Problems using a qsub (PBS) job-scheduler: "no access to tty (Bad file descriptor)"
Old   January 20, 2015, 04:15
Unhappy Problems using a qsub (PBS) job-scheduler: "no access to tty (Bad file descriptor)"
Heliana Cardenas
heliana60 is on a distinguished road
Hi Bruno!
Thank you so much, I checked and openFoam settings was trying to compile an earlier version of the open-mpi that was downloaded by ThirdParty. I fixed that and it compiled
I am now facing another little problem when I submit the queue to the cluster, it always says:
Warning: no access to tty (Bad file descriptor).
Thus no job control in this shell
This is the script I am using when I enter qsub viscofoam:
#!/bin/bash
#PBS -l walltime=100:00
#PBS -l select=1:ncpus=8:mpiprocs=8
#PBS -N th10_1e-2_sU
#PBS -q all.q
#PBS -o out # stdout and stderr
#PBS -e err
# redirect stdout and stderr
# -o log
# -e log.err
module load openmpi
mpirun -np 8 viscoelasticFluidFoam -parallel > run_par.$PBS_JOBID
Do you have any idea?
Heliana
heliana60 is offline   Reply With Quote
Old   January 24, 2015, 14:26
Retired Super Moderator
Bruno Santos
Hi Heliana,
I moved (copied) your post from here: http://www.cfd-online.com/Forums/ope...llel-mode.html - to this new thread at the correct sub-forum, since this was no longer an issue with installation.
OK, regarding your question: this seems something that should be answered by your system's administrator.
However, I did a quick search on Google for:
qsub Warning: no access to tty
and found out that this is only a warning, meant to tell you that key combinations such as Ctrl+Z will not work, mainly because the job request was sent to the cluster and there is no directly control from the current launch. You'll have to use some other command to stop or control the job you've sent to the cluster.
Best regards,
Bruno
Old   January 26, 2015, 09:39
Heliana Cardenas
Hi Bruno!
My administrator already fix it apparently the cluster was not using bash but csh and for some reason it was not following the command at the begging of my script to switch to bash. He fixed that and qsub is running.
The problem that I am facing right now is that when I run it it is like it's running somehow the case n-times (n=number of proccessors-ish) so it is actually taking longer.
I tried this in my own computer with a simple cavity case and it does the same, when I introduce:
mpirun -np 8 icoFoam -parallel > log.parallel &
it runs the case 8 times hence talking longer (it shows when i check with top-command) Am I doing something wrong??
thank you so much for your help
have a nice day!
Heliana
Old   January 26, 2015, 16:42
Bruno Santos
Quick answer:
As long the "-parallel" option is used, then the 8 processes are running the case cooperatively.
If you had not used this option, then it would truly be running the same case 8 times independently.
The problem you're seeing is that you are not at least following the rule of thumb of a minimum of 50000 cells per processor. Have a look at this blog post of mine for a ton more details on this topic: Notes about running OpenFOAM in parallel
Old   January 28, 2015, 08:14
Heliana Cardenas
thank you Bruno!
I am reading those notes now
Heliana
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 16:14
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 14:14
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
