[openSmoke] libOpenSMOKE
Like Tree133Likes
Old   July 6, 2013, 09:49
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi bobi and all,
I compiled OF-2.2.x on my laptop today and tried the flamelet model 2.2.x:
1. git clone ... is working fine (no errors)
2. flamelet libs compiled well
3. thermodynamics do not compile
That problem is solved by removing a deb file
4. flameletSimpleFoam is not compiling
That problem is going to solved. The files are "crashed" there are some nonsence lines in the files. I remove them now and clean the files
5. flameletPisoFoam is compiling
6. tutorial SIMPLE is not working due to changes in the PDF library
That problem is going to be solved
7. tutorial PISO is not working due to changes in the PDF library
Tobi
babakflame likes this.
Tobi is offline   Reply With Quote
Old   July 6, 2013, 10:18
Default flameletModel 2.2.x
  #202
Tobi's Avatar
Tobias Holzmann
Flamelet Model 2.2.x is now cleared and working without any problems.
Please test it!
Old   July 6, 2013, 12:09
Bobby
babakflame is on a distinguished road
Many Thanks to my friend Tobi
babakflame is offline   Reply With Quote
Old   July 24, 2013, 02:31
Bobby
Hi Tobi
What is the convergence criterion in your simple and piso codes and how can we increase or decrease the convergence accuracy?
I mean where should we implement the modifications?
Regards]
Bobi
Old   July 29, 2013, 07:31
Default convergence
  #205
Tobi's Avatar
Tobias Holzmann
Hi Bobi,
as you can see in the sandia-flame the residuals never go below 1e-3 - 1e-4. In that case I wait till i reach a "steady-state" residual state; like a horizontal line.
But that depend on your case. In my masterthesis it was possible to get a residual to 1e-5 but for that I decreased the relax factor strong. Further more I always save the last time steps (like every 100 iterations) and compare the differences between the slices/Clips/values to be sure that I reached a steady state solution.
Problem in most cases I had is the fact, that the combustion Chambers (in my case) never be a steady. I always realize transient movements in my values on certain Points in the geomtry.
For the transient (piso) algo I use the time, residuals and visualisation.
In the sandia-flame I get a better convergence in my Simulation but that was all I simulated with my transient solver.
Old   August 13, 2013, 05:33
Default About simpleFoamflamelet solver
  #206
sonu
yash.aesi is on a distinguished road
helo ,
After successfully running the tutorial of Sandia COH2N2 flame in flamelet model under the simplefoamflamelet solver now i want to try it for my geometry and case . i had converted my mesh file into OF , so now can anybody tell me which file i have to copy from the tutorial and kept in my working folder to solve my case ?
yash.aesi is offline   Reply With Quote
Old   August 13, 2013, 12:34
Bobby
Hi
You should make your own PDF file, 0 (initial conditions) and constant folder
for required coefficients. Just the same as Tobi tutorial.
Bobi
Old   August 14, 2013, 04:48
sonu
thanks alot bobi .....i will try as u said ....
Old   August 21, 2013, 10:04
Default Mixing of two gases with turbulentFlameletRhoSimplecFoam
  #209
TBO
TBO is on a distinguished road
The turbulentFlameletRhoSimplecFoam creates a lot of opportunities for me for steady state combustion modelling in OpenFOAM. In the end, I am very interested in simulations with chemical reactions and combustion involved and that is what this solver is doing. Also thank you for the good documentation about the chemistry involved in this solver, that is what is missing for some other chemistry solvers on CFD online.
However, I am also interested in steady state modelling of the mixing between two different gases (fuel and air). So a cold flow case without the actual chemical reaction which shows the mass or volume fractions of the different species. Is it possible to do this with turbulentFlameletRhoSimplecFoam and what do I need to change for this (e.g. in the library). I am using OpenFOAM 2.1.1.
TBO is offline   Reply With Quote
Old   August 21, 2013, 12:23
Bobby
Hi TBO
My suggestion for you for simulating cold flows is using RhoPimpleFoam and RhoSimpleFoam solvers of OpenFoam, cause their flow solvers are exactly the same as libOpenSmoke modified versions. LibOpenSmoke and its modified bversions are steady flamelet solvers which automatically spread combustion according to mixture fraction value in the domain.
Good Luck
Bobi
Old   August 22, 2013, 03:36
TBO
Originally Posted by babakflame View Post
Hi TBO
Good Luck
Bobi
Hi Bobi,
Thank you for your reply, please correct me if I'm wrong, since I'm not very experienced with OpenFOAM so far. I am already using rhoSimplecFoam for cold flow modelling, however what I would like to do is calculate the mixture fractions of different species in the domain. So for example the mixing of methane jets in an air flow. As far as I know rhoSimplecFoam can only cope with one species (if anyone can tell me how to implement several species in rhoSimplecFoam, I am very satisfied).
I already looked into other solvers, e.g. reactingFoam and there you have the possibility to switch off chemical reactions (however this solver is transient, resulting in extreme calculation times). Is there any possibility to switch off the chemical reactions (or modify the library) for the libOpenSmoke?
immortality likes this.
Old   August 22, 2013, 06:29
Bobby
Hi TBO
HTML Code:
I did not get what you mean by this sentence. However, If you mean various inlet constituents with not having combustion , you might use fireFoam cause this solver supports this option.
HTML Code:
You can insert this option for libOpenSmoke if you have sufficient knowledge of OpenFOAM and combustion, However my proposal for you is using fireFOAM in O.F. 2.2.x , cause in this version this option (the same as you want ) is added to the current combustion models. In addition, it calculates the mixture fraction of the domain without having combustion though.
I hope you find this helpful
Bobi
Old   August 22, 2013, 06:46
TBO
Hi Bobi,
Thank you for your answer. Indeed I mean various inlet constituents without having combustion.
I already looked into fireFoam (as well as reactingFoam) before, however the main problem with these solvers is that they are transient and I would like to model steady state (since this saves a lot of computational time).
I already looked into several other options (alternateSteadyReactingFoam, edcSimpleFoam). However results for these solvers are not satisfying jet and documentation/CFD online discussions are very limited.
Regards,
Old   August 22, 2013, 12:15
Bobby
Hi TBO
HTML Code:
I should mention that these solvers are totally different and if you use them you can find out that why I proposed you firefoam with no combustion model (so much faster than reactingfoam with off chemistry). Although you are right. Both of them use piso algorithm which is a transient flow solver.
HTML Code:
I am still sure that you can use RhoSimpleFoam for your aim
HTML Code:
Ask your question in forum (not this one), You will get your answer
Bobi
Old   September 16, 2013, 06:41
parsa
parsa_abbasi is on a distinguished road
Dear All,
I'm doing also the same job with OpenFoam, but until now, i didn't get the semialer result as I got in Transient mode. I made several steady-State Solvers, but seems that No Combustion happens! I'm using the 'psi Combustion Model' which is used in reactingFoam Solver as well. If any of you could run the Transient Solver in Steady-State mode ( with delta T=1 for example , and not with deltaT= 10^-6) or already created a new steady-state solver , I would be so grateful if help me this way,
looking forward to your replies,
Sincerely,
Parsa
parsa_abbasi is offline   Reply With Quote
Old   September 16, 2013, 13:03
Tobi's Avatar
Tobias Holzmann
Dear all,
this thread is for libOpenSMOKE and not for other combustion solver.
To have a clear thread, please make new threads with your problems
Thanks
Tobi
babakflame and TBO like this.
Old   September 16, 2013, 15:28
Bobby
Hi Tobi
I have an issue with k parameter in simulating bluff-body flames. what should I take for this value? For instance; In your Sandia_CO/H/N2 you have mentioned as:
  outlet
        type            zeroGradient;
    axis
        type            empty;
    sidewall
        type            compressible::kqRWallFunction;
        value           uniform 1;
    burnerwall
        value           uniform 1;
for the boundary walls. Also in another tutorial for a bluff-body flame I found:
bluffbody
        value           uniform 17.34;
    back
        type            wedge;
    outlet
        type            inletOutlet;
        inletValue      uniform 1;
        value           uniform 1;
Would you PLZ hint me about it that how these parameters are taken?
My specific issue is its value for the bluff-body boundary as a kind of wall.
It is the initial value, So is it important choosing the exact right value. I suggest maybe just estimating a value and starting my simulation.
Am I right Buddy?
Regards
Bobi
Old   September 17, 2013, 07:10
Tobi's Avatar
Tobias Holzmann
Originally Posted by parsa_abbasi View Post
Dear All,
Sincerely,
Parsa
Hi Parsa,
just one question. Are you using the libOpenSMOKE tool and the flamelet solver or a other solver?
It s confusing cause you mentioned you are using the ''psi Combustion Model" ?
Tobi
Old   September 17, 2013, 07:16
Tobi's Avatar
Tobias Holzmann
Hi Tobi
Am I right Buddy?
Regards
Bobi
Hi Bobi,
you are right. The values you choose are just initial values. After the first iteration the value change. But if you choose your value very good your simulation get to a steady state solution faster.
Additionally the first timesteps could be hard for openfoam to calculate due to bounding things and stuff like that. So its good to have a accurate value.
In my tutorial case its just a standard value if I do not know a correct one
I always begin with 0.01 to 1 ... due to the velocity and geometry.
The inlet value can be calculated (not exact but good for initialising).
For the wall I could use 10 or 100 too
So just start with 0.1 or 1 and check the first 10 or 50 timesteps / iterations ... if you have no problems with the wall value then everything is okay.
I read in an other thread that People set the k and Epsilon values to 1e5 or sth. like that
Well in my opinion you should set a correct dimension.
So if you know that the inlet has k=0.0032 then I choose the same Dimension for the walls like 0.001 ... but not 10
Hope this answer will help you for your Problem.
Tobi
immortality and babakflame like this.
Old   September 18, 2013, 15:11
sonu
greetings oll ,
i have a small doubt that in 0 folder the value of each species (like CH4) in boundary fields is in mole fraction . rite ?? not the mass fraction
correct me if i am wrong
Thank you ,
Regards
sonu
Numerical treatment of the source term in combustion equations Tobi Main CFD Forum 37 September 15, 2020 14:42
[openSmoke] flameletSmoke + new ODESolver (by Alberto Cuoci) Tobi OpenFOAM Community Contributions 1 November 21, 2017 19:24
Unsteady solver with Flamelet Model (libOpenSMOKE) francesco_capuano OpenFOAM Running, Solving & CFD 11 November 26, 2013 05:50
LibOpenSmoke, getting the species in ParaFoam Christoph_84 OpenFOAM 1 May 31, 2012 15:42
