Extending OpenFOAM ::: error
Old   August 2, 2010, 09:18
Default Extending OpenFOAM ::: error
Balkrishna Patankar
balkrishna is on a distinguished road
I am writing a solver for simulating mixing of 3 liquids of mass fractions alpha0 , alpha1 and alpha2 .... I have extended the twoLiquidMixing Foam solver to include 3 components mentioned above . The source is compiled ok but on running for a test case .... i get the following error .
Please can anyone suggest how to overcome this :
Reading field alpha0 word::stripInvalid() called for word alpha0 For debug level (= 2) > 1 this is considered fatal
balkrishna is offline   Reply With Quote
Old   August 3, 2010, 06:19
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
If you post the part of the code where you construct the alpha objects, and the alpha0 file and location, you may get some more help.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   August 3, 2010, 06:25
Balkrishna Patankar
Thanks for the reply .... I corrected my error .... The problem was with a space between alpha and 0 characters ....
Old   August 3, 2010, 06:27
Balkrishna Patankar
however I am facing another problem now .... :
I have tried to extend openfoam's two liquid mixing solver to n liquids where n is a number from the user .... However after a few iterations < 10 I get the following warning
-> FOAM Warning :
From function Time:perator++()
in file db/Time/Time.C at line 681
Increased the timePrecision from 7 to 8 to distinguish between timeNames at time 0.000250075
Time = 0.00025007459
and then the courant number suddenly shoots up to >10^8 ... how should I correct it ....
Old   August 3, 2010, 06:32
First things to check:
1) Does this case you're running for 'n' components work with 2 components (i.e. have you compared your new code with the old code when n=2)?
2) Have you tried lowering the time step.
Old   August 3, 2010, 06:36
Balkrishna Patankar
Thanks for the reply .... I have tried lowering the time step ... but all this does is prolongs the blow up of the solution .
I am running this code for n=2 to confirm with the twoLiquidMixingFoam Solver ... although the code compiles without errors I get the above error ...
Old   August 3, 2010, 06:48
Code compiling doesn't mean it will run correctly! To be honest it could be anything. Just glancing at the solver it strikes me that you may have to come up with a sensible way of solving for turbulence when n>2 (maybe you don't). But the physics is another matter...
It looks like the changes you would have had to make are:
1) PtrList of alphas.
2) Creation of an nPhaseMixture Class or equivalent.
3) Change the calculation of rho/rhoPhi in a few places.
4) Solve n-1 alphaEqns.
Old   August 3, 2010, 06:56
Balkrishna Patankar
I will review the physics for nComponents .
Regarding :
1) PtrList of alphas. => I have created suitable pointers in createFields.H
2)Creation of an nPhaseMixture Class or equivalent. => I have added this too .
3)Solve n-1 alpha Eqns => Is it ok to solve n alpha Eqns as long as they have been used carefully. Because for n components the nth is to be calculated by 1-sum(all other comp) .I dont have issues about speed as of now ....
4) Change the calculation of rho/rhoPhi in a few places. => Please can you elaborate on this . rhoPhi is calculated in alphaEqn and used in UEqn . The way the (twoLiquidMixing) solver calculates rhoPhi is
rhoPhi = alpha1Eqn.flux()*(rho1-rho2) + phi*rho2
The way I have done it is :
rhoPhi = rho1*alpha1Eqn.flux() + rho2*alpha2Eqn.flux()
Thanks again for ur help ....
Old   August 3, 2010, 07:43
It's difficult to say what could be going wrong. You may have boundedness issues with rhoPhi.
You've made quite a few changes at the same time. When I'm writing new stuff I try to do it incrementally and test it after every change. I usually start with the infrastructure, so in your case sorting out the storage of alphas and the capability to solve more alpha equations. Then I would try changing the calculations of rhoPhi line by line -> often there are subtle numerical reasons for the way they are formulated.
Old   August 3, 2010, 07:54
Balkrishna Patankar
Thanks for the advice n help ....
Old   August 3, 2010, 09:21
Balkrishna Patankar
The precise error i get is :
Courant Number mean: 2.69878e+06 max: 6.18058e+08
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/ifmg/OpenFOAM/OpenFOAM-1.7.0/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/ifmg/OpenFOAM/OpenFOAM-1.7.0/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::Time::adjustDeltaT() in "/home/ifmg/OpenFOAM/OpenFOAM-1.7.0/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam::Time::setDeltaT(double) in "/home/ifmg/OpenFOAM/OpenFOAM-1.7.0/lib/linuxGccDPOpt/libOpenFOAM.so"
#6 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
Floating point exception
Old   August 9, 2010, 04:06
Balkrishna Patankar
i modified twoLiquidMixingFoam source for n Components as a start I am testing it for 2 components . I get a very weird floating point exception error at the start of the iterations . On tracing the error with Info statements I found out that the program gives a fpe while calculating the kinematic viscosity in the calcNu function . specifically at the following point :
void nComponentMixture::calcNu()
    nuModel1_->correct();
    nuModel2_->correct();
    volScalarField limitedAlpha1
        "limitedAlpha1",
        min(max(alpha1_, scalar(0)), scalar(1))
    volScalarField limitedAlpha2
        "limitedAlpha2",
        min(max(alpha2_, scalar(0)), scalar(1))
    Info<<alpha1_<<endl<<alpha2_<<endl<<rho1_<<endl<<rho2_<<endl;
// Average kinematic viscosity calculated from dynamic viscosity
    nu_ = mu()/(limitedAlpha1*rho1_ +limitedAlpha2*rho2_ );
Where could the possible error be ?
Old   August 9, 2010, 04:07
Balkrishna Patankar
If i however comment the nu_ calculation statement the program runs till convergence ....
Old   August 9, 2010, 05:27
Sounds like both your alphas are becoming zero at the same time? Have you checked their values?
Old   August 9, 2010, 05:36
Balkrishna Patankar
Yes . This is infact before any iteration is performed . I have checked values of the alpha's , rho's and mu() to be very sure and none of them are zero ...
Old   August 9, 2010, 05:51
That's the only reason I can think of. Can you post your output up here?
Old   August 9, 2010, 05:52
Balkrishna Patankar
|  \\    /   O peration     | Version:  1.7.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : 1.7.0-21131bcbd876
Exec   : ../balFoam
Date   : Aug 09 2010
Time   : 13:52:07
Host   : ifmg-desktop
PID    : 7157
Case   : /home/ifmg/mySol/balFoam/twoLiquid
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Reading field p
Reading field U
Reading field massFrac1
Reading field massFrac2
Selecting incompressible transport model Newtonian
#0  Foam::error::printStack(Foam::Ostream&) in "/home/ifmg/OpenFOAM/OpenFOAM-1.7.0/lib/linuxGccDPOpt/libOpenFOAM.so"
#2  Uninterpreted:
#3  Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) in "/home/ifmg/OpenFOAM/OpenFOAM-1.7.0/lib/linuxGccDPOpt/libOpenFOAM.so"
#4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&)
#8  __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
Old   August 9, 2010, 06:17
Balkrishna Patankar
@l_r_mcglashan Sir , Would you mind if i did send you my solver entirely as a tar.gz file ?
Old   August 9, 2010, 07:19
If you wish, I can take a quick look.
Old   January 20, 2014, 05:14
Albrecht vBoetticher
vonboett is on a distinguished road
...although it is probably an old issue now, I want to add something in case somebody faces the same problem and reads through this thread: A typical error is that the phases add up to a higher value than 1 in a cell. Something you don't see because the single phase shares can be between 0 and 1, but the sum can exceed 1 and that is for incompressible flow fatal. Check that the initial field and the boundary values do not lead to alpha1+alpha2+alpha3 >1
vonboett is offline   Reply With Quote
nonNewtonian viscosity model mhassani OpenFOAM Programming & Development 5 January 7, 2013 10:27
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
POSDAT problem piotka STAR-CD 4 June 12, 2009 09:43
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
user defined function cfduser CFX 0 April 29, 2006 11:58
