Propeller tutorial in OpenFoam
Old   October 28, 2014, 02:42
Default Propeller tutorial in OpenFoam
Sachin
Sachin m is on a distinguished road
Has anyone tried the propeller tutorial in openFoam??
If yes let me know how to go about it.
My allrun file is not working. So iam trying to run it manually.
Can anyone help me out with the steps???
Thanks in advance.
Sachin m is offline   Reply With Quote
Old   October 30, 2014, 14:05
smraniaki is on a distinguished road
Hello Sachin,
It was yesterday I was struggling finding a case that I ran propeller case. If you've noticed, there are 2 scripts; Allrun and Allrun.pre.
Start with Allrun.pre and give it sometimes. You might think it is doing nothing, but it actually uses snappyhexamesh to triangulate the hexameshes. the mesh also seem pretty heavy cuz I had difficulty viewing that via xserver. Once you are done with the first script, the its time to run the second script(Allrun). It took my system like 20 minutes to finish running the first script. Try it this way and I hope it works.
Good luck
Smran
smraniaki is offline   Reply With Quote
Old   November 5, 2014, 02:19
chen long
Jackie Chen is on a distinguished road
Thanks in advance.
for the tutorial file you can proceed with pimpleDyMFoam
Jackie Chen is offline   Reply With Quote
Old   December 18, 2014, 01:44
Sachin
Thank you smran. I ll try it the way you mentioned and let you know with the result.
Old   December 18, 2014, 08:57
and dont forget, like Chen mentioned pimpleDyMFoam is the solver your need to run after the scripts are finished pre processing.
Good luck
Old   June 2, 2018, 07:14
Default error
shantanu mandhane
shantanumandhane is on a distinguished road
I tried to run this tutorial. After running pimpleDyMFoam and opening paraview i got this error message:
ERROR: In /home/buildslave/dashboards/buildbot/paraview-pvbinsdash-linux-shared-release_opengl2_qt4_superbuild/source-paraview/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 7266
vtkOpenFOAMReaderPrivate (0x3ed5c70): Error reading line 25 of /home/cmg10/OpenFOAM/Simulations/Practice/propellors/propeller1/0/epsilon: Unsupported directive includeEtc
thanks in advance!
shantanumandhane is offline   Reply With Quote
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
Error running Propeller Tutorial TOM01 OpenFOAM Running, Solving & CFD 2 October 16, 2013 07:44
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
Install of OpenFOAM 1.6 Error 1 Error 2 & run tutorial potac OpenFOAM Installation 3 August 27, 2009 10:04
[OpenFOAM] Error while postprocessing channelOodles tutorial in OpenFOAM 13 alberto ParaView 4 April 13, 2006 06:58
