[openSmoke] libOpenSMOKE
Like Tree133Likes
Old   October 6, 2014, 03:49
Bobby
babakflame is on a distinguished road
Greetings Tobi
Actually I tried to map the LES results onto a finer grid for enhancing the accuracy level. Then I found that every time and without attention to the map type O.F. gets error on "different grid points on source and target cases".
This code constructs Look-up tables on grid points so changing the number of grid points would lead into error in combustion solution procedure. However, the accuracy of the thermodynamic tables are satisfactory.
"Hagen told me that the code should normally accept mapping. I will give it another try."
Best
Bobi
babakflame is offline   Reply With Quote
Old   October 12, 2014, 13:09
Guilherme Sempionato
sempionato is on a distinguished road
Hi all,
I'm starting to develop Openfoam codes, actually LES equations for this flamelet solver. I've seen that Bobi is trying something similar as:
chi_st=2 * (turbulence->mut()/(rho*sigmat)) * magSqr(fvc::grad(Z));
My question is: can all mut in Z equation be changed for muSgs? If positive, is this the only modification for LES equations in this solver?
I have already modified the essential files (options, files, createFields, etc)
Thanks!
sempionato is offline   Reply With Quote
Old   October 13, 2014, 02:58
Bobby
Greetings Guilherme
Two equations differ between RAS and LES in steady flamelet approach:
1- scalar dissipation term
2- mixture fraction variance
If you follow this thread posts, you will find out exactly what terms you need to put into your LES solver.
Best,
Bobi
Old   October 13, 2014, 18:32
Thanks by your fast reply Bobi,
I have changed my code as you suggested in the January 3 2014 posts, but, observing LESModel.H in the Muller code I see:
virtual const volScalarField& delta() const
return delta_();
After the modifications the code insists in try to find delta() in the algebraic equation suggested for LES.
How did you solve this?
Thanks!
Old   October 14, 2014, 04:39
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
return delta_();
Thanks!
please notice that Müllers Code is not Cuocis code. Its a other way of implementing! A lot of ways leed to roma (;
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   October 15, 2014, 09:03
Bobby
Greetings Guilherme
I have not get enough time to investigate Hagen source code strictly. However for hinting you I can say that for mixture fraction variance equation you need to define a Delta in LES approach. This Delta again appears in Subgrid scale modeling. So please investigate this thread posts exactly, I guess my formulation is in the posts, If not I will put it in next posts.
Sorry for insufficient time.
Best
Bobi
Old   November 10, 2014, 18:00
Tobi's Avatar
Tobias Holzmann
Hi all,
I had a discussion with Bernhard last monday and I will check out if I can make a WIKI entry and collect all the stuff which is mentioned in that thread.
But I want to tell you that the flameletModel is now available here:
https://bitbucket.org/shor-ty/flameletmodel
Keep foaming,
Tobias Holzmann
Old   November 13, 2014, 10:05
Hi Bobi, thanks by your answer! Thanks to Tobi too!
I am also with a short time to dedicate for now, very bad for a OpenFOAM novice, but I got, after your hints and some study of the Pitsch and Peters papers, two equations for LES description:
ZvarCells = Cv*sqr(turbulence->delta())*magSqr(Z)
and
chi_st=Cx*(turbulence->muEff()/(rho*sigmat))*magSqr(fvc::grad(Z));
The problem that I have for now, in the same geometry of the original RANS case, is that the flame is very long and there is no significative radial difusion as is showed in the picture below.
http://i58.tinypic.com/5kr4n7.png
Changing for a 3D sector geometry, with ~300.000 elements, I have encountered that, in the adustableTimeStep mode, the time step goes to zero, but, with fixed time step, the solver gives the same strange flame that is saw in the 2D case.
I think that changing boundary conditions this strange flame behavior will not change... It someone already did a LES sucessfull implementation in this solver and encountered this error?
Thanks!
Old   November 13, 2014, 10:14
Bobby
Greetings Guilherme
HHmmmmm....
First of all, pay attention that for a strict LES simulation implement a 3D simulation. If you perform a 3D simulation. (Do not use wedge-typed grid for LES simulations) Then you will have accurate radial diffusion.
The problem of your case is implementing LES in an axisymmetric domain.
Try it again buddy; you will get correct results.
I will post comprehensive hints on performing LES and RAS simulations correctly with both Alberto and Hagen Codes in a few days.
Best
Bobi
Tobi likes this.
Old   November 13, 2014, 10:45
Talking
  #410
Thaks Bobi, I will be waiting for your hints! In this moment i am running a 3D code with fixed time step (the adjustable one tends to zero I dont know why). Later I will post the results and the mesh.
Old   November 23, 2014, 10:03
Bobby
Greetings All
The followings are hints for you with your flamelet simulations.
Flamelet Tables
The difference between codes of Hagen and Alberto is considering non-adiabatic terms. These terms are not included in Hagen flamelet equations. On the other hand, although Alberto's code considers these terms (i.e. radiation), the method of radiation implemented in the code is not applicable to heavy fuels. It doesn't incorporate soot radiation.
Both methods are roughly fast. Alberto tool does not show you extinction (you just choose some values for scalar dissipation rate and the tool computes the tables for these values without locating the extinction point). In cantera tool, you will find out scalar dissipation rate of quenching
\chi_Q by gradually increasing chi. After reaching extinction , the temperature would always be in room condition.
RAS and URAS
There are some methods for defining fully-developed flow fields such as coding with the help of swak4Foam or reading inlet velocity boundary from file (refer to: http://www.openfoam.org/version2.1.0...conditions.php)
Although there are distinct methods, the best method is extending the boundary condition to upstream to ensure fully-developed flow field.
For RAS and URAS simulations, probably the best grid is a wedge-typed one to reduce computational cost.
LES
For LES simulation, do not use wedge-typed grids. This will culminates in false radial diffusion of mixture fraction. Implement your simulations with 3D grids.
A verified method is solving your fully-developed inflows in a separated tube (using RhoPimpleFoam not incompressible solvers). Afterwards, map the outlet velocity of tube for your inflow in the main computational domain.
Use the following as a sample for your inlet from a pre-solved tube:
FUEL
        type            turbulentInlet;
        referenceField  nonuniform List<vector>
252
(-0.296506256 142.798641 0.146544894)
    fluctuationScale (0.03 0.1 0.03);
        value           nonuniform List<vector>
252(
For your pipe simulation, use inletOutlet BC to write down the outlet velocity of the tube separately.
Keep focus that the configuration of the pipe should be identical to the injection plane. Use comparable mesh resolution for the outlet plane of tube and injection plane in the main domain.
For simulating swirl cases with LES, focus on the outlet pressure BC. Try mixedValue or waveTransmissive ones to prohibit fluctuations enter your domain in not sufficiently large computational domains.
Best,
Bobi
Likun and wenxu like this.
Old   November 26, 2014, 05:18
Bobby
Greetings All
I have received private messages asking for more detailed hints. I will add some points according to these questions to the previous post.
Best,
Bobi
Old   November 26, 2014, 08:22
Tobi's Avatar
Tobias Holzmann
Hi all,
I will sum everything which was discussed here and put it in that wiki site:
http://openfoamwiki.net/index.php/LibOpenSMOKE
wyldckat likes this.
Keep foaming,
Tobias Holzmann
Old   December 4, 2014, 16:46
Retired Super Moderator
Bruno Santos
Greetings to all!
FYI: Since Tobi deleted his account at Github, I also eliminated the mirror mentioned in post #197 and created a new mirror for this new repository: http://repo.or.cz/w/shor-ty-flameletmodel.git
To git clone from it, use either one of the following commands:
  • Code:
    git clone git://repo.or.cz/shor-ty-flameletmodel.git
  • Code:
    git clone http://repo.or.cz/r/shor-ty-flameletmodel.git
For those who don't have git, use one of the snapshot links from here: http://repo.or.cz/w/shor-ty-flameletmodel.git/tree
Best regards,
Bruno
PS: I'll edit the original post that had links to the old repositories and leave a note on which post the new ones are mentioned.
Tobi likes this.
Old   December 4, 2014, 17:31
Tobi's Avatar
Tobias Holzmann
Thanks Bruno,
sorry that I change so many things
But now everything is at the right place.
Also thanks for adding the libOpenSMOKE wiki page to the contribute.
Keep foaming,
Tobias Holzmann
Old   January 1, 2015, 02:24
Freedom
wenxu is on a distinguished road
Hello,Bobi,
Do you familiar with the Cantera solver? Now i try Hagen's code and using cantera to generate flamelet library. But i do not know what's the mixture fraction based on? That to say, it's definition is based on one-step reaction or Bilger's definition(based on element)?
Also i find that OpenSMOKE has a runFlameletGeneration.sh in flameletGeneration folder, but i can not find the details how the library is generated? ---i can not find the source code because most of them is binary files. BTW, why not choose FlameMaster to generate flamelet library which is the common choose.
Best regards,
wenxu
wenxu is offline   Reply With Quote
Old   January 1, 2015, 11:23
Bobby
Greetings Wenxu
AFA I know, the cantera-based look-up table constructor is based on Bilger's definition i.e. elements.
Detail your problem with any of look-up table makers more clearly, I hope to be capable of helping.
Best,
Bobi
Old   January 1, 2015, 21:56
Freedom
Thank you very much, Bobi,
The details of my problem is that now i want to use cantera to generate flamelet library, but the library i need seems "strange" which in the attachment 1: mixture fraction. The picture is in the paper:http://www.sciencedirect.com/science...40748914003757 when the fuel fraction becomes less, the Zst should become lager, but in the picture we can see that Zst seems stay unchanged and the maximum Z become less and less until 0.24.
But the picture of mixture fraction i get from cantera is as attachment 2: myself picture, which the maximum mixture fraction (in fuel side) is always 1 and is different from the paper.
So i should redefine the mixture fraction in cantera, right? If not , how can i get it? Thank you very much!
Sorry for that this post have little relation with libOpenSMOKE, but useful to generate flamelet library which every one should encounter it. AFAIK the generation of flamelet library in libOpenSMOKE we MUST use binary files, so we can not see the source code and impossible to redefine the mixture fraction.
Sorry for the tedious description but i think i have describe it more clear.
best regards,
wenxu
Old   January 2, 2015, 06:46
Bobby
Greetings Wenxu
I took a short look at your reference:
What I learned is that although the writers used Flame Master for solving steady one dimensional flamelet equations, the definition of mixture fraction in their paper is completely different from conventional ones (due to modeling pulveized coal combustion). You need to redefine mixture fraction in Cantera-based code or Flame Master with considering upper bound of Mixture Fraction in this special case.
In addition, for reproducing their work, you need to apply some changes in your flow solver as well, to incorporate the transport equation of progress variable.
All in all, I could say that their work is highly reputable and not easy to reproduce.
Best,
Bobi
Old   January 22, 2015, 09:13
Freedom
Greeting to all.
Anyone has the experiences of getting the mass fraction and temperature from the flamelet library using four parameters (e.g. x, z",z, a )? In other words, how can I implement interpolation using four dimension?
Anyone can give me some hints?
regards,
wenxu
Numerical treatment of the source term in combustion equations Tobi Main CFD Forum 37 September 15, 2020 14:42
[openSmoke] flameletSmoke + new ODESolver (by Alberto Cuoci) Tobi OpenFOAM Community Contributions 1 November 21, 2017 19:24
Unsteady solver with Flamelet Model (libOpenSMOKE) francesco_capuano OpenFOAM Running, Solving & CFD 11 November 26, 2013 05:50
LibOpenSmoke, getting the species in ParaFoam Christoph_84 OpenFOAM 1 May 31, 2012 15:42
