strange behavior in interPhaseChangeFoam
Old   June 15, 2015, 11:23
Default strange behavior in interPhaseChangeFoam
Huang Xianbei
huangxianbei is on a distinguished road
Hi,all:
I'm doing a cavitation simulation around the hydrofoil recently with interPhaseChangeFoam. However, I found quite strange results from this solver.
Description of my model: A hydrofoil fixed in a channel , the free stream velocity (inlet velocity is U = 5.33m/s), the cavitation number is defined as : a = (p_out - p_sat)/(0.5*rho*U^2)=1.25, as in interPhaseChangeFoam, the reference pressure is set to 0 Pa by default, the pressure in the calculation is the absolute pressure. Therefore, p_out = 20055.6 Pa according to the definition of the cavitation number.
The mesh used is about 20000 elements, with yPlus ranging from 37 to 267, which is suitable to use the wall function.
First of all, I ran a case (3D, 0.5 million cells) in simpleFoam to see the pressure distribution under noncavitating condition, here is the comparison with experiment.
The result is in acceptable agreement with exp
huangxianbei is offline   Reply With Quote
Old   June 15, 2015, 11:29
Huang Xianbei
As 3D simulation is time consuming, I study 2D case in interPhaseChangeFoam.
Still, I'd like to see if the noncavitating case agrees with the exp. So I set the following boundary conditionsthe estimation of k and epsilon can be found http://openfoamwiki.net/index.php/TurboECPGgi2D and http://support.esi-cfd.com/esi-users/turb_parameters/)
alpha1:
INLET
        type            fixedValue;
        value           $internalField;
    OUTLET
        type            inletOutlet;
        inletValue      $internalField;
   UPWALL
        type            zeroGradient;
    BOTTOMWALL
        type            zeroGradient;
    PART_1
        type            zeroGradient;
     frontAndBackPlanes
        type            empty;
epsilon:
INLET
        type            fixedValue;
    OUTLET
        type            inletOutlet;
    UPWALL
        type            epsilonWallFunction;
    BOTTOMWALL
    PART_1
     frontAndBackPlanes
        type            empty;
k:
INLET
        type            fixedValue;
    OUTLET
        type            inletOutlet;
    UPWALL
        type            kqRWallFunction;
    BOTTOMWALL
    PART_1
     frontAndBackPlanes
        type            empty;
nut:
    INLET
        type            calculated;
        value           uniform 0;
    OUTLET
        type            calculated;
        value           uniform 0;
    UPWALL
        type            nutkWallFunction;
        value           uniform 0;
    BOTTOMWALL
        value           uniform 0;
    PART_1
        value           uniform 0;
     frontAndBackPlanes
        type            empty;
p_rgh
INLET
        type            zeroGradient;
    OUTLET
        type            fixedValue;
    UPWALL
        type            buoyantPressure;
    BOTTOMWALL
    PART_1
     frontAndBackPlanes
        type            empty;
U
INLET
        type            fixedValue;
    OUTLET
        type            pressureInletOutletVelocity;
        phi             phi;
    PART_1
        type            fixedValue;
        value           uniform (0 0 0);
    UPWALL
        type            fixedValue;
    BOTTOMWALL
        type            fixedValue;
     frontAndBackPlanes
        type            empty;
Old   June 15, 2015, 11:37
Huang Xianbei
the transportProperties:
phaseChange on;
//transportModel Newtonian;
//nu nu [0 2 -1 0 0 0 0] 1e-6;
phaseChangeTwoPhaseMixture SchnerrSauer;
pSat             pSat       [1 -1 -2 0 0]    2300;   // saturation pressure
sigma           sigma [1 0 -2 0 0 0 0] 0.07;
phase1
    rho             rho [1 -3 0 0 0 0 0] 1000;
phase2
    nu              nu [0 2 -1 0 0 0 0] 4.273e-04;
    rho             rho [1 -3 0 0 0 0 0] 0.02308;
SchnerrSauerCoeffs
    n               n      [0 -3 0 0 0 0 0]     1.6e+13;
    dNuc            dNuc   [0 1 0 0 0 0 0]      2.0e-06;
    Cc              Cc     [0 0 0 0 0 0 0]      1;
    Cv              Cv     [0 0 0 0 0 0 0]      1;
fvSchemes:
ddtSchemes
    default              Euler;
interpolationSchemes
    default              linear;
divSchemes
    default              none;
    div(rhoPhi,U)        Gauss linearUpwind grad(U);
    div(phi,epsilon)       Gauss linearUpwind grad(epsilon);
    div(phi,k)           Gauss linearUpwind grad(k);
    div(phi,alpha)       Gauss vanLeer;
    div(phirb,alpha)     Gauss interfaceCompression;
gradSchemes
    default              Gauss linear;
laplacianSchemes
    default              Gauss linear limited 0.5;
snGradSchemes
    default              none;
    snGrad(pd)           limited 0.5;
    snGrad(rho)          limited 0.5;
    snGrad(alpha1)       limited 0.5;
fluxRequired
    default              none;
    p_rgh;
    pcorr;
    alpha1;
fvSolution
solvers
    alpha1
        maxUnboundedness 1e-5;
        CoCoeff          2;
        maxIter          5;
        nLimiterIter     2;
        solver           PBiCG;
        preconditioner   DILU;
        tolerance        1e-12;
        relTol           0.1;
    "(U|k|epsilon)"
        solver          PBiCG;
        tolerance       1e-06;
        relTol          0.1;
    "(U|k|epsilon)Final"
        solver          PBiCG;
        tolerance       1e-06;
        relTol          0;
    p_rgh
        solver           GAMG;
        tolerance        1e-8;
        relTol           0.1;
        smoother         DICGaussSeidel;
        nPreSweeps       0;
        nPostSweeps      2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator     faceAreaPair;
        mergeLevels      1;
        maxIter          50;
    pcorr
        $p_rgh;
        relTol           0;
    p_rghFinal
        solver            PCG;
        preconditioner
            preconditioner  GAMG;
            tolerance        1e-6;
            relTol           0;
            nVcycles         2;
            nPreSweeps       0;
            nPostSweeps      2;
            nFinestSweeps    2;
            cacheAgglomeration false;
            mergeLevels      1;
        tolerance        1e-7;
        relTol           0;
        maxIter          50;
PIMPLE
    momentumPredictor          no;
    nOuterCorrectors           1;
    nCorrectors                2;
    nNonOrthogonalCorrectors   1;
    cAlpha                     0;
    nAlphaCorr                 1;
    nAlphaSubCycles            1;
relaxationFactors
    fields
    equations
        "U.*"                      1;
As can be seen , all the settings are the same with the tutorial: cavitatingBullet
The resulting Cp at x/l = 0.1 is about -2, which is much lower than the exp, indicating a much lower pressure than exp. While the calculation is at least stable.
I used to think the time scheme may affect the result, so I change it to the second order backward/ Crank , however, the two schemes used can easily lead to overflow>
I have got stuck on this problem for days Is there anyone who can tell me what's wrong? Any advice is appreciated.
Best regards
Xianbei
Old   May 18, 2017, 05:46
tommaso da vinci
l.eonardo is on a distinguished road
Hallo to everyone in the Forum.
Huang,
have you figured out how to improve your model to avoid an over estimation of the cavitating phenomena? I have, more or less, the same set up you use and I obtain a cavity longer than the experimental.
Thank you in advance
Tom
l.eonardo is offline   Reply With Quote
Old   May 18, 2017, 21:46
Huang Xianbei
Huang,
Tom
Hello:
The reference is here:
http://www.tfd.chalmers.se/~hani/kur...ChangeFoam.pdf
The major modification is:
from
max(p - pSat(), p0_)/max(p - pSat(), 0.01*pSat()),
to
max(p - pSat(),p0_)/max(p - pSat(), 0.001*mag(pSat())),
Meaning that the model is more sensitive to the vaporization or condensation.
Maybe this method can improve your results.
Xianbei
Old   May 21, 2017, 16:28
Default Differences of InterPhaseChangeFoam between OF 2.3 and OF 4.1
Stefano Gaggero
Mashiro5 is on a distinguished road
Dear All,
I'm having similar problems in the case of simple cavitation estimation using interPhaseChangeFoam.
My test case is the well known NACA66 hydrofoil by Shen and Dimotakis (Shen YT and Dimotakis PE. The influence of surface cavitation on hydrodynamic force. In: Proceedings of the 22nd ATTC, St. Johns, NL, Canada, 8–11 August 1989, pp.44–53.).
I already simulated this hydrofoil using OpenFOAM 2.3 with quite satisfactory results.
When I moved to OpenFOAM 4.1, I re-ran some old calculations to check if everything behaves similarly.
Unfortunately this is not the case. As you can see from the figures below, using OF 4.1 leads to significantly longer cavity bubbles (longer than OF 2.3 and in turn, to the experiments).
Calculations have been carried with exactly the same setup: same mesh, same numerical schemes (except for the new conventions in fvSchemes of OF 4), same numerics (exactly the same fvSolution file). Calculations were initialized with the same non-cavitating calculations in order to provide a realistic estimation of the pressure around the hydrofoil and avoid/limit the initial transient.
Do you have any explanation circa these differences?
Many thanks,
Stefano
Mashiro5 is offline   Reply With Quote
interphasechangeFoam: strange residual behaviour with keps and kwSST shipman OpenFOAM Post-Processing 1 June 14, 2014 09:58
Problem with INTERPHASECHANGEFOAM shipman OpenFOAM 2 March 26, 2014 13:36
InterPhaseChangeFoam ERROR shipman OpenFOAM Running, Solving & CFD 37 March 23, 2014 13:43
Wrong forces on a 2D airfoil using interPhaseChangeFoam Artur OpenFOAM 0 August 7, 2013 12:38
Bug about MULES::implicitSolve for interPhaseChangeFoam in OF-1.6 chiven OpenFOAM Bugs 18 April 18, 2013 23:56
