Boundary conditions for known pressure drop
Old   January 7, 2016, 13:59
Default Boundary conditions for known pressure drop
Thomas Oliveira
t.oliveira is on a distinguished road
Dear all,
I am simulating the flow of water across the domain shown in figure original.png attached. Would you have any suggestions for the appropriate boundary conditions for this case?
The water flows in the white region (which seems disconnected in this slice, but is connected in 3D). The black regions are impermeable walls where the no-slip condition applies. The pressure is constant along the inlet (red) face, and constant along the outlet (blue) face. The pressure drop is known.
I am struggling to find out which are the appropriate boundary conditions, for pressure p and velocity v, in the inlet, outlet and walls.
One of my innumerous tries was:
walls
- p: zeroGradient
- v: fixedValue, uniform (0 0 0)
inlet
- p: fixedValue, $p_in
- v: zeroGradient
outlet
- p: fixedValue, $p_out
- v: zeroGradient
but the results weren't physically correct. Moreover, I am not comfortable with the choice of zeroGradient for v at the inlet and outlet, I don't see any physical reason for such.
Another try involved mirroring the mesh (figure mirrored.png attached) and doubling the pressure drop (it is a Stokes flow, so I can do it). This would allow me to apply a periodic boundary condition for the velocity. However, the pressure field is not periodic, and OpenFOAM apparently do not accept a periodic boundary condition for one field (v) and not for the other (p).
Thank you for your attention,
Thomas
t.oliveira is offline   Reply With Quote
Old   January 7, 2016, 18:55
Wouter van der Meer
wouter is on a distinguished road
Hello Thomas,
I think numerically this is very hard to do. I would advice to make an iteration where you select the outlet pressure and the inlet velocity and than change the inlet velocity until you inlet pressure is the one you want.
Hope this helps
Wouter
wouter is offline   Reply With Quote
Old   February 1, 2016, 10:52
Thomas Oliveira
Thanks, Wouterfor the suggestion.
What really worked was using one of the traditional solution algorithms for pressure-velocity coupling.
Old   February 1, 2016, 12:02
Olivier
olivierG is on a distinguished road
hello,
Seems too late, but there is a new BC in OF3.0+ :"pressurePIDControlInletVelocity" which seems to do what you want.
(see here http://www.openfoam.com/version-v3.0...ndTunnelNozzle )
regards,
olivier
olivierG is offline   Reply With Quote
Old   March 4, 2016, 14:46
Thomas Oliveira
Thank you, Olivier! It is never too late. It calls my attention to all the new BCs available on OF 3.0.
boundary conditons
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Boundary conditions for known pressure drop t.oliveira OpenFOAM Running, Solving & CFD 0 January 5, 2016 23:04
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 12:14
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 06:58
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
