March 5, 2009, 15:39 |
Hi Niels,
Thanks for the in
#101 |
Vishal Nandigana
Rep Power: 18 |
Hi Niels,
Thanks for the information. I will try that.. I heard that even oscillatingfixedvalue would also work in this case... Any idea how to incorporate them.. Thanks Regards Vishal Nandigana |
March 9, 2009, 05:59 |
As I have not tried it, my onl
#102 |
Niels Gjoel Jacobsen
Rep Power: 37 |
As I have not tried it, my only suggestion is for you to look at the wiki, which seems to give quite a few examples.
Good luck, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
March 9, 2009, 13:10 |
Thanks Niels...
I will go t
#103 |
Vishal Nandigana
Rep Power: 18 |
Thanks Niels...
I will go through it and get back to you.. Regards Vishal |
June 29, 2009, 14:19 |
#104 |
Gautami Erukulla
Rep Power: 17 |
Hello
I have downloaded the groovy wave Tank case from the following link. http://openfoamwiki.net/index.php/Contrib_groovyBC I was not able to run the case successfully.(on OpenFoam-1.5) Any suggestions will be really helpful. Regards, Gautami. |
June 29, 2009, 15:49 |
#105 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
You touched the first two bullet-points in number 3 at http://openfoamwiki.net/index.php/Ho..._Message_Board Bernhard |
June 29, 2009, 17:18 |
#106 |
Gautami Erukulla
Rep Power: 17 |
I am sorry for being so vague. I am using OpenFoam-1.5 on Suse linux 10.3. The main reason why my groovy wave tank case is not working is that I am not able to compile the library. I downloaded the source code for the library from: https://openfoam-extend.svn.sourcefo...ries/groovyBC/ I created a new folder named groovyBC in the applications folder and copied the source code into it and tried to compile it with the command "wmake libso". But I get the following error. gali@SAI:~/OpenFOAM/OpenFOAM-1.5/applications/groovyBC> wmake libso wmakeLnInclude: linking include files to /home/gali/OpenFOAM/OpenFOAM-1.5/applications/groovyBC/lnInclude Making dependency list for source file PatchResult.C Making dependency list for source file PatchValueExpressionParser.yy could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionParser.yy Making dependency list for source file PatchValueExpressionLexer.ll could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionLexer.ll Making dependency list for source file PatchValueExpressionDriver.C could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionDriver.C Making dependency list for source file groovyBCFvPatchFields.C could not open file PatchValueExpressionParser.tab.hh for source file groovyBCFvPatchFields.C Making dependency list for source file groovyBCPointPatchFields.C could not open file MixedPointPatchField.H for source file groovyBCPointPatchFields.C could not open file PatchValueExpressionParser.tab.hh for source file groovyBCPointPatchFields.C could not open file PointPatchFieldMapper.H for source file groovyBCPointPatchFields.C SOURCE=PatchResult.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/gali/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/gali/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/gali/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/PatchResult.o PatchResult.C: In member function ‘void Foam::PatchResult::uglyDelete()’: PatchResult.C:97: warning: deleting ‘void*’ is undefined SOURCE=PatchValueExpressionParser.yy ; rm -f Make/linuxGccDPOpt/PatchValueExpressionParser.C Make/linuxGccDPOpt/PatchValueExpressionParser.tab.hh; bison -ra -v -d $SOURCE ; mv *.tab.cc Make/linuxGccDPOpt/PatchValueExpressionParser.C ; mv *.tab.hh Make/linuxGccDPOpt/PatchValueExpressionParser.tab.hh ; mv *.hh Make/linuxGccDPOpt ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/gali/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/gali/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/gali/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c Make/linuxGccDPOpt/PatchValueExpressionParser.C -o Make/linuxGccDPOpt/PatchValueExpressionParser.o /bin/sh: bison: command not found mv: cannot stat `*.tab.cc': No such file or directory mv: cannot stat `*.tab.hh': No such file or directory mv: cannot stat `*.hh': No such file or directory g++: Make/linuxGccDPOpt/PatchValueExpressionParser.C: No such file or directory g++: no input files make: *** [Make/linuxGccDPOpt/PatchValueExpressionParser.o] Error 1 gali@SAI:~/OpenFOAM/OpenFOAM-1.5/applications/groovyBC> Can you please suggest as to what I can do. Thankyou Gautami. |
June 29, 2009, 17:53 |
#107 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
OK. This is something that can be worked with.
The error lies here: Quote:
Bernhard |
June 30, 2009, 13:29 |
#108 |
Gautami Erukulla
Rep Power: 17 |
Thank you very much for your advice.I have installed bison on my machine and I could compile groovyBC library successfully. I tried to run the groovy wave tank case now.The command blockmesh worked fine.Then the command setFields also worked fine.After these two commans I wanted to check the VOF patch and so I have given paraFoam command. In paraFoam,in the object inspector if I select gamma in the Vol Field Status the paraFoam exits,with the following messages on the terminal. Can you please help me with this. Create mesh for time = 0 Reading setFieldsDict Setting field default values Setting volScalarField gamma Setting volVectorField U Setting field region values Adding cells with center within box (0 0 -1) (30 0.1 0) Setting volScalarField gamma End gali@SAI:~/OpenFOAM/gali-1.5/run/tutorials/interFoam/groovyWaveTank> paraFoam Attempt to cast type N4Foam5token8CompoundINS_4ListIdEEEE to type N4Foam5token8CompoundINS_4ListIdEEEE#0 Foam::error:rintStack(Foam::Ostream&) in "/home/gali/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/gali/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Foam::Ostream& Foam:perator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) in "/home/gali/OpenFOAM/gali-1.5/lib/linuxGccDPOpt/libgroovyBC.so" #3 Foam::Istream& Foam:perator>><double>(Foam::Istream&, Foam::List<double>&) in "/home/gali/OpenFOAM/gali-1.5/lib/linuxGccDPOpt/libgroovyBC.so" #4 Foam::Field<double>::Field(Foam::word const&, Foam::dictionary const&, int) addr2line failed #5 Foam:imensionedField<double, Foam::volMesh>::readField(Foam::dictionary const&, Foam::word const&) addr2line failed #6 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/home/gali/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libfiniteVolume.so" #7 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) addr2line failed #8 void Foam::vtkPV3Foam::convertVolFields<double>(Foam::f vMesh const&, Foam::volPointInterpolation const&, Foam::IOobjectList const&, vtkDataArraySelection*, vtkMultiBlockDataSet*) in "/home/gali/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libvtkPV3Foam.so" #9 Foam::vtkPV3Foam::updateVolFields(vtkMultiBlockDat aSet*) in "/home/gali/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libvtkPV3Foam.so" #10 Foam::vtkPV3Foam::Update(vtkMultiBlockDataSet*) in "/home/gali/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libvtkPV3Foam.so" #11 vtkPV3FoamReader::RequestData(vtkInformation*, vtkInformationVector**, vtkInformationVector*) in "/home/gali/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libPV3FoamReader_SM.so" #12 vtkMultiBlockDataSetAlgorithm::ProcessRequest(vtkI nformation*, vtkInformationVector**, vtkInformationVector*) in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libvtkFiltering.so.pv3.3" #13 vtkExecutive::CallAlgorithm(vtkInformation*, int, vtkInformationVector**, vtkInformationVector*) in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libvtkFiltering.so.pv3.3" #14 vtkDemandDrivenPipeline::ExecuteData(vtkInformatio n*, vtkInformationVector**, vtkInformationVector*) addr2line failed #15 vtkCompositeDataPipeline::ExecuteData(vtkInformati on*, vtkInformationVector**, vtkInformationVector*) addr2line failed #16 vtkDemandDrivenPipeline::ProcessRequest(vtkInforma tion*, vtkInformationVector**, vtkInformationVector*) in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libvtkFiltering.so.pv3.3" #17 vtkStreamingDemandDrivenPipeline::ProcessRequest(v tkInformation*, vtkInformationVector**, vtkInformationVector*) addr2line failed #18 vtkCompositeDataPipeline::ProcessRequest(vtkInform ation*, vtkInformationVector**, vtkInformationVector*) addr2line failed #19 vtkDemandDrivenPipeline::UpdateData(int) addr2line failed #20 vtkStreamingDemandDrivenPipeline::Update(int) in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libvtkFiltering.so.pv3.3" #21 vtkExecutive::Update() in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libvtkFiltering.so.pv3.3" #22 vtkDemandDrivenPipeline::Update() addr2line failed #23 vtkStreamingDemandDrivenPipeline::Update() addr2line failed #24 vtkAlgorithm::Update() addr2line failed #25 vtkAlgorithmCommand(vtkClientServerInterpreter*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&) in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libvtkFilteringCS.so" #26 vtkMultiBlockDataSetAlgorithmCommand(vtkClientServ erInterpreter*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&) in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libvtkFilteringCS.so" #27 vtkPV3FoamReaderCommand(vtkClientServerInterpreter *, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&) in "/home/gali/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libPV3FoamReader_SM.so" #28 vtkClientServerInterpreter::ProcessCommandInvoke(v tkClientServerStream const&, int) in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libvtkClientServer.so" #29 vtkClientServerInterpreter::ProcessOneMessage(vtkC lientServerStream const&, int) addr2line failed #30 vtkClientServerInterpreter::ProcessStream(vtkClien tServerStream const&) addr2line failed #31 vtkSelfConnection::ProcessStreamLocally(vtkClientS erverStream&) in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libvtkPVServerCommon.so" #32 vtkSelfConnection::SendStreamToClient(vtkClientSer verStream&) in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libvtkPVServerCommon.so" #33 vtkProcessModuleConnection::SendStream(unsigned int, vtkClientServerStream&) addr2line failed #34 vtkProcessModuleConnectionManager::SendStream(int, unsigned int, vtkClientServerStream&, int) addr2line failed #35 vtkProcessModule::SendStream(int, unsigned int, vtkClientServerStream&, int) addr2line failed #36 vtkSMOutputPort::UpdatePipeline(double) addr2line failed #37 vtkSMSourceProxy::UpdatePipeline(double) in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libvtkPVServerManager.so" #38 pqOutputPort::getDataInformation(bool) const addr2line failed #39 pqDisplayPolicy::getPreferredViewType(pqOutputPort *, bool) const in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libpqCore.so" #40 pqDisplayPolicy::getPreferredView(pqOutputPort*, pqView*) const in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libpqCore.so" #41 pqDisplayPolicy::createPreferredRepresentation(pqO utputPort*, pqView*, bool) const addr2line failed #42 pqPendingDisplayManager::createPendingDisplays(pqV iew*) in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libpqCore.so" #43 pqMainWindowCore::createPendingDisplays() addr2line failed #44 pqMainWindowCore::qt_metacall(QMetaObject::Call, int, void**) at moc_pqMainWindowCore.cxx:0 #45 QMetaObject::activate(QObject*, int, int, void**) in "/usr/lib/libQtCore.so.4" #46 QMetaObject::activate(QObject*, QMetaObject const*, int, void**) in "/usr/lib/libQtCore.so.4" #47 pqObjectInspectorWidget::accepted() in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libpqComponents.so" #48 pqObjectInspectorWidget::accept() addr2line failed #49 pqObjectInspectorWidget::qt_metacall(QMetaObject:: Call, int, void**) addr2line failed #50 QMetaObject::activate(QObject*, int, int, void**) addr2line failed #51 QMetaObject::activate(QObject*, QMetaObject const*, int, int, void**) in "/usr/lib/libQtCore.so.4" #52 QAbstractButton::clicked(bool) in "/usr/lib/libQtGui.so.4" #53 QAbstractButtonPrivate::emitClicked() in "/usr/lib/libQtGui.so.4" #54 QAbstractButtonPrivate::click() addr2line failed #55 QAbstractButton::mouseReleaseEvent(QMouseEvent*) addr2line failed #56 QWidget::event(QEvent*) addr2line failed #57 QAbstractButton::event(QEvent*) addr2line failed #58 QPushButton::event(QEvent*) addr2line failed #59 QApplicationPrivate::notify_helper(QObject*, QEvent*) in "/usr/lib/libQtGui.so.4" #60 QApplication::notify(QObject*, QEvent*) addr2line failed #61 QCoreApplication::notifyInternal(QObject*, QEvent*) in "/usr/lib/libQtCore.so.4" #62 QETWidget::translateMouseEvent(_XEvent const*) in "/usr/lib/libQtGui.so.4" #63 QApplication::x11ProcessEvent(_XEvent*) in "/usr/lib/libQtGui.so.4" #64 ?? in "/usr/lib/libQtGui.so.4" #65 g_main_context_dispatch in "/usr/lib/libglib-2.0.so.0" #66 ?? in "/usr/lib/libglib-2.0.so.0" #67 g_main_context_iteration in "/usr/lib/libglib-2.0.so.0" #68 QEventDispatcherGlib:rocessEvents(QFlags<QEventL oop::ProcessEventsFlag>) in "/usr/lib/libQtCore.so.4" #69 QGuiEventDispatcherGlib:rocessEvents(QFlags<QEve ntLoop::ProcessEventsFlag>) in "/usr/lib/libQtGui.so.4" #70 QEventLoop:rocessEvents(QFlags<QEventLoop::Proce ssEventsFlag>) in "/usr/lib/libQtCore.so.4" #71 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsF lag>) in "/usr/lib/libQtCore.so.4" #72 QCoreApplication::exec() in "/usr/lib/libQtCore.so.4" #73 pqProcessModuleGUIHelper::RunGUIStart(int, char**, int, int) in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libpqCore.so" #74 vtkProcessModule::StartClient(int, char**) in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libvtkPVServerCommon.so" #75 vtkProcessModule::Start(int, char**) in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libvtkPVServerCommon.so" #76 vtkProcessModuleGUIHelper::Run(vtkPVOptions*) in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libvtkPVServerCommon.so" #77 pqMain::Run(QApplication&, pqProcessModuleGUIHelper*) in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libpqCore.so" #78 main in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/paraview" #79 __libc_start_main in "/lib/libc.so.6" #80 vtkObject::RegisterInternal(vtkObjectBase*, int) in "/home/gali/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/paraview" From function dynamicCast<To>(From&) in file /home/gali/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/typeInfo.H at line 87. FOAM aborting /home/gali/OpenFOAM/OpenFOAM-1.5/bin/paraFoam: line 83: 21555 Aborted paraview --data=$caseFile gali@SAI:~/OpenFOAM/gali-1.5/run/tutorials/interFoam/groovyWaveTank> Thank You, Gautami. |
June 30, 2009, 14:05 |
#109 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Edit the system/controlDict. Change the line that says libs ("libgroovyBC.so"); (or similar) to libs ("libOpenFOAM.so" "libgroovyBC.so"); For normal programs this should make no difference but for paraview it is quite important. Bernhard |
June 30, 2009, 14:30 |
#110 |
Gautami Erukulla
Rep Power: 17 |
Thank you,thanks a lot really. I could run the case successfully now. Regards, Gautami. |
June 30, 2009, 14:51 |
#111 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
You're welcome
I just checked: the fix was already described on the Wiki-page. @Eric Paterson: If you read this. Could you incorporate this fix into the next tar of groovyWaveTank that you upload (for the benefit of the poor non-Macians)? Bernhard |
September 21, 2009, 11:05 |
#112 | |
David GISEN
Rep Power: 17 |
I have a problem getting the "groovywavetank" test case running. After trying with OF 1.6 (where I had a lot of trouble because of the changes) I tried to run it in OF 1.5. I compiled groovyBC with Bison 2.3, because it was the newest I found in Synaptic, it seemed to work fine. blockMesh and setFields worked too, but when I try to start interFoam, I get:
regards David Last edited by David*; September 22, 2009 at 05:27. |
September 21, 2009, 14:38 |
#113 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Bernhard PS: It has nothing to do with groovyBC. For once i didn't mess anything up |
September 22, 2009, 06:38 |
#114 |
David GISEN
Rep Power: 17 |
Thank your for your help, I got it working. Maybe the example was created using a dev-Version? For my OF 1.5 it works with the fvSolution posted below.
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: dev | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { pcorr PCG { preconditioner GAMG; tolerance 1e-3; relTol 0; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; nBottomSweeps 2; cacheAgglomeration false; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; maxIter 100; }; pd GAMG { tolerance 1e-8; relTol 0.05; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration false; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; }; pdFinal PCG { preconditioner DIC; tolerance 1e-7; relTol 0; /* preconditioner GAMG; tolerance 1e-8; relTol 0; // nVcycles 2; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration false; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; maxIter 20; */ }; U smoothSolver { smoother GaussSeidel; tolerance 1e-6; relTol 0; nSweeps 1; }; k PBiCG { preconditioner DILU; tolerance 1e-08; relTol 0; }; B PBiCG { preconditioner DILU; tolerance 1e-08; relTol 0; }; nuTilda PBiCG { preconditioner DILU; tolerance 1e-08; relTol 0; }; } PISO { momentumPredictor no; nCorrectors 3; nNonOrthogonalCorrectors 0; nGammaCorr 1; nGammaSubCycles 3; cGamma 1; pdRefCell 0; pdRefValue 0; pRefProbe { fields (pd); probeLocations ((0.51 0.51 0.51)); }; } // ************************************************************************* // |
February 3, 2010, 23:10 |
#115 | |
Jiang
Rep Power: 17 |
Dear grtabor, Do you have used directMapped condition for turbulent inlet ? It seems that OpenFOAM can only simplely map the internal plane value to the inlet. but I want to do like this :return the internal value multiply an function of z to the inlet. eugene said maybe you can do this. Could you give me some suggestions ? Thank you very much. |
July 2, 2010, 10:56 |
#116 |
Tobias Holzinger
Rep Power: 17 |
Hey Daniele,
did you solve the problem? It seems, I need to do it quite similar. Do you have some code snippets for me? Thanks in advance! Tobi |
August 1, 2010, 09:52 |
#117 |
Robert
Rep Power: 16 |
Hi Eveyone,
I want to implement a transient boundary conditions, hence I need boundaryData file under constant. However,the problem is the property that I want to vary with time is dimensionedScalar (No_Read in CreateFields.H) instead of volScalarField. What can I do to implement this? I have tried to put this in the solver, but doesn't work. if (runTime.value() > 500) { Q = 600; } else { Q = 0; } Suggestions will be very much appreciated. Thanks in advance. Robert |
August 2, 2010, 03:10 |
#118 | |
Tobias Holzinger
Rep Power: 17 |
what exactly does not work? Is there any error message? Tobi |
August 2, 2010, 03:22 |
#119 |
Robert
Rep Power: 16 |
Hi Toby,
I'm using pimpleFoam plus other bits of codings from different solvers. I can check the Q in the time folder and see that in the nonuniformList <scalar> not everything is zero which means the loop doesn't work. Kind Regards, Robert |
August 2, 2010, 06:22 |
#120 | |
Tobias Holzinger
Rep Power: 17 |
Hi Robert,
did you try something like Quote:
Tobi |
Transient boundary conditions | Dave | FLUENT | 5 | October 30, 2011 09:58 |
Transient boundary conditions in CFX | Sohail Ahmed | CFX | 2 | December 11, 2007 14:01 |
Transient boundary conditions | Yannick | FLUENT | 6 | November 6, 2007 08:47 |
Transient Boundary Conditions | James Date | CFX | 5 | September 13, 2004 12:34 |
