cyclicAMI crashes in parallel when processor has faces for only on AMI patch |
April 4, 2014, 11:00 |
Andreas Groß
Rep Power: 13 |
Hi everybody,
i tried to run a case with cyclicAMI and non planar rotational patches (rotationAngle set). The case runs fine on a single or on a small number of processors. Using more processors results in cyclicAMI failing to initialize. After some observation I think that this error occurs when a processor holds faces from one ami patch but not from the other one. Please find a test case attached (pipe flow and a rotation angle of 60 deg). The case runs fine on a single processor and crashes in parallel. To reproduce run Allrun script. When the decomposition changed to force faces of both AMI patches on each processor it will run fine in parallel; change decomposeParDict to: Code:
simpleCoeffs { n (1 1 2); // n (2 1 1); delta 0.1; } Code:
--> FOAM Warning : From function void Foam::cyclicAMIPolyPatch::calcTransforms(const primitivePatch&, const pointField&, const vectorField&, const pointField&, const vectorField&) in file AMIInterpolation/patches/cyclicAMI/cyclicAMIPolyPatch/cyclicAMIPolyPatch.C at line 204 Patch areas are not consistent within 0.01 % indicating a possible error in the specified angle of rotation owner patch : side1 neighbour patch : side2 angle : 60 deg area error : 99.9978 % match tolerance : 0.0001 cyclicAMIPolyPatch::calcTransforms: patch:side1 Specified rotation: swept angle: 60 [deg] reverse transform: (0.5 -0.866025 0 0.866025 0.5 0 0 0 1) patch: side1 forwardT = 1((0.5 0.866025 0 -0.866025 0.5 0 0 0 1)) reverseT = 1((0.5 -0.866025 0 0.866025 0.5 0 0 0 1)) separation = 0() collocated = 1(0) |
April 9, 2014, 10:37 |
Andreas Groß
Rep Power: 13 |
Hey again,
seems like there was a bug in the check for the orientation of the rotation. This bug was causing the failure of AMI in parallel and the warnings in parallel and serial; please note, that there might still be warnings when decomposing the case. So here's the fix: Code:
From 5811815091ef368b64ca93eaf2027dcf353b872f Mon Sep 17 00:00:00 2001 From: AndreasG <openfoam.noHam.kwijybo.de> Date: Wed, 9 Apr 2014 15:24:16 +0200 Subject: [PATCH] fixing bug #0001260 fix the check for orientation of given rotation angle in cyclicAMI --- .../cyclicAMI/cyclicAMIPolyPatch/cyclicAMIPolyPatch.C | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-) diff --git a/src/meshTools/AMIInterpolation/patches/cyclicAMI/cyclicAMIPolyPatch/cyclicAMIPolyPatch.C b/src/meshTools/AMIInterpolation/patches/cyclicAMI/cyclicAMIPolyPatch/cyclicAMIPolyPatch.C index 91ac2b8..a7e8cbe 100644 --- a/src/meshTools/AMIInterpolation/patches/cyclicAMI/cyclicAMIPolyPatch/cyclicAMIPolyPatch.C +++ b/src/meshTools/AMIInterpolation/patches/cyclicAMI/cyclicAMIPolyPatch/cyclicAMIPolyPatch.C @@ -173,16 +173,20 @@ void Foam::cyclicAMIPolyPatch::calcTransforms reduce(transformedAreaNeg, sumOp<vector>()); reduce(area1, sumOp<vector>()); - scalar errorPos = mag(transformedAreaPos - area1); - scalar errorNeg = mag(transformedAreaNeg - area1); + // Vectors of patches are pointing to outside, so sum of master and transformed + // slave patch has to zero - AG 2014/04/09 + scalar errorPos = mag(transformedAreaPos + area1); + scalar errorNeg = mag(transformedAreaNeg + area1); + // Transformation RPos is transformation for neighbour patch, so local transformation + // is transpose tensor - AG 2014/04/09 if (errorPos < errorNeg) { - revT = RPos; + revT = RPos.T(); } else { - revT = RNeg; + revT = RNeg.T(); rotationAngle_ *= -1; } -- 1.8.1.4 |
bugs, cyclicami |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 02:47 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
[GAMBIT] periodic faces not matching | Aadhavan | ANSYS Meshing & Geometry | 6 | August 31, 2013 12:25 |
[blockMesh] Cyclic BC's: Possible face ordering problem? (Channel flow) | sega | OpenFOAM Meshing & Mesh Conversion | 3 | September 28, 2010 13:46 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
