September 15, 2010, 08:56 |
#21 |
Olivier
Rep Power: 18 |
Hello Maddalena,
Thanks for this test case. Have you tested to comment the line Code:
//jump_ = max(jump_, scalar(0)); As Mike pointed out, this is the only difference between 1.5-dev and 1.6.x/1.7.x Olivier |
September 15, 2010, 09:03 |
#22 |
maddalena
Rep Power: 23 |
September 16, 2010, 07:04 |
#23 |
maddalena
Rep Power: 23 |
One more question on the subject.
I am experiencing hard time to simulate a closed loop cooling system which includes a fan. I set the fan direction as described above: choose the master and slave face as I want the air moves and set the f coefficient as 1(10). PotentialFoam confirms that my settings are OK, as shown in fan_0.png. However, when using simpleFoam (with turbulence off), the flow reverses its direction and, at time 75, it is completely on the opposite direction I want it to go, see fan_75.png. I also noticed that the continuity error is a little bit too high: at time 75 I have: Code:
time step continuity errors : sum local = 0.0232117, global = -9.05912e-06, cumulative = -9.81427e-05 Any ideas on the reason of that? thank you for any idea or suggestion. mad Last edited by maddalena; September 16, 2010 at 07:07. Reason: added info |
September 17, 2010, 09:21 |
#24 |
maddalena
Rep Power: 23 |
For everyone that will meet the same problem: the fan BC is very sensitive to the mesh quality in proximity of it. Although having a good tet mesh, the simulation never converged. The solution was to use a hexa mesh in the proximity of the fan.
Hope this help someone. mad |
February 3, 2011, 11:57 |
How is velocity defined?
#25 |
Jerry
Rep Power: 15 |
Hi all,
I'm using the fan bc, which is proving very useful for me. However I was wondering given the case where the velocity varies across the boundary condition which value of V is used to calculate the pressure drop (given the inputted polynomial coefficients). Is it an average value? Thanks for your help! |
February 9, 2011, 14:48 |
what is going wrong?
#26 |
maddalena
Rep Power: 23 |
It seems like that problems I thought solved reappears suddenly in these days… As usual, velocity field at the fan interface looks unrealistic: wiggles and vectors going in the wrong direction. However:
mad |
August 24, 2011, 13:56 |
#27 |
Claudio
Rep Power: 16 |
Hi All,
I kindly ask You to read my thread http://www.cfd-online.com/Forums/ope...am1-7-1-a.html. Thank You in advance, Claudio |
November 9, 2011, 15:31 |
#28 | |
Cesar Retamal Bravo
Rep Power: 15 |
I'm new to the use of OpenFOAM, I have installed on my computer OpenFOAM 2.0.1, and I'm trying to model a bedroom with a fan in the center, the flow enters through a window and out through a door. Download the example of the fan, the compiler creates in the boundary conditions and fan_half1 fan_half0 patches and not that I give these values in the file 0 / p would greatly appreciate your answers cordially Cesar |
November 10, 2011, 03:56 |
#29 | |
maddalena
Rep Power: 23 |
maddalena. |
November 10, 2011, 08:30 |
#30 |
Cesar Retamal Bravo
Rep Power: 15 |
thank you very much Maddalena
If anyone could help me more, they are most grateful. I have also problems with the creation of the mesh in OpenFOAM, I can not define the inner patch to model the fan, try making a mesh of ideas, but when using the tool converts the mesh buts ideasUnvToFoam lose some volume elements, could you help me again by favor. thanks Cesar. |
November 10, 2011, 08:33 |
#31 | |
maddalena
Rep Power: 23 |
Hi Cesar
mad |
July 30, 2015, 13:22 |
#32 |
daniel
Rep Power: 11 |
Hello
I wanted to run this case posted above"fan.tar.gz" Last edited by leinad; July 30, 2015 at 14:50. |
CoupledFvScalarMatrix in OF15 | fisher | OpenFOAM Running, Solving & CFD | 9 | May 27, 2020 10:40 |
Forces in OF15 | richard | OpenFOAM Running, Solving & CFD | 180 | July 9, 2018 11:54 |
Bug in patchIntegrateC OF15 | anger | OpenFOAM Bugs | 8 | May 29, 2009 05:36 |
Is it a bug in Userbs Guide for OF15 | kai | OpenFOAM Bugs | 1 | October 2, 2008 09:07 |
Bug or a feature of OF15 | rafal | OpenFOAM Bugs | 5 | July 25, 2008 06:25 |
