July 1, 2016, 06:55 |
The Gray-Scott Model
Tobias Holzmann
Rep Power: 52 |
Dear all,
I am happy to announce the new development » The Gray-Scott-Model «. The model solves two species equations that are coupled and have reaction-diffusion character (of course I also added the convection term). In the model you can see how to implement the equations implicit, explicit and you also can check out how to linearize a non-linear term (the simplest approach is used here). The model can be used for understanding numerics in more details (that was the reason why I implemented explicit and implicit). Unfortunately I did not add the Fourier and Courant number for stabilization criteria. Anyway, the model can also be used as a playground to see how different settings influence the behavior of the solution. In addition you can get very nice patterns like these here: https://holzmann-cfd.com/en/openfoam...ll-impressions A brief description with links to further literature is given here (English): https://holzmann-cfd.com/en/openfoam...ay-scott-model There you also find the source code for OpenFOAM 2.3.x, 3.0.x and 4.x plus four tutorials. It is a simple model but you can get some more feeling about FOAM. Enjoy ...
Keep foaming, Tobias Holzmann Last edited by Tobi; January 10, 2020 at 17:46. |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
coalChemistryFoam: "Foam::error::printStack(Foam::Ostream&) at ??:?" | musabai | OpenFOAM Running, Solving & CFD | 2 | February 20, 2015 15:07 |
Non gray model in DO radiation model in Fluent | novice | FLUENT | 2 | January 19, 2015 15:26 |
Weighted Sum of Gray Gas Model (WSGGM) in FLUENT | anthony05 | Fluent UDF and Scheme Programming | 0 | July 15, 2013 01:07 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 26, 2009 00:27 |
