October 25, 2005, 16:04 |
using wallHeatflux I ca
Ulrich Uphoff
Rep Power: 17 |
using wallHeatflux I can calculate the heatFlux over the wall patches. Has anybody found a solution to calculate the heat transfer coefficient? It is defined as q/(T_wall-T_fluid) where T_fluid is the temperature somewhere near the wall. I am not sure which temperature to use, a temperature somewhere in the boundary layer or the first temperature value outside the boundary layer. How can I realize this in openFoam in an elegant way? Regards Uli |
October 26, 2005, 07:05 |
I'm also interested in this pr
I'm also interested in this problem, but my view on this case is that this is problematic, based on what I've read earlier on this forum.
As far as I understand, then you'll probably need two meshes, one for each material. This problem with the two meshes and the coupling between them has been discussed here before, but if anyone has any easy solutions for implementing the heat transfer coeffient in the interface for a temperature calculation for two different kinds of materials then I would also like to hear some hints on how to model this (since I'm a beginner with Foam). So far, I've only used laplacianFoam to calculate the temperatures for a uniform material and used setFields to make a small box with higher temperatures in the middle... In my opinion, Foam would become much more popular, if this kind of problem would become easy to deal with (but since I'm a beginner with Foam, perhaps there already exists an easy solution?). Actually I don't understand your question completely. Seems like you already have some simulation results but you don't know the heat transfer coefficient? I think the problem should be seen from this viewpoint: How to implement HTC in the interface with laplacianFoam for two different materials (different thermal diffusivity for each mesh) and then calculate the new temperatures based on this? (I don't know the answer). |
October 26, 2005, 14:01 |
Hi Martin,
your point of vi
Ulrich Uphoff
Rep Power: 17 |
Hi Martin,
your point of view is right, but I wanted to work on the problem step by step: First step: Assuming a fluid calculation with a constant wall temperature I just wanted to calculate the heat transfer coefficient. My problem is the estimation of a "near wall" gas-temperature. What temperature should I use and how do I calculate it with OpenFoam? Second step: Assuming a wall thickness distribution on the outer surface I would like to calculate the heat transfer coefficient in conjunction with the 1-D heat conduction in the wall. Third step: Using two meshes, fluid and solid and coupling them. I know that this has already been discussed... Best regards Uli |
October 26, 2005, 15:17 |
I think you have the problem b
Eugene de Villiers
Rep Power: 21 |
I think you have the problem backwards here.
The heat transfer coefficient is a modeled quantity dependent on the local flow properties. The temperatures you use to calculate the heat flux are the wall temperature and the temperature in the first off-the-wall cell. |
October 27, 2005, 02:56 |
Actually, Ulrich is right. In
Håkan Nilsson
Rep Power: 18 |
Actually, Ulrich is right. In a CFD solver you compute the heat flux, which is determined by the temperature gradient close to the wall. The heat transfer *coefficient* on the other hand is a pure definition, and it can be defined as h=q/(T_wall-T_fluid). If q is computed with given T_wall, all that is needed to compute h is T_fluid. That is where the definition comes in. You have to define what T_fluid you want to use for your particular application. In free-stream flow it can be the free-stream temperature, and in internal flow it can be some average temperature. It is just a definition. Usually you determine T_fluid during post-prosessing, in the post-processor. I'm sure that you could write an application in OpenFoam for it also, but I'm not sure that it is worth the effort.
Håkan. |
October 27, 2005, 06:09 |
Ah ok, I got it wrong, you wan
Eugene de Villiers
Rep Power: 21 |
Ah ok, I got it wrong, you want to calculate the overall heat transfer coefficient of an object or boundary. In that case I agree with Hakan. Specifically, I would use the temperature of the fluid at the inlet as T_fluid.
March 1, 2006, 05:51 |
Hi, I want to model a experime
Hi, I want to model a experiment which has a incompressible fluid flow alongside bars with constant heat flux.
The goal is to describe the spatial velocities, temperatures and presures. I was told on the message bord that rhoSimpleFoam would be a good solver for this problem if the density somehow was set to a fix value. Once I made rhoSimpleFoam visible in FoamX it seemed identical to buoyantSimpleFoam. Are there any differance between the solvers? I have reed on the message board that constant heat flux needs to be aranged thru fixed gradiant b.c on T. But I can only find fixed value och zero gradient as b.c alternatives. The big quesiton is: How do i modify rhoSimpleFoam so that it models a flow being heated with constant heat flux? Thanks /E |
October 15, 2007, 06:37 |
Dear Foamers,
want to study
Stefan Radl
Rep Power: 18 |
Dear Foamers,
want to study mass/heat transfer in a simple pipe flow. I want to calculate the local heat flux from the wall and plot it against the pipe length. An idea would be to calculate the heat flow / the mean temperature in a certain slice perpenticular to the axis and then write to a file. Has anybody tried this ever or has an appropriate postProcessor? br Stefan Radl |
November 17, 2008, 12:09 |
HI,
i would like to know th
#9 |
Pattyn Eric
Rep Power: 17 |
HI,
i would like to know the wall heat flux of a flat plate at a constant temperature which is heating a fluid by forced convection. When using the function wallHeatflux, it complains about my thermophysical model: Selecting thermodynamics package hMixtureThermo<homogeneousmixture<consttransport<s peciethermo<hconstthermo<perfe ctgas>>>>> cannot open file file: /net/ric_home/ep4/OpenFOAM/ep4-1.5/run/Channel_Flowinitialisation/920/Ydefault at line 0. From function regIOobject::readStream(const word&) in file db/regIOobject/regIOobjectRead.C at line 66. FOAM exiting The ones he proposes me are complicated and not necessary for my application. Is it possible, using a pureMixture model to know the heat flux, to get easely this quantity or the normal gradient ? |
November 18, 2008, 04:25 |
make a copy of the exis
#10 |
Ville Tossavainen
Rep Power: 17 |
make a copy of the existing "wallHeatFlux" utility and modify the code (and the make files) a little bit. At least you need to replace "hCombustionThermo" in createFields.H with something more appropriate (like basicThermo). Also you need to replace "hCombustionThermo.H" with something else (like hThermo.H). Just play with the code |
November 18, 2008, 04:42 |
Hi Ville,
I am also interes
#11 |
Hi Ville,
I am also interested in wallHeatFlux utility from where can I get this? Thanks Emo |
November 18, 2008, 06:17 |
Before playing with any code,
#12 |
Pattyn Eric
Rep Power: 17 |
Before playing with any code, i have tried to recompile the wallHeatFlux application with an other name.
However, after the wmake exe, i received the following error: ep4@wobwslx2:/net/ric_home/ep4/OpenFOAM/ep4-1.5/applications/wallHeatFluxpure$ wmake exe SOURCE=wallHeatFluxpure.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/src/turbulenceModels/RAS -I/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/specie/lnInclude -I/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/combustion/lnIncl ude -I/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/basic/lnInclude -IlnInclude -I. -I/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/wallHeatFluxpure.o g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/src/turbulenceModels/RAS -I/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/specie/lnInclude -I/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/combustion/lnIncl ude -I/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/basic/lnInclude -IlnInclude -I. -I/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC Make/linux64GccDPOpt/wallHeatFluxpure.o -lcompressibleRASModels -lcombustionThermophysicalModels -lfiniteVolume -lspecie -lbasicThermophysicalModels \ -lm -o a.out /usr/local/bin/ld: cannot find -lcompressibleRASModels collect2: ld returned 1 exit status make: *** [a.out] Fehler 1 When installing OpenFoam, i had alredy have such errors with -l... and resolved it by recompiling the different libraries with the command wmake libso. In this case, they are already "up to date". I don't understand why i have this problem again. Thank you for any help, comments. Eric |
November 18, 2008, 16:55 |
Pattyn: type just "wmake"
E
#13 |
Ville Tossavainen
Rep Power: 17 |
Emo: "wallHeatFlux" utility is provided in the OpenFOAM distribution package. If you want to use it with non-combustible mixture, you need to make the small modification I described before. |
November 19, 2008, 02:52 |
i'm not sure to have un
#14 |
Pattyn Eric
Rep Power: 17 |
i'm not sure to have understood. Should i make wmake in my new application directory in place of wmake exe or a wmake for the compressibleRASModels in place of wmake libso? The first option gives me this: /ric_home/ep4/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libcompressibleRASModels .so: undefined reference to `Foam::cellDistFuncs::correctBoundaryPointCells(Fo am::HashSet<int,> > const&, Foam::Field<double>&, Foam::Map<int>&) const' /ric_home/ep4/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::triSurface::triSurface()' /ric_home/ep4/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::triSurfaceTools::delaunay2D(Foam::List<foam ::vector2d<double> > const&)' /ric_home/ep4/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::cellDistFuncs::maxPatchSize(Foam::HashSet<i nt,> > const&) const' /ric_home/ep4/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::Pstream::init(int&, char**&)' /ric_home/ep4/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::directMappedPolyPatch::calcMapping() const' /ric_home/ep4/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libcompressibleRASModels .so: undefined reference to `Foam::cellDistFuncs::sumPatchSize(Foam::HashSet<i nt,> > const&) const' /ric_home/ep4/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::Pstream::addValidParOptions(Foam::HashTable <foam::string,>&)' collect2: ld returned 1 exit status make: *** [/ric_home/ep4/OpenFOAM/ep4-1.5/applications/bin/linux64GccDPOpt/wallHeatFluxpur e] Fehler 1 Thank you for any help Eric |
November 19, 2008, 04:51 |
I meant the first thing, "wmak
#15 |
Ville Tossavainen
Rep Power: 17 |
I meant the first thing, "wmake" to make executables and "wmake libso" for libraries. I have got the same error if I tried "wmake exe" (never used it before though) to build an executable.
Did you run "wclean" before "wmake" in your new utility directory? I have no clues what could be wrong.. |
November 25, 2009, 08:43 |
#16 | |
Rep Power: 17 |
Maybe not the best way, but it works fine in my opinion |
November 25, 2009, 11:41 |
#17 |
Eelco van Vliet
Rep Power: 19 |
Hi Ulrich,
I used wallHeatFlux as well and found some strange behaviour with it after a restart of a parallel run (heatflux will be reset to zero) My solution was using groovyBC (available on the openfoam contributions), a flexible way of settings boundary conditions. With groovyBc you can impose both a constant heat flux as well as a heat transfer coefficient. Have a look at the thread below to see what I did. Regards, Eelco http://www.cfd-online.com/Forums/ope...r-restart.html |
Correlations for heat transfer coefficients | poornima | Main CFD Forum | 2 | April 27, 2006 12:27 |
export nodes, cells and heat transfer coefficients | Ademar Cardoso | FLUENT | 0 | September 13, 2005 18:22 |
approach to heat transfer coefficients | Petr | CFX | 0 | September 30, 2004 06:25 |
Heat Transfer Coefficients: Predictive Capability | Chris | Main CFD Forum | 2 | August 16, 2002 15:31 |
Heat Transfer Coefficients | Ashish Kumar Gupta | Siemens | 6 | November 22, 2001 03:50 |
