Segmentation fault in edcSimplefoam
Old   January 23, 2013, 11:23
Default Segmentation fault in edcSimplefoam
ILAM
dreamilam is on a distinguished road
Hi guys,
I am trying to convert the edcSimplefoam solver (released in the 6th openFOAM workshop) from version 1.7 to 2.1.. I have managed to compile the solver and the associated libraries without any problems.
But, when i try to run a model case, I am getting a 'segmentation fault' error.
The segmentation fault occurs at line 79 in the attached file.. I have no clue why it is happening..
can anyone help?
dreamilam is offline   Reply With Quote
Old   July 25, 2013, 09:59
kolla04 is on a distinguished road
hi,
i am working on the same problem ... did you solve your problem??
kolla04 is offline   Reply With Quote
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 22:59
segmentation fault when installing OF-2.1.1 on a cluster Rebecca513 OpenFOAM Installation 9 July 31, 2012 16:06
Segmentation Fault Shawn_A OpenFOAM Running, Solving & CFD 6 October 31, 2011 15:38
forrtl: severe (174): SIGSEGV, segmentation fault occurred therockyy FLOW-3D 7 January 19, 2011 23:52
ParaView segmentation fault only for multiphase gwierink OpenFOAM 9 March 25, 2010 08:23
