read binary tensor field
Old   August 17, 2015, 23:20
Default read binary tensor field
J.-H. Wang
f0208secretx is on a distinguished road
Hi Foamers,
I have velocity gradient output at every time step in binary, compressed format using calcFvcGrad library. I now want to write a custom binary reader to port this data for each time step to other solvers I wrote. I can't seem to find the descriptions of how this binary is formatted anywhere. I need to know precision, order of array (NCell*9 matrix), corresponding vertex/cell position etc. Will appreciate for any help. Thanks.
f0208secretx is offline   Reply With Quote
Old   August 18, 2015, 15:32
Retired Super Moderator
Bruno Santos
Quick answer:
  1. The order is the exact same as when writing in "ascii".
  2. The precision is part of one of the build options. You can check by running:
    echo $WM_ARCH_OPTION
    echo $WM_PRECISION_OPTION
    which should tell you if it's built with 32 or 64-bit and if Single or Double Precision (SP or DP).
  3. For the format of the tensor, check the programmer's guide (references: http://openfoamwiki.net/index.php/Ma...rGuideAddendum ) or check the source code of the test utility "applications/test/tensor".
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 09:46
[Resolved] GPU on Fluent Daveo643 FLUENT 4 March 7, 2018 09:02
Cannot read 2nd column of data in libforces.so output force.dat file musahossein OpenFOAM Programming & Development 9 February 21, 2015 23:43
Error in solution using "Grid Interface" agustinvo FLUENT 4 January 20, 2015 13:03
Read Plot3D Binary File John Main CFD Forum 3 January 17, 2001 04:57
