LES
Like Tree36Likes
Old   May 18, 2007, 10:06
Default Hi Eugene, thank you for your
  #81
Cedric DUPRAT
cedric_duprat is on a distinguished road
Hi Eugene,
thank you for your reply,
1- I think (and I think you also will agree) that the effect of pressure gradient is fonction of the geometry, isn't it ?. Mine is a diffuser so I "hope" that the effect won't be negligible ...
2- I agree that the wall model is dependent of y+.
value of y+ give us the area where the first node is (viscous layer, buffer lawer, ...)
3- I also use a Newton-Raphson in my own code without any limiter (10 loops in OF), I didn't try it yet but, I hope getting value for utau (converged one). then I'll check the value of y+ just to know if I used the good law or not.
I'm interrested in Peller, Brun, Manhart (DLES VI) point of vue in wall layer. but, I don't think they used Pmean ...
You had problems with the value of pressure gradients using instantaneous p, can you tell me more about what you did ?
Cedric
cedric_duprat is offline   Reply With Quote
Old   May 18, 2007, 10:33
Default Not much to tell, I built a pr
  #82
Eugene de Villiers
eugene is on a distinguished road
Not much to tell, I built a pressure sensitised wall function for the SA DES model, applied it to a side mirror geometry and the results were more or less the same as without it. No actual "problems".
eugene is offline   Reply With Quote
Old   July 15, 2007, 05:46
Default Hi everyone By using oodles f
  #83
Marhamat Zeinali
marhamat is on a distinguished road
Hi everyone
By using oodles for turbulent flat plate simulation in 3D(that in it back&front are symmetryplane)i see pressure gradient in my solution.
How i can justify that?
Best regards
Marhamat
marhamat is offline   Reply With Quote
Old   July 17, 2007, 10:41
Default Hi everyone I add that i us
  #84
Marhamat Zeinali
Hi everyone
I add that i used symmetryplane as a upperwall boundry condition.
any idea?
Regards
Marhamat
Old   July 17, 2007, 11:41
Default Hi Marhamat I'm not sure to
  #85
Cedric DUPRAT
Hi Marhamat
I'm not sure to get your graph but, as I understand, your pressure decrease right ?
Does your geometry 200 lenght or do you use cyclic BC to get these results ?
what about your BC inlet and outlet ?
just questions but ....It's just to get better your problem
Cedric
Old   July 18, 2007, 02:08
Default Hi Cedric The geometry is s
  #86
Marhamat Zeinali
Hi Cedric
The geometry is same as the last geometry that i point it out (on Saturday, May 05, 2007 - 01:55 am )in this page but in 3D and with these conditions:
Inlet for inlet BC & outlet for outlet Bc.
inlet velocity is uniform = 10 m/s.& nu=1.0e-6
$Dimentions=(1200,20,10)mm. mesh refined.
And i used initial perturbed condition .
As you see pressure decrease in x direction
Thanks alot
Marhamat
Old   July 18, 2007, 03:28
Default you fixed the velocity at the
  #87
Cedric DUPRAT
you fixed the velocity at the inlet, what about the pressure value at your outlet BC ? is it, for exemple 0 ?
did you change something at "line division" 40 (see your Graph)?
that's all I was thinking about up to now ...
Cedric
Old   July 18, 2007, 04:25
Default Yes,the outlet pressure is zer
  #88
Marhamat Zeinali
Yes,the outlet pressure is zero
In this case i used two blockes that in block one the bottom wall is symmetryplane(200mm).and the plate set after it.
Marhamat
Old   July 18, 2007, 04:40
Default so, ... I don't get what is t
  #89
Cedric DUPRAT
so, ...
I don't get what is the problem, you fixed the pressure at 0 at the outlet so, if your pressure is higher than 0 before (that's your case), the pressure will decrease to get your hand fixed value at the outlet. What do you think of that ?
Cedric
Old   July 18, 2007, 09:01
Default That's right. But i want to
  #90
Marhamat Zeinali
That's right.
But i want to know in which condition(with which changes)i can get result for turbulent flat plate with zero pressure gradient.
Best regards
Marhamat
Old   July 18, 2007, 09:39
Default yes, ...sure http://www.cfd-on
  #91
Cedric DUPRAT
yes, ...sure
so :
1- with your last run (picture) you know the inlet pressure, so why don't you put the same at the outlet ?
2- other solution, why don't you change the outlet BC from fixed value of pressure to zerogradient.
and then, try to check often the pressure in your run so you won't have to wait too long ...
I'm not sure it will help ....
Cedric
Old   July 19, 2007, 08:13
Default Your pressure gradient for a c
  #92
Eugene de Villiers
Your pressure gradient for a constrained flow (I assume your top bondary is symmetry?) has to be equal to the wall shear stress. That is basic conservation of momentum.
If you want to keep the pressure more or less uniform you will have to change the top boundary to reflect this. Specifically you will have to set the top boundary to some kind of free-stream condition that fixes the pressure at the same value as the outlet and allows fluid to leave the domain.
This can probably (i make no promises!) be achieved by using a totalPressure boundary for both the top and outlet and applying a pressureInletOutletVelocity boundary to U over the same extent. This might cause problems at the junction of the inlet and the top wall though.
Old   July 23, 2007, 05:34
Default Hi Eugene I used atomospher
  #93
Marhamat Zeinali
Hi Eugene
I used atomospher condition in top&outlet boundries.but it seems the solution isn't good for turbulent plate.
Do you think i must increase the altitude of my geometry(in this case h/L=0.02 & L=1m)
Thanks alot
Marhamat
Old   July 23, 2007, 08:57
Default Well first off, your "free-str
  #94
Eugene de Villiers
Well first off, your "free-stream" boundary is inside the boundary layer! I suggest you place your top boundary 10-20 times further away from the bottom wall.
Old   July 30, 2007, 12:11
Default hi all, I'm (again) trying
  #95
Cedric DUPRAT
hi all,
I'm (again) trying to integrate a near wall scaling with adverse pressure gradient in OF after a few month break on this topic.
1- a "comment-question" on law of the wall in OF, the law add a viscosity at the wall (which is added at the first cells, I guess), is there a discontinuity of the viscosity between the first cell and the second one ? (this question can be also asked for most of the OF' LES models)
2- I need to calculate the pressure gradient in my geometry (axisymetric one).
my question is can I do something like that; the pressure pradient vector is avaiable at the cell center by:
volVectorField gradp = fvc::grad(p);
I transpose it in Cylindric coordinate system
fvPatchVectorField& gradpCCSin = gradp.boundaryField()[PatchID];
CCSin[PatchID] = ccs.toLocal(cartFaceCentres[PatchID]);
CCSin[PatchID][1] = CCSin[PatchID][1] + neg(CCSin[PatchID][1])*360;
and then, I would like to get the tangent component. but the vector::Y is the orthoradial one isn't it ? :
scalar dpds = ccs.toLocal(gradpCCSin).component(vector::Y);
still following, the end is coming soon :
so if I use snGrad(p) (the wall normal direction ?)* ccs.toLocal(gradpCCSin).component(vector::Y),
will it be the tangential component of grad(p) ?
I'm not sur to get what I want and, I'm not sure to take the easiest way ...
Can someone give me his point of view on that method?
Thank you,
Cedric
Old   October 5, 2007, 15:56
Default hi all i am a new user of Ope
  #96
susan jackson
susanjackson24 is on a distinguished road
hi all
i am a new user of Open FOAM,i want to use oodles solver in openfoam,and i have a basic question about it.
1-i know that the filter width have various definition such as (dxdydz)^(1/3) and ... i want to know which one of these definition used in openfoam.
2-what does the meaning of Lesdelta and its option such as van dreist and parndtl and cube root vol?
Best regards
susan
susanjackson24 is offline   Reply With Quote
Old   October 8, 2007, 07:51
Default Hey susan, delta is the fil
  #97
hadi tartoussi
hadi is on a distinguished road
Hey susan,
delta is the filter width, cubeRootVol is the filter width that you have mentioned in your message.
VanDriest is a damping function used to make the contribution of the sgs model goes to 0 near the wall boundary.
Take a look at .C files to see how it is calculated.
Hope it helps!
Hadi
hadi is offline   Reply With Quote
Old   October 17, 2007, 05:55
Default Hi Eugene and all Thanks Eug
  #98
ehsan yasari
ehsanyasari is on a distinguished road
Hi Eugene and all
Thanks Eugene.
Our thease is about filtration in LES.
We study LESfilters codes (LESfilter,NewFilter,Simple,Laplace,anistropic) but we have following problem about them:
1-Algorithm and Formulation of filtration that used in these codes.
2-According to the discription part of laplacefilter.H and anisotropicfilter.H :
Description
Kernel as filter as Test filter with ratio 2
Box filter: g = delta2/24 -> g = delta2/6
Spherical box filter: g = delta2/64 -> g = delta2/16
Gaussian filter: g = delta2/24 -> g = delta2/6
what is "g" parameter and where is the effect of "g" in these codes.
3-What is "widthcoeff_" that used in these codes?
We REALLY need the answer of these question.thanks for your help.
ehsanyasari is offline   Reply With Quote
Old   October 17, 2007, 09:13
Default Sorry, I did not code and neve
  #99
Eugene de Villiers
Sorry, I did not code and never use the filters so cannot answer your question off-hand.
ethan oh likes this.
Old   December 10, 2007, 05:15
Default Hello all would you please
  #100
Armin Hosseinian
armin_h is on a distinguished road
Hello all
would you please any one let me know how can i push flow into the pipe in openfoam?
I have created the geometry of the pipe and also the mesh.
I need to see the velocity profile which comes from the moving flow into the pipe.
I am new user of openfoam and i dont know how can i put the amounts for the u velocity and see the motion of the fluid inside the pipe.
I would appreciate any comments.
sorry if it is not an advance question.
Cheers
Armin
armin_h is offline   Reply With Quote
