still does not run in parallel. I tested where the error occured and think this is already in the volPointInterpolation (cpi) of the setMotion.H. The patchToPatch interpolation also does not work in parallel, but we could switch over to a directMappedBased boundary condition (like the turbulentTemperatureCoupledBaffleMixed which is used in CHTMultiRegionFoam - this one works also in parallel) in order to couple fluid and solid patches. Any idea how to get this solver working in parallel? |
May 23, 2011, 12:06 |
flappingconsolesmall problem
#66 |
khaled
Rep Power: 16 |
Hi All
I'm struggling with some problems running the tutorials for icoFsiFoam solver (flappingConsoleSmall) on openfoam-1.6-ext. I recive this message int the terminal window: >/OpenFOAM/of16ext/stressAnalysis/icoFsiFoam/flappingConsoleSmall$ ./Allrun >Running blockMesh on/home/khaled/OpenFOAM/of16ext/stressAnalysis/icoFsiFoam/ flappingConsoleSmall/fluid >Running blockMesh on /home/khaled/OpenFOAM/of16ext/stressAnalysis/icoFsiFoam/ flappingConsoleSmall/solid /home/khaled/OpenFOAM/of16ext/stressAnalysis/icoFsiFoam/flappingConsoleSmall >./Allrun: 23: makeFsiCaseLinks: not found >Running icoFsiFoam on /home/khaled/OpenFOAM/of16ext/stressAnalysis/icoFsiFoam/flappingConsoleSmall/fluid >/Allrun: 27: makeFsiResultsLinks: not found and log files are: 1) log.blockMesh Default patch type set to empty --> FOAM Warning : From function polyMesh:olyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 583 Found 10 undefined faces in mesh; adding to default patch. 2) log.icofsiFoam --> FOAM FATAL IO ERROR: keyword divSchemes is undefined in dictionary "/home/khaled/OpenFOAM/of16ext/stressAnalysis/icoFsiFoam/flappingConsoleSmall/fluid/system/solid/fvSchemes" file: /home/khaled/OpenFOAM/of16ext/stressAnalysis/icoFsiFoam/flappingConsoleSmall/fluid/system/solid/fvSchemes From function dictionary::subDict(const word& keyword) const in file db/dictionary/dictionary.C at line 457. FOAM exiting
May 24, 2011, 04:29 |
#67 |
Matthias Voß
Rep Power: 20 |
looks like blockMesh came up with the error in the first place.
May 29, 2011, 16:16 |
#68 |
Rep Power: 16 |
@ PeterII
You need to take the latest RunFunctions from http://openfoam-extend.svn.sourcefor...ext/bin/tools/ and replace it with your RunFunctions in bin/tools/ Moreover comment out these lines in Allrun Code:
#cd constant #ln -s ../../solid/constant solid #cd .. #cd 0 #ln -s ../../solid/0 solid #cd .. |
June 5, 2011, 08:26 |
icostructFoam paraFoam
#69 |
khaled
Rep Power: 16 |
Thank you (ZKM) so much for this help. However the blockMesh log file show the this error:
Creating block mesh topology Default patch type set to empty --> FOAM Warning : From function polyMesh:olyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 583 Found 10 undefined faces in mesh; adding to default patch. Check block mesh topology Now I want to model the deformation of the blood vessel under a pusatil pressure and anny helpe will be appreciate. |
June 15, 2011, 10:31 |
icoFsiFoam problem with decomposed patches
#70 |
D. Matz
Rep Power: 15 |
Hi everybody,
I'm new to this Forum, but have some experience with OpenFOAM. I'm interested in Fluid Structure Interaction and am currently testing the icoFsiFoam-Solver from the OF-1.6-ext version. In serial mode the tutorial and several other cases are working fine, but if it goes to parallel the results do not match the serial ones. The deformation of the solid in parallel (in some cases) is far less than expected. The problem occurs when the fluid/solid patch is on 2 or more processors. If the fluid/solid patch is only on one processor the parallel and serial cases match perfectly. My questions are, if somebody else has the same problem and if there is any solution? Thanks in advance! Best regards, Daniel PS: The Problem can easily be reproduced with the standard tutorial for icoFsiFoam (flappingConsoleSmall). For the decomposeParDict the following can be used (it is only important that the fluid/solid patch is split!): numberOfSubdomains 4; method simple; simpleCoeffs { n (1 4 1 ); delta 0.001; } |
July 7, 2011, 06:56 |
myFSI solver and test case
#71 |
Charbel Habchi
Rep Power: 15 |
Hi everyone,
You can find here a new solver that I am trying to make for fluid-structure interaction. I am working on version 1.6-ext. This solver included: 1/ pimpleDyMFoam in which we have ALE and turbulence models can be used 2/ outer fixed point adaptive relaxation by using Aitken's method for strong coupling 3/ solve transport equations for heat and mass transfer 4/ solid solver for large deformattion (2nd Piola-Krichhoff stress tensor...) 5/ computing traction in setPressure.H but it is not taken into account in tractionDisplacementFvPatchVectorField.C can you give some hint please Can you try this solver on the attached testCase and give me remarks because I am sure there will be some mistakes especially for: 1/ Aitken's method 2/ solid solver and its part in tractionDisplacementFvPatchVectorField.C 3/ setting traction in tractionDisplacementFvPatchVectorField.C Thank you in advance. Charbel. |
July 24, 2011, 00:16 |
#72 | |
Santiago
Rep Power: 16 |
I have the exact same problem. Does anyone knows how to solve this one?? I will really appreciate any help. Thanks |
August 4, 2013, 11:32 |
IcoFSIFOAM EROOR
#73 |
Soheil nazmdeh
Rep Power: 13 |
Hi ,
I try to solve my case with icoFsiFOAM solver , but in my geometry this eroor accur when try to solve it : ..... Moving mesh time step continuity errors : sum local = -92209, global = 1.98903, cumulative = 2.86326 CG: Solving for p, Initial residual = 0.999957, Final residual = 7.0708e-07, No Iterations 526 CG: Solving for p, Initial residual = 0.999109, Final residual = 0.000723223, No Iterations 1000 Moving mesh time step continuity errors : sum local = 2.07627e+14, global = 2.26112e+10, cumulative = 2.26112e+10 Floating point exception (core dumped) please help me to solve it...! |
November 14, 2013, 06:41 |
icoFsiFoam in OpenFOAM 2.2.1
#74 |
ok
Rep Power: 14 |
Dear All,
could you help me please where can I find icoFsiFoam solver in OpenFOAM 2.2.1. I searched many times but unfortunately I didn't get any result. Also, I tried to make my FSI directory but the same it is not working. Help me please to find the answer. Regards |
November 16, 2013, 15:15 |
#75 | |
Eric Robertson
Rep Power: 15 |
November 18, 2013, 13:15 |
#76 |
ok
Rep Power: 14 |
Many thanks for your reply. I have some questions regarding your answer
1. Have I install OpenFOAM 1.6-ext inside OpenFOAM 2.2.1 that I had installed before or install it separately? 2. During installation I got some error, how can I re-install it again? 3. I got locked folders, OpenFOAM 1.6-ext locked, why? 4. How to work with fluid and solid in parallel in cases such that flappingConsoleSmall? Many thanks for your helping. |
November 30, 2013, 16:09 |
FVM and FEM FSI-OF-1.6ext
#77 |
Hi
Iam using pimpleFsiFoam solver for pitching motion of naca0012 airfoil in incompressible and turbulence flow.My problem is weak coupling. PimpleFsiFoam is a solver based on FEM. So for moving the airfoil by pointDisplacement, I converted it to FVM. I create 2 meshes in gambit, one for the fluid and another one with the airfoil only as my solidMesh. Then convert them using fluentmeshToFoam. Various mesh for y + <1 is tried and boundary conditions for U and P are: U: Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (13.7873 2.431 0); boundaryField { outlet { type zeroGradient; } inlet { type fixedValue; value $internalField; } airfoil { type movingWallVelocity; value uniform (0 0 0); } Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { outlet { type fixedValue; value uniform 0; } inlet { type zeroGradient; } airfoil { type zeroGradient; } Do Solver wrong acts or the case is problem? Geometry with coarse mesh and without motion and laminar flow was ran only by icoFsiFoam openfoam tutorial solver. For turbulent flow,I convert icoFsiFoam to pisoFsiFoam. But again, I fail. How do I apply this motion in the FEM solver? Last edited by wyldckat; December 1, 2013 at 09:36. Reason: Added [CODE][/CODE] |
February 6, 2014, 17:58 |
what caused that error
#78 | |
Eric Bryant
Rep Power: 13 |
Seeing a similar error PeterII experienced, and ZKM suggested a solution for.
Different situation - in that I'm adapting the icoFsiFoam solver to use a different solid domain solver. The error I see is: Code:
--> FOAM FATAL IO ERROR: keyword grad(U) is undefined in dictionary "/home/eric/foam/eric-3.0/run/ applications/solvers/icoFsiElasticAcpSolidFoam/tutorial/fluid/system/fvSchemes::gradSchemes" So could anyone shed some light on the underlying reason for ZKM's proposed solution: Quote:
July 21, 2014, 21:46 |
Problem in viewing HronTurekFsi
#79 |
Hassan Adel
Rep Power: 13 |
I solved HronTurekFsi case in OF- Extend 3.1
for many time steps but i stoped the solver to show it in paraFoam. It appears fluid domain only without solid
H.Elsheshtawy |
August 7, 2014, 10:30 |
flexible flapping airfoil
#80 |
Hi friends,
I could impose motion on solid patch by applying oscillatingFixedValue BC in motionU file and solid moves properly.But unlike the solid, fluid patch moves in the opposite direction of solid patch. Solver is icoFsiElasticNonLin... in foam-extend-3.1. My test case is uploaded on: http://www.uploadbaz.com/f4xg5rf6b2rv Where is the problem? Can someone help me? Christoph, I have a specific question from you. I want to impose a forced oscillatory motion on solid,According to your thread in post #10. Can you tell me how did you apply that motion? |
FLUID STRUCTURE INTERACTION | Javier | FLUENT | 1 | October 14, 2004 14:42 |
fluid-structure interaction | Tikka | Main CFD Forum | 4 | July 7, 2001 16:08 |
Fluid-Structure Interaction | Janice | Main CFD Forum | 9 | May 3, 2001 17:46 |
FLUID/Structure Interaction | Jas | Main CFD Forum | 5 | November 21, 2000 05:46 |
Fluid-Structure Interaction | Gabor BALINT | Main CFD Forum | 5 | October 12, 1999 05:54 |
