writeFormat and timeFormat in functions subDict in controlDict
Old   November 7, 2015, 05:53
Default writeFormat and timeFormat in functions subDict in controlDict
Karelke Yu
cfdopenfoam is on a distinguished road
deal foamers,
i am wondering if we can set the writeFormat and timeFormat in functions sub-dictionary in the controlDict.
the functionObjects i am using are faceSource and cellSource. and i test with
writeFormat bababa;
timeFormat bababa;
both not work. no error message. and the timeFormat and writeFormat set in controlDict seem not valid for data output by functionObject.
if there is a method to do this, please give me some hints.
thanks for your attention.
cfdopenfoam is offline   Reply With Quote
Old   November 8, 2015, 15:22
Retired Super Moderator
Bruno Santos
Quick answer: I've checked the source code and those controls are not available independently for each function object.
As for the format... yeah, it's hard-coded to a specific format: https://github.com/OpenFOAM/OpenFOAM...jectFile.C#L39
Please report this in the bug tracker: http://www.openfoam.org/bugs/
Old   November 20, 2015, 02:43
Karelke Yu
thanks for your reply. too much current work made this belated.
i will report it right now.
Old   March 5, 2021, 09:29
Lukas Fischer
lukasf is on a distinguished road
have there been any changes for the most recent versions?
I found a source for OpenFOAM V2006
(https://www.openfoam.com/documentati...8H_source.html)
which says to use
     surfaces
         type            surfaces;
         fields          ( p );
         surfaceFormat   boundaryData;
         formatOptions
             boundaryData
                 format  binary;
         surfaces
             outlet
                 type            patch;
                 patches         (outlet);
                 interpolate     false;
but it does not work for v1902 (the files are still in ASCII format).
I found the file OpenFOAM-v1912/tutorials/incompressible/pimpleFoam/LES/vortexShed/system/controlDict
in which the same code is used for ensight. It works for e.g. the ensight format but not for boundaryData which is just written in ASCI.
    cuttingPlane
        type            surfaces;
        libs            (sampling);
        writeControl    timeStep;
        writeInterval   1;
        timeStart       0;
        surfaceFormat   boundaryData; //ensight;
        formatOptions
            boundaryData //ensight
                format binary;
                collateTimes true;
        fields          (U);
        interpolationScheme cellPoint;
        surfaces
            zNormal
                type            cuttingPlane;
                planeType       pointAndNormal;
                pointAndNormalDict
                    point       (0 0 -0.01);
                    normal      (0 0 1);
                interpolate     false;
I might give OpenFOAM V2006 a try.
Best regards,
Lukas
lukasf is offline   Reply With Quote
Forces not calculated when including a library in controlDict fusij OpenFOAM 2 May 13, 2011 08:25
