bad momentum source, vortice direction with twoPhaseEulerFoam and non-ortho meshes
Old   February 5, 2015, 05:20
Default bad momentum source, vortice direction with twoPhaseEulerFoam and non-ortho meshes
cutter is on a distinguished road
I'm observing nonphysical results when using twoPhaseEulerFoam on non-orthogonal meshes. I'm trying to simulate a long tank with rigid lid and aeration (usage of a simplified geometry in order to track down the problem):
The inflow of air is supposed to introduce large vortices and lead to mixing of the fluid. These results can be observed when using complete orthogonal hexaedral meshes:
Whenever I try to use somewhat skew or non-orthogonal meshes the whole simulation either blows up or yields wrong results (wrong direction of vortices!). There seems to be an artificial source of momentum:
I already tried to use non-orthogonal correction loops and different numerical schemes. This issue probably relates to the following bug report: http://www.openfoam.org/mantisbt/view.php?id=1379
Please find the two sample cases illustrating the problem within this Dropbox shared folder: https://www.dropbox.com/sh/eqoaca7b9...fPLSKSiha?dl=0
None of the tutorial cases concerning air-water simulations seems to use non-orthogonal meshes or non-trivial geometries (except mixerVessel2D). Are there any example cases that match my use case closely?
Any other comments regarding case setup and boundary conditions are welcome too! I will happily provide further infos that may be required to shed some light on this issue.
Thanks
Cutter
cutter is offline   Reply With Quote
Old   February 11, 2015, 00:36
Dongyue Li
sharonyue is on a distinguished road
I would like to say this this is related to mesh, I happened to run across this problem long long time ago, this is still not solved, The only solution for me is to use hex mesh.
I downloaded your case, there is no files under 0 file. n which openfoam edition r u using?
And maybe u can just try this simple 2D case. pls see the mesh attached. Anyway, from my experience using twoPhaseEulerFoam, this solver is sensitive to mesh.
sharonyue is offline   Reply With Quote
Old   February 11, 2015, 13:55
thanks for the feedback. I will have a look at the 2D mesh.
The boundary condition files are located in the init directory. Please copy them into the 0 directory before running the solver. See run_simulation.sh for more infos! The usage of the init dir allows to recover the boundary condition files at a later point in time. They sometimes get modified by tools like setFields or screwed up by the user. This way there is always a working backup. Some people use a folder called 0.org for the same reason.
I did the tests with a recent version of OF 2.3.x.
Sorry for the short reply - I am not in the office this week. More infos next week...
Cutter
Old   February 27, 2015, 16:01
Dongyue Li
Hello!
Have u ever solved this problem?
Best,
Old   May 19, 2015, 10:45
sorry for this very late response, I've been busy with some other projects in the meantime.
The problem has (at least partially) been fixed with the patches in OpenFOAM-dev (see https://github.com/OpenFOAM/OpenFOAM-dev) during the first months of 2015 (there've been quite a lot regarding twoPhaseEulerFoam directly).
The solver is now capable to produce plausible results for the simple test case I provided in the first post of this thread and meshes similar to the 2d samples of post #2. It is also able to run much more complicated cases using irregular hex meshes produced with cartesianMesh (part of the cfMesh grid generation suite). However it constantly crashes with a similar case which differs in geometry size and some load parameters only.
Many thanks to the OF team for the ongoing development effort!
Cutter
Old   April 25, 2016, 18:17
Sami
Mehrez is on a distinguished road
Hello Foamers,
Thank you for this thread and for the great job you are doing.
I am facing the same stability issues using multiphaseEulerFoam (OpenFoam 2.3.0) with a mesh of 99% hex elements.
Is this problem solved or how can I run stable simulations using this solver (or twoPhaseEulerFoam) ?
Thank you for your answer.
Best,
Mhrz
Mehrez is offline   Reply With Quote
Old   May 27, 2016, 11:15
masoudsh is on a distinguished road
Hi Cutter
I use twophaseEulerFoam openfoam 2.4,I have problem in my case
Alpha became negative,and epsilon increases and then deltaT is reduced very much
Do you khnow how can I fix that?
Best Regards
Masoud
masoudsh is offline   Reply With Quote
Old   November 17, 2016, 15:17
please check OpenFOAM 3.0.1, there've been many important changes in the 3.x.x branch that solved some of my own issues.
Also check the latest dev versions (https://github.com/OpenFOAM/OpenFOAM-dev), there's currently quite a lot development regarding the twoPhaseEulerFoam solver.
Cutter
