[openSmoke] libOpenSMOKE
Like Tree133Likes
Old   April 11, 2013, 15:46
Wink flameletModel 2.1
  #161
harikrishnan
hayhari is on a distinguished road
Originally Posted by Tobi View Post
Hi Harry,
1. you do not have to compile/install GSL
2. use the Flamelet-Model 2.1.x on my git repository. Its newer and some user-unfriendly setups are made there.
3. if you have the possibility use OpenFOAM 2.2.x couse I made a few output changes in the Flamelet-Model 2.2.x
https://github.com/shor-ty?tab=repositories
Hi Tobi,
Thanks for the update i have started using Flamelet-Model 2.1.x but i i am not able to create PDF library with bigger chemical kinetics file.if the number of species/reactions are more it is giving an error like
Clear folders
removed `Flamelet_0/Flamelet_1_Hz.out'
removed `Flamelet_0/Flamelet_3_Hz.out'
removed `Flamelet_0/Flamelet_2_Hz.out'
removed `Flamelet_0/Flamelet_5_Hz.out'
removed `Flamelet_0/Flamelet_8_Hz.out'
removed directory: `Flamelet_0'
removed `Logs/Log-LookUpTable0'
removed `Logs/Log-Enthalpydefect_0'
removed directory: `Logs'
removed `BzzFile.txt'
Calculation of flamelet lib with enthalpy defect 0
Finished...
Flamelets generated...
LookUpTable-Ensemble
Look-Up-Table for Flamelets with enthalpy defect 0
terminate called after throwing an instance of 'std:ut_of_range'
what(): basic_string::substr
./runFlameletGeneration.sh: line 86: 95530 Aborted ./OpenSMOKE_LookUpTable.sh --input "Input/Input_$i.inp" --kinetics "$kinetics" -build-library > Logs/Log-LookUpTable$i
Look-Up-Table for enthalpy defect 0 generated
Remove Fluent libs
Finished...
I dont know whats happening while calculating the look up table. i was using a bigger chemical kinetics file for DME. It is working well with small CRECK kinetics and GRI Mech.
please help
Thank you
Hari
hayhari is offline   Reply With Quote
Old   April 12, 2013, 02:42
Default FlameletModel 2.1.x
  #162
harikrishnan
What is the maximum number of species that can be handled by OpenSMOKE_CHEMKINInterpreter.sh
when i run this, i am getting an error
./Run.sh: line 1: 64711 Aborted
Please help
Thank you
Hari
Old   April 12, 2013, 09:51
Bobby
babakflame is on a distinguished road
Hi hayhari
I experienced the same problem, when I tried to use C1C16 polimi mechanism, Unfortunately I couldn't fix it.I think that due to lack of access to flamelet generation code
there might not be a clear answer for this problem.
Bobi
babakflame is offline   Reply With Quote
Old   April 14, 2013, 06:33
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Please help
Thank you
Hari
Normally everything should work:
1. all species must be avaiable in the three folders / files
-> kinetics
-> thermodynamics
-> transportproperties
2. As bobi told you, there is not a clear answer for you due to the binaries.
Sorry
But if there are some users that want to programm with c++ the flamelet generation new I promise that I will work with you!
There are some nice c++ libraries for beta-pdf- calculations and so on!
Tobi is offline   Reply With Quote
Old   April 19, 2013, 19:06
Retired Super Moderator
Bruno Santos
Greetings to all!
Just passing by to give some news... looks like the CRECK Modeling team has gone pro! Check it out:
I found out from their main website: http://creckmodeling.chem.polimi.it/
Best regards,
Bruno
Ohbuchi, MPJ, hayhari and 1 others like this.
Old   April 20, 2013, 05:37
Tobi's Avatar
Tobias Holzmann
Originally Posted by wyldckat View Post
Greetings to all!
Best regards,
Bruno
Sounds and looks good
Thanks bruno!
Old   April 21, 2013, 05:10
Default libOpenSMoke
  #167
harikrishnan
Flamelet n.1
DONE!
Flamelet n.2
DONE!
Flamelet n.3
DONE!
Flamelet n.4
DONE!
Flamelet n.5
DONE!
Flamelet n.6
DONE!
Flamelet n.7
DONE!
Flamelet n. 1 - Scalar dissipation rate (st.): 1 Hz
Number Of Species: 98
Number Of Points: 106
Aborted
while excecuting OpenSMOKE_LookUpTable.sh.... what is the possible fix for this error..?
Thanks
Hari
Old   April 21, 2013, 06:32
Tobi's Avatar
Tobias Holzmann
Hi Hari,
do you use the flamlet model from my github?
If yes I can not give you a solution for that. The problem (i mentioned many posts befor) is the binarys for the falmetlet generation.
Its not possible to have a look into that !!!
Therefor you are not able to resolve that problem!
But maybe there is a othre tool in the laminar tool?!
Old   April 21, 2013, 06:42
Tobi's Avatar
Tobias Holzmann
Well the laminarSmoke uses a binary execution file too
Old   April 23, 2013, 10:41
lcy
chengyi
lcy is on a distinguished road
thank you. the question is solved. I update the linux, and try again. Then it succeeds.
lcy is offline   Reply With Quote
Old   April 29, 2013, 12:42
danz is on a distinguished road
Hi Tobi,
I've posted here some questions about the flamelet libraries one and half month ago. And during that time, I was working on another model first and then on CANTERA to build my own flamelet librairies. Now, I've got the libraries and my next step is to be able to create an interface between the CFD solver and the libraries. I've one and half month to have interesting results... Is it possible?
Thanks
Danz
danz is offline   Reply With Quote
Old   April 29, 2013, 14:52
Tobi's Avatar
Tobias Holzmann
Originally Posted by danz View Post
Hi Tobi,
Thanks
Danz
Yes the implementation of your Flamelets into the OF Solver is very easy. Is your code free ?
I am interested in that stuff.
Old   April 30, 2013, 04:34
Hi Tobi,
Unfortunately, my cfd code is not free...
Now, I'm trying to create a module to read my library
Old   May 6, 2013, 03:55
Thumbs down libOpenSmoke
  #174
harikrishnan
I have made a a complex geometry in fluent and exported to OpenFoam using Fluent3dToFoam.it is having 20 patches. Then i tried to do the simulation using Flamelet model then i got the following error..
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.1.1-221db2718bbb
Exec : rhoSimpleFoamFlamelets_1007
Date : May 06 2013
Time : 12:17:23
Host : "hari-pc"
PID : 4800
Case : /home/harikrishnan/libOpenSMOKE/tutorials/rhoSimpleFoamFlamelets/fluent2
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading g
Flamelet thermodynamics...
Selecting thermodynamics package hPdfThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>>
Patch Fixed Temperature 3
Patch Fixed Temperature 4
Patch Fixed Temperature 5
Patch Fixed Temperature 6
Patch Fixed Temperature 7
Patch Fixed Temperature 8
Patch Fixed Temperature 9
Patch Fixed Temperature 10
Patch Fixed Temperature 11
Patch Fixed Temperature 12
Patch Fixed Temperature 13
Patch Fixed Temperature 14
Patch Fixed Temperature 15
Patch Fixed Temperature 16
Patch Fixed Temperature 17
Patch Fixed Temperature 18
Patch Fixed Temperature 19
Patch Fixed Temperature 20
Adiabatic mode...
Delta-Dirac Distribution for scalar dissipation rate...
OpenSMOKE_PDF_Flamelet
Index: 1
File name: PDF-Library/PDF-0/SR_1.bin
Mixture fraction points: 327
Variance Mixture fraction points: 32
Nominal strain rate: 4.94066e-324 Hz
Stoic. scalar dissipation rate: 1e-06 Hz
Temperature min: 292 K
Temperature max: 2386.94 K
Density min: 0.157304 kg/m3
Density max: 1.1982 kg/m3
Index: 2
File name: PDF-Library/PDF-0/SR_2.bin
Stoic. scalar dissipation rate: 0.0001 Hz
Temperature max: 2386.93 K
Index: 3
File name: PDF-Library/PDF-0/SR_3.bin
Stoic. scalar dissipation rate: 0.01 Hz
Temperature max: 2386.17 K
Density min: 0.157356 kg/m3
Index: 4
File name: PDF-Library/PDF-0/SR_4.bin
Stoic. scalar dissipation rate: 0.1 Hz
Temperature max: 2380.62 K
Density min: 0.157668 kg/m3
Index: 5
File name: PDF-Library/PDF-0/SR_5.bin
Stoic. scalar dissipation rate: 1 Hz
Temperature max: 2337.71 K
Density min: 0.159747 kg/m3
Index: 6
File name: PDF-Library/PDF-0/SR_6.bin
Stoic. scalar dissipation rate: 5 Hz
Temperature max: 2250.72 K
Density min: 0.164261 kg/m3
Index: 7
File name: PDF-Library/PDF-0/SR_7.bin
Stoic. scalar dissipation rate: 10 Hz
Temperature max: 2197.33 K
Density min: 0.167249 kg/m3
Index: 8
File name: PDF-Library/PDF-0/SR_8.bin
Stoic. scalar dissipation rate: 20 Hz
Temperature max: 2134.8 K
Density min: 0.170962 kg/m3
Index: 9
File name: PDF-Library/PDF-0/SR_9.bin
Stoic. scalar dissipation rate: 30 Hz
Temperature max: 2093.9 K
Density min: 0.173518 kg/m3
Index: 10
File name: PDF-Library/PDF-0/SR_10.bin
Stoic. scalar dissipation rate: 40 Hz
Temperature max: 2062.88 K
Density min: 0.175527 kg/m3
Index: 11
File name: PDF-Library/PDF-0/SR_11.bin
Stoic. scalar dissipation rate: 100 Hz
Temperature max: 1952.04 K
Density min: 0.183232 kg/m3
OpenSMOKE_PDF_NonAdiabaticFlamelet_Library
File name: PDF-Library/LookUpTable.out
Number of Enthalpy defects: 1
Minimum enthalpy defect: 0 kJ/kg
Maximum enthalpy defect: 0 kJ/kg
Adiabatic flamelets: 1
Temperature fuel: 300 K
Temperature oxidizer: 292 K
Density fuel: 0.926635 kg/m3
Density oxidizer: 1.1982 kg/m3
Enthalpy fuel: -3.87397e+06 J/kg
Enthalpy oxidizer: -115713 J/kg
Initialize basic fields...
Initialize enthalpy field (field)...
pdfThermo h(const scalarField& T, const label patchi)... end..
Calculate (first time)...
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::hPdfThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam:erfectGas> > > > >::calculate() in "/home/harikrishnan/OpenFOAM/harikrishnan-2.1.1/platforms/linux64GccDPOpt/lib/libOpenSMOKE_pdfThermo.so"
#4 Foam::hPdfThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam:erfectGas> > > > >::hPdfThermo(Foam::fvMesh const&) in "/home/harikrishnan/OpenFOAM/harikrishnan-2.1.1/platforms/linux64GccDPOpt/lib/libOpenSMOKE_pdfThermo.so"
#5 Foam::basicPdfThermo::addfvMeshConstructorToTable< Foam::hPdfThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam:erfectGas> > > > > >::New(Foam::fvMesh const&) in "/home/harikrishnan/OpenFOAM/harikrishnan-2.1.1/platforms/linux64GccDPOpt/lib/libOpenSMOKE_pdfThermo.so"
#6 Foam::basicPdfThermo::New(Foam::fvMesh const&) in "/home/harikrishnan/OpenFOAM/harikrishnan-2.1.1/platforms/linux64GccDPOpt/lib/libOpenSMOKE_pdfThermo.so"
in "/home/harikrishnan/OpenFOAM/harikrishnan-2.1.1/platforms/linux64GccDPOpt/bin/rhoSimpleFoamFlamelets_1007"
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception (core dumped)
I am relatively new to openFoam and not able to identify the reason for this error.
Also H in 0 directory is which enthalpy? enthalpy of formation??
Please help.
Thanks
Hari
Old   May 23, 2013, 08:20
Tobi's Avatar
Tobias Holzmann
Hi Hari,
that is a Setup mistake.
It seems that some BC has no "value uniform x;"
Check out your BC!!
If you wanna know if that Problem occure due to the BC you can insert a line into the hPdfThermo.C (i think that is the file) -> function calculate();
Tobi
Old   May 25, 2013, 04:44
Bobby
Hi Tobi
Thanks very much for your quick reply. When I tried simulating DLR flame, the compiler got a error from dimension of the Chi-Update equation. Although I checked the formula from your modified guide and the peters turbulent combustion book and the same equations were written there. However, from dimension error it seems that the R.H.S. must be divided by rho. If you remember, Once I asked you about a missing rho. I think now it makes sense.
Again thanks for your quick and kind reply
Regards
Bobi
Old   May 25, 2013, 05:06
Tobi's Avatar
Tobias Holzmann
Removed due to the reason in the edit line!
Old   May 25, 2013, 05:29
Tobi's Avatar
Tobias Holzmann
[quote="Tobis - Masterthesis"]
The turbulent diffusion term is modelled with the approximation of gradient diffusion:
-\frac{\partial}{\partial x_j} = (\frac{\rho}{2} \overline{u_j' u_i' u_i'}) \approx \frac{\mu_t}{\sigma_t} \frac{\partial k}{\partial x_j}
So you see that with RANS Modelling the density is in the mu_t and mu_t is modelled with the turbulence models! (k/eps).
\mu_t = C_\mu \rho q L
In LES (I think) you have a other modellation!
So it could be the reason in your calculation (missing rho).
But I have no Idea how LES is working - so try out and read litrerature
babakflame likes this.
Old   May 27, 2013, 07:14
Tobi's Avatar
Tobias Holzmann
Is it working now?
How is your eqn. for Z ? Especially the Diffusion Terms!
Old   May 27, 2013, 11:31
Bobby
Hi Tobi
Now, I am trying to solve my problem with fireFoam (flamelet/progress variable).
Very soon, I will test the LES-Flamelet code and will tell you the results.
Regards
Bobi
Numerical treatment of the source term in combustion equations Tobi Main CFD Forum 37 September 15, 2020 14:42
[openSmoke] flameletSmoke + new ODESolver (by Alberto Cuoci) Tobi OpenFOAM Community Contributions 1 November 21, 2017 19:24
Unsteady solver with Flamelet Model (libOpenSMOKE) francesco_capuano OpenFOAM Running, Solving & CFD 11 November 26, 2013 05:50
LibOpenSmoke, getting the species in ParaFoam Christoph_84 OpenFOAM 1 May 31, 2012 15:42
