exp() function not working?
Old   April 23, 2014, 22:10
Default exp() function not working?
CHARLES
CHARLES is on a distinguished road
For some reason I don't think that exp() is doing anything... can you please tell me what you think is wrong?
I have the following code:
argf2 = sqr(k_)/(6.0*nu()*epsilon_);
f2 = 1-2/9*Foam::exp(-1.0*sqr(argf2));
I can tell that argf2 is doing what is supposed to.
However, when I bring up f2 in paraview it just shows up as 1 everywhere.
If I define f2 in the following way:
f2 = 99-2/9*Foam::exp(-1.0*sqr(argf2));
f2 shows up as 99 everywhere.
f2 = -2/9*Foam::exp(-1.0*sqr(argf2));
Then the field f2 shows up as 0, even if it was initialized as a different value.
I have also tried to not use "Foam::" before exp() and it doesn't make a difference.
Additionally, when I look at the f2 that was output to the time directory it looks like this:
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0.001";
    object      f2;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 1;
boundaryField
    plate
        type            calculated;
        value           uniform 1;
    back
        type            empty;
    front
        type            empty;
    inlet
        type            calculated;
        value           uniform 1;
    outlet
        type            calculated;
        value           uniform 1;
    top
        type            calculated;
        value           uniform 1;
    symmetry
        type            symmetryPlane;
when in reality it should be an internalField nonuniform List<scalar>
Thank you!
CHARLES is offline   Reply With Quote
Old   April 24, 2014, 05:31
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
2/9 is 0 as it is integer division. So your problem is not with exp but with 2/9 that should be 2.0/9.0 (or if you'd like 2 and 9 then you can write it as 2*Foam::exp(...)/9, in this case nominator will be converted to double due to exp function)
alexeym is offline   Reply With Quote
Old   April 24, 2014, 14:30
CHARLES
Thank you Alexey!
Adding the ".0" to each integer made a difference. Instead of f2 being set to 1 everywhere, it is being set to 0.777778 (i.e.: 1.0 - 2.0/9.0). OpenFOAM still doesn't recognize the
. Even if I try to define f2 as
f2 = 1-2.0*Foam::exp(-1.0*sqr(argf2))/9.0;
When I open the f2 output in the time directory, I see that it is still shown as
FoamFile
    version     2.0;
    format      ascii;
    location    "0.001";
    object      f2;
boundaryField
    plate
        type            calculated;
        value           uniform 0.777778;
    back
        type            empty;
    front
        type            empty;
    inlet
        type            calculated;
        value           uniform 1;
    outlet
        type            calculated;
        value           uniform 1;
    top
        type            calculated;
        value           uniform 1;
    symmetry
        type            symmetryPlane;
instead of the nonuniform list.
Do you think it may have something to do with the way I have initialized f2 and argf2?
    argf2
        IOobject
            "argf2",
            runTime_.timeName(),
            mesh_,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        mesh_,
        dimensionedScalar("argf2", dimless, 0.0)
    f2
        IOobject
            "f2",
            mesh_,
            IOobject::NO_READ,
        mesh_,
        dimensionedScalar("f2", dimless, 1.0)
argf2= sqr(k_)/(6.0*nu()*epsilon_);
f2 = 1-2.0/9.0*Foam::exp(-1.0*sqr(argf2));
Old   April 24, 2014, 14:56
Alexey Matveichev
Hi!
Well, as I don't know other values in your problem, I'll try to guess
k_ is of order of unity, epsilon_ is almost like k_, nu is around 1e-7, so argf2 should be something around 1e6. And exp(-1e12), I guess it's just 0. At the plate patch argf2 is zero, so f2 there is equal 1 - 2.0/9.0.
Old   April 29, 2014, 14:07
CHARLES
Alexey,
My values for the internal field in the 0 folder are the following:
k=2.16e-3
epsilon=6.27e-4
nu=1.53e-5
which would make argf2=(2.16e-3)^2/(6*1.53e-5*6.27e-4)=81.06 (based on initial conditions)
Based on your argument, I can tell that f2 should in fact approach 0.77778!
exp(-1.0*sqr(argf2)) = 0 -> f2=1.0-2.0/9.0
Thank you.
Now the next question is why does OpenFOAM not create the nonuniform list <scalar>?
FoamFile
    version     2.0;
    format      ascii;
    location    "0.001";
    object      f2;
boundaryField
    plate
        type            calculated;
    back
        type            empty;
    front
        type            empty;
    inlet
        type            calculated;
        value           uniform 1;
    outlet
        type            calculated;
        value           uniform 1;
    top
        type            calculated;
        value           uniform 1;
    symmetry
        type            symmetryPlane;
Old   April 29, 2014, 14:24
Alexey Matveichev
No, it should not.
f2 = 1.0 - 2.0/9.0*exp(-sqr(argf2))
Even if argf2 == 81, exp(-6561) is equal 0, so f2 = 1.0 - 2.0/9.0*0.0 == 1.0.
Guess, cause it's uniform.
Old   April 29, 2014, 14:50
CHARLES
Ooops!
My apologies, I was thinking of the value of argf2 at a solid boundary, which yields argf2=0, leading to f2=1-2.0/9.0.*1.
Thank you for your help Alexey!
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
Can anybody help me to solve the list errors while compiling Openfoam 15 on Opensuse 103 32bit coompressor OpenFOAM Installation 0 November 12, 2008 20:53
Could you please help me about the VTKFoam liugx212 OpenFOAM Pre-Processing 5 February 13, 2008 12:31
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 07:27
[OpenFOAM] Could you please help me liugx212 ParaView 4 December 22, 2005 17:55
