Programming of fluctuating two-component inlet
Old   August 3, 2010, 10:39
Default Programming of fluctuating two-component inlet
steph79 is on a distinguished road
I want to specify an inlet with two (u and v) fluctuating components. I've tried to use the groovyBC utility but as far as I can tell it's limited to produce a homogeneous/uniform inlet with respect to each time step, although please correct me if I'm wrong!!!
Assuming this is the case could someone advise me where to get started in terms of implementing this for myself and retrofitting the custom code to OpenFOAM? I'm using version 1.7.0.
Thanks! :-)
steph79 is offline   Reply With Quote
Old   August 3, 2010, 12:15
David Gaden
marupio is on a distinguished road
I don't know what groovyBC is capable of... but I think it should be able to handle what you are asking for. If not, here's a crude guide on programming custom boundary conditions:
http://openfoamwiki.net/index.php/Ho...dary_condition
Good luck!
marupio is offline   Reply With Quote
Old   August 3, 2010, 16:37
Nima Samkhaniani
nimasam is on a distinguished road
you are wrong
with groovyBC, you can make a blend BC even fluctuating with time or position!!!
look at wiki and example,you will find more
nimasam is offline   Reply With Quote
Old   August 3, 2010, 18:20
Originally Posted by nimasam View Post
you are wrong
For once I'm wrong!
Could you, or anyone else, help direct me to implement equations of this form in groovyBC?
u = 10 + sin((5*y + 2)*time)
v = cos((5*y+2)*time)
Another thing is, can I define global variables at the head of the program, as for Fluent UDF's? For example - #define UMEAN 10 ???
@David - thanks for the guide, I hadn't come across that before and it could come in handy!
Old   August 3, 2010, 18:35
Nima Samkhaniani
type groovyBC;
valueExpression "vector(10+sin(a*time()),cos(a*time()),0)";
gradientExpression "vector(0,0,0)";
fractionExpression "1";
variables "a=5*pos().y+2;";
timelines ();
value uniform (0 0 0);
Old   August 3, 2010, 19:05
Talking
type groovyBC;
timelines ();
That was very kind, thank you for your help and I'll let you know how I get on tomorrow!!!
Old   August 4, 2010, 13:21
It worked great, thanks again!
Old   January 26, 2012, 09:19
Having disappeared from the OpenFOAM world for over a year now I recently installed version 2 and discovered that groovybc is no longer supported. I had this boundary condition working fine with 1.7.
Could someone quickly tell me how to transfer this exact same boundary condition over to swak4foam?
Thanks.
RSM value of fluctuating component of velocity Kushagra CFX 5 April 10, 2008 16:20
Gravity component and inlet velocity Vidya FLUENT 8 July 31, 2006 09:28
HOW to GET FLUCTUATING VELOCITY COMPONENT at FLUEN Seyfettin FLUENT 2 December 1, 2005 04:51
Diffusion component at inlet Balaji FLUENT 2 August 8, 2005 08:37
how to get fluctuating component l.g.patil FLUENT 0 February 9, 2002 12:57
