June 8, 2013, 15:21 |
#21 |
Manuel Díaz Brito
Rep Power: 13 |
Well, that was my first thought and they seem to be OK. On the other hand the residuals worry me, as you can see in the attached figure they are pretty high, but I'm not able to spot where errors might come from.
June 9, 2013, 02:25 |
getting used to crappy k-Omega SST residuals
#22 |
Jose Rey
Rep Power: 18 |
I am getting used to seeing k-omega SST runs with decrepit residuals. Even when you are careful about your y+ (keeping it below 5 or even below 1 at all times) as you have been. Just run the motorbike tutorial and you will see residuals that make yours look amazing (regardless of how long you let it run). After lots of tweaking your mesh (mine come from snappyHexMesh), it is possible to improve residuals on a case by case. In the case of snappyHexMesh, sometimes less means more. When I ask snappyHexMesh to do lots of iterations, it sometimes endsup worsening the mesh.
June 14, 2013, 16:48 |
further issues
#23 |
Manuel Díaz Brito
Rep Power: 13 |
Thanks Frédéric,
I found out that for 2D Aref has to be the spanwise cell thickness, and modifying it I get proper values of c_d (for 2D-SRANS...). This was using omegaWallFunction and y1+ in the range of 4-42. When I tried with a finer mesh (aiming for y1+ about unity) the case crashes due to floating point exception before 700 iterations as seen in the attached picture. The output of checkMesh is as follows: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : checkMesh Date : Jun 14 2013 Time : 20:43:29 Host : "lyceum2" PID : 16785 Case : /home/mdb1g12/OpenFOAM/mdb1g12-2.1.1/run/sst7 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 101320 internal points: 0 faces: 201230 internal faces: 99910 cells: 50190 boundary patches: 4 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 50190 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology frontAndBack 100380 101320 ok (non-closed singly connected) inlet 347 696 ok (non-closed singly connected) outlet 231 464 ok (non-closed singly connected) wall 362 724 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-20.4992 -20.5 0) (20.5 20.5 0.00015) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 0) All edges aligned with or perpendicular to non-empty directions. Boundary openness (-5.16794e-22 -1.3413e-24 2.9497e-15) OK. Max cell openness = 2.61712e-14 OK. Max aspect ratio = 867.882 OK. Minumum face area = 1.5e-09. Maximum face area = 7.5. Face area magnitudes OK. Min volume = 1.30171e-11. Max volume = 0.001125. Total volume = 0.224971. Cell volumes OK. Mesh non-orthogonality Max: 62.0435 average: 6.24136 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.572015 OK. Coupled point location match (average 0) OK. Mesh OK. End Thanks in advance |
June 14, 2013, 17:10 |
#24 |
HECKMANN Frédéric
Rep Power: 17 |
Just to remind me, what is your Reynolds number?
June 14, 2013, 17:35 |
#25 |
Manuel Díaz Brito
Rep Power: 13 |
I'm setting up the case at Re = 3e+6
June 15, 2013, 01:38 |
#26 |
HECKMANN Frédéric
Rep Power: 17 |
Simulating a cylinder is not as easy as it might look... An airfoil is much easier to converge. How does your data look like (flow field) at 500 iterations for example? Is there any un physical properties?
You might have to try with a simple first order (upwind) at e beginning and when you get a good general flow field, you can go to second order. It is hard to convergence directly to second order a case as complicated as a flow behind a cylinder (the recirculation area is not easy to find) |
August 11, 2013, 18:15 |
#27 |
Rafael Coelho
Rep Power: 14 |
Dear All,
I sent the last two days trying to simulate this tricky problem. I had some discussions about it on: http://www.cfd-online.com/Forums/ope...tml#post444972 As Fredo well said simulate the flow around a cylinder is harder than it seems. I found on my backups some data from a similar wind tunnel experiment I did back in 2008. We where measuring the turbulence on the cylinder wake and drag wasn't the main purpose. The Reynolds was 2*10⁴ and I have two results for Cd=0.925 and on another experiment Cd=1.019. According to Schlitching Cd=1.2. Those fellows (http://www.disasterzone.net/projects...ent.pdf) also had some problems and found Cd=1.06 and Cd=0.96. After 29 attempts I am getting Cd around 1.1. I will upload the complete case to dropbox and post the link here. |
August 11, 2013, 18:32 |
#28 |
Rafael Coelho
Rep Power: 14 |
I am using a 3D domain and snappyHexMesh in order to make "scaleable" and "swapable" in case of running a different body . The bottom plane is treated as a wall (as it is on motorbike tutorial). The same case can run with pimpleFoam renaming the FvSolutions and FvScheme files.
I would like to compare some Ux results on a plane 40mm behind the cylinder. I have the analytical and experimental data of it and it will be good to compare. Does anyone kno a easy way to get this data? Thanks! |
August 13, 2013, 15:54 |
#29 |
Rafael Coelho
Rep Power: 14 |
January 15, 2016, 16:06 |
#30 |
A E
Rep Power: 10 |
Hi guys,
This is kinda an old thread, but I am just wondering whether or not you see any amplitude modulations in your responses (meaning CD or CL vs time) in your 3D simulations? I am doing the same problem in Star-CCM+ for Re = 4,000 with different RANS models, I see the modulations in SST KW results but no modulations when I use K - epsilon. Thanks, A E |
k-omega SST simulation of turbulent flow around a circular cylinder | DanM | OpenFOAM Running, Solving & CFD | 17 | October 13, 2016 14:29 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 12:47 |
Flow induced vibration of a mobile cylinder | Hooman | Main CFD Forum | 0 | December 31, 2010 09:48 |
Simulation Flow Around cylinder 3D | Jwolf | CFX | 19 | November 25, 2009 15:21 |
Flow over a cylinder | Anna | Main CFD Forum | 9 | March 24, 2006 15:32 |
