April 2, 2012, 11:44 |
#61 |
Jan Löhrmann
Rep Power: 16 |
Hi Niels,
please find attached the deepwater-case. I used a slight grading in y-direction as the wave-height is already quite small (0.02m) and I wanted to avoid further refinement to achieve 12 cells per wave-height. Thanks for your help! Regards jan |
April 2, 2012, 11:45 |
#62 |
Björn Windén
Location: National Maritime Research Institute, Tokyo, Japan
Rep Power: 14 |
Hi Niels.
Thank you for your reply. I think the air velocity option wasn't added when I downloaded it (mid January.) My waveProperties-file is attached. //Björn |
April 2, 2012, 12:10 |
#63 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi
@Jan: You have not changed the wave properties even though you have changed the water depth. This is probably the reason for the bad results in deep water - run setWaveParameters. @Björn: setWaveParameters does nothing, when it is "combinedWaves", so the wave number for your waves is computed as if there were no current; i.e. it is approximately a factor of two wrong! At present you have to compute the wave number by hand instead - I have no plans of implementing a automatic wave number computation for wave-current, as two solutions exists, thus the user should be aware of which solution is the one to be used. What you experience in the simulation is the elongation of the waves once they become free of the explicit forcing in the beginning of the relaxation zone. Kind regards, Niels |
April 2, 2012, 12:25 |
#64 |
Björn Windén
Rep Power: 14 |
Ah. I didn't think about double checking the wave number after running setWaveParameters. Thank you very much Niels! This will hopefully solve my problems.
//Björn |
April 2, 2012, 12:39 |
#65 |
Rep Power: 37 |
Actually, if you use streamFunction as a wave theory, then wave-current interaction is inherently an option, merely choose e.g. stokes drift different from 0.
Currently, however, you can only manually set those wave parameters (using the matlab script in application/utilities/misc), since I have not been able to make a stable solution from within OF. / Niels |
April 4, 2012, 06:41 |
#66 |
Jan Löhrmann
Rep Power: 16 |
Hi Niels,
thanks a lot for your help! I simply ran the Allrun-Script where setWaveParameters isn't included initially. With this command included (and the missing keywords in waveProperties) everything is running just fine! Awesome! Regards Jan |
April 5, 2012, 09:51 |
#67 |
Jan Löhrmann
Rep Power: 16 |
Sorry to bother again. I just wanted to apply waveFoam to a bit more complex case of mine. setWaveParameters went through fine but when I'm running setWaveField I get this messages:
Reading waveProperties Reading g Reading field alpha Reading field U Reading field p Setting the wave field ... OBS: noi is larger than 2. Possible error could occur: 3 OBS: noi is larger than 2. Possible error could occur: 3 OBS: noi is larger than 2. Possible error could occur: 4 OBS: noi is larger than 2. Possible error could occur: 4 OBS: noi is larger than 2. Possible error could occur: 3 OBS: noi is larger than 2. Possible error could occur: 4 Best regards Jan |
April 5, 2012, 11:04 |
#68 |
Rep Power: 37 |
Hi Jan
Yes, it is a waves2Foam problem, however, the bug has been fixed as of revision 1944, so please make an Code:
svn update Happy Easter, Niels |
April 9, 2012, 22:23 |
#69 |
Nima
Rep Power: 14 |
Dear Niels
I am using ubuntu 11.10 coupled with OF1.7 at the moment and read about the previous problems compiling waveFoam, although I have downlowded the latest release of the code I still get an error which means the solver (not the utilities) can not be compiled , the error message is sth like below : root@ubuntu:/home/nima/waves2Foam# ./Allwmake '/root/OpenFOAM/root-1.7.0/lib/linux64GccDPOpt/libwaves2Foam.so' is up to date. make[1]: Entering directory `/home/nima/waves2Foam/applications/solvers/solvers17/waveFoam' g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/opt/openfoam170/src/transportModels -I/opt/openfoam170/src/transportModels/incompressible/lnInclude -I/opt/openfoam170/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam170/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam170/src/finiteVolume/lnInclude -DOFVERSION=17 -I./../../../../src/lnInclude -IlnInclude -I. -I/opt/openfoam170/src/OpenFOAM/lnInclude -I/opt/openfoam170/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/waveFoam.o -L/opt/openfoam170/lib/linux64GccDPOpt \ -linterfaceProperties -lincompressibleTransportModels -lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -llduSolvers -L/root/OpenFOAM/root-1.7.0/lib/linux64GccDPOpt -lwaves2Foam -lOpenFOAM -liberty -ldl -lm -o /root/OpenFOAM/root-1.7.0/applications/bin/linux64GccDPOpt/waveFoam /usr/bin/ld: cannot find -llduSolvers collect2: ld returned 1 exit status make[1]: *** [/root/OpenFOAM/root-1.7.0/applications/bin/linux64GccDPOpt/waveFoam] Error 1 make[1]: Leaving directory `/home/nima/waves2Foam/applications/solvers/solvers17/waveFoam' make: *** [waveFoam] Error 2 make: Target `application' not remade because of errors. make[1]: Entering directory `/home/nima/waves2Foam/applications/utilities/misc' make[2]: Entering directory `/home/nima/waves2Foam/applications/utilities/misc/matlab' make[2]: Nothing to be done for `application'. make[2]: Leaving directory `/home/nima/waves2Foam/applications/utilities/misc/matlab' make[1]: Leaving directory `/home/nima/waves2Foam/applications/utilities/misc' make[1]: Entering directory `/home/nima/waves2Foam/applications/utilities/preProcessing' make[2]: Entering directory `/home/nima/waves2Foam/applications/utilities/preProcessing/relaxationZoneLayout' make[2]: `/root/OpenFOAM/root-1.7.0/applications/bin/linux64GccDPOpt/relaxationZoneLayout' is up to date. make[2]: Leaving directory `/home/nima/waves2Foam/applications/utilities/preProcessing/relaxationZoneLayout' make[2]: Entering directory `/home/nima/waves2Foam/applications/utilities/preProcessing/setWaveField' make[2]: `/root/OpenFOAM/root-1.7.0/applications/bin/linux64GccDPOpt/setWaveField' is up to date. make[2]: Leaving directory `/home/nima/waves2Foam/applications/utilities/preProcessing/setWaveField' make[2]: Entering directory `/home/nima/waves2Foam/applications/utilities/preProcessing/setWaveParameters' make[2]: `/root/OpenFOAM/root-1.7.0/applications/bin/linux64GccDPOpt/setWaveParameters' is up to date. make[2]: Leaving directory `/home/nima/waves2Foam/applications/utilities/preProcessing/setWaveParameters' make[1]: Leaving directory `/home/nima/waves2Foam/applications/utilities/preProcessing' Please help me finding out what should be the reason many thanks Nima |
April 10, 2012, 07:19 |
#70 |
Jan Löhrmann
Rep Power: 16 |
Hi Niels,
I updated and recompiled waveFoam. The error I mentioned last time doesn't occur anymore. What confuses me though, is that when running setWaveFields, it doesn't seem to finish the actual setting of the wave field. This command is already running for hours, which doesn't seem to be reasonable to me (although I'm running it on a mesh with 4.1 M cells). Have you a clue what could be the reason for that? Best regards Jan |
April 11, 2012, 05:15 |
#71 |
Rep Power: 37 |
Hi
@Nima: I apologise, but there was a small bug in the Allwmake script - puzzling that it has not been noticed before. The svn is update, merely type Code:
svn update @Jan: Check whether or not the setWaveField is stalling in one of the cells or whether it is just extremely slow on your computer - I have set >1M cells in minutes, where most of the time was spent on constructing the mesh. Stalling: E.g. an Info statement the loop in Code:
void setWaveField::correct() Best regards, Niels |
April 11, 2012, 16:36 |
#72 | |
Rep Power: 17 |
I had a question about the relaxation zones introducing high-frequency content with a modified waveFlume tutorial case where the domain was extended, the depth increased to give kh=4. When I refined the tutorial grid resolution using refineMesh, I saw strange behavior containing high frequencies near the beginning of the outlet relaxation zone. Here is Neils' reply to my question:
Does this mean that coarsening the outlet relaxation zone help with this issue? Greg |
April 17, 2012, 12:11 |
#73 |
Björn Windén
Rep Power: 14 |
Hi Niels.
Regarding your previous reply to my problems with using waves and current: http://www.cfd-online.com/Forums/ope...tml#post352719 (post #65) I'm still having some trouble with this. Would it be possible to enlighten me as to what would be the correct way of using waveProperties when modelling an object travelling with forward speed in waves. I have tried setting T and k in the wave properties to those of the wave without current and omega to ωe =ωwave+kU. This seems to give the correct encounter period and the wave keeps it's wavelength when it leaves the relaxation zone. However; there is still something that is not right in that the wave increases slightly in amplitude when leaving the relaxation zone (see attached image, red line is end of zone and propagation direction is left->right.) Kind regards Björn Last edited by wyldckat; December 28, 2013 at 08:50. Reason: updated the link to the other post, given the transfer of posts from the news thread |
April 17, 2012, 17:22 |
#74 |
Rep Power: 37 |
Hi Bjørn
I have never worked with such a problem, so I can hardly give a best practice help, but this question might solve your problems: What wave theory are you using and is it valid? You could e.g. test with a streamfunction wave and see, whether the wave height is correctly computed, because that theory must be valid for regular waves/regular waves superimposed on a current. Kind regards, Niels |
April 18, 2012, 02:36 |
Compilation Error
#75 |
Nima
Rep Power: 14 |
Hi Niels
thanks for updating the Svn but unfortunately I still have the problem compiling the code. I even started from the scratch compiled the OpenFOAM again myself to solve it but it still gives me the same error , I follow the wiki procedure as below , maybe you can find a mistake in what I do : 1. I download the SVN code (waves2foam) 2- create a folder named solver21 in solvers dictionary 3.paste the interFoam source code in it ( a folder named waveFoam) 4.change interFoam according to wiki 5.run ./Allwmake in the Waves2foam It is really making me sick as I have been struggling with it nearly 2 weeks now and can't solve the problem, please tell me how do you interpret the following error message!: it is a part of the message which contains the error -I. -I/home/nima/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude -I/home/nima/OpenFOAM/OpenFOAM-2.1.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/waveFoam.o /bin/sh: cannot open The: No such file make[1]: *** [Make/linux64GccDPOpt/waveFoam.o] Error 2 make[1]: Target `/home/nima/OpenFOAM/nima-2.1.x/platforms/linux64GccDPOpt/bin/waveFoam' not remade because of errors. |
April 18, 2012, 06:35 |
Waves2Foam Related Topics
#76 |
Rep Power: 37 |
The problem is in your Make/options file. You need to manually add the two first two digits replacing the long string in the brackets.
April 18, 2012, 06:37 |
#77 |
stephane sanchi
Rep Power: 18 |
I try to redo the 3Dwaves tutorial with OF-2.1.x. I'm having problem with the createBaffles command. Regards, Stephane. |
April 19, 2012, 06:54 |
#78 |
stephane sanchi
Rep Power: 18 |
How to create baffles for the 3Dwaves tutorial with OF-2.1.x.
# Create internal wall topoSet setsToZones -noFlipMap createBaffles -overwrite f0 '(internalWall internalWall)' As attachment is the topoSetDict file. Hope it can help. Regards, Stephane. |
April 19, 2012, 11:35 |
#79 |
Nima
Rep Power: 14 |
April 20, 2012, 05:28 |
#80 |
Rep Power: 37 |
Dear all,
This thread has been started to replace the discussions in the announcement thread for waves2Foam, as most activities are not related to actually announcements. Please use this thread as of now for any discussions, questions, problems or suggestions in relation to waves2Foam. Thanks a lot for your corporation, Niels |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 06:29 |
Re-Project topics | protocol | STAR-CCM+ | 0 | March 22, 2016 06:25 |
Waves2Foam Related Topics | seoseonguk | OpenFOAM Running, Solving & CFD | 0 | March 1, 2016 23:18 |
Waves2Foam Related Topics | seoseonguk | OpenFOAM Running, Solving & CFD | 0 | March 1, 2016 23:14 |
Error: "Cannot find file points" related to changing parallelized code to serial? | Suyf | OpenFOAM Running, Solving & CFD | 0 | February 12, 2015 05:31 |
