Problems on Tetrahedra to Polyhedra using polyDualMesh on concave surface object
Old   July 23, 2008, 13:38
Default I'd like to using OpenFOAM wit
Martin/Run DU
chnrdu is on a distinguished road
Send a message via Skype™ to chnrdu
I'd like to using OpenFOAM with polyhedra mesh to simulate a flow field in a pipe connected volume, like the image:
I use salome to generate this mesh with netgen(1d-2d-3d)
I have set up the boundaries as independent as each surface is a boundary, then convert it to polyhedra using polyDualMesh, but checkMesh said that there are several concave faces and wrong oriented faces:
the black colored faces is concave faces which are just around the connection edge of the two near boundaries.
However, I set some surfaces together as one boundaries including the neighbor surfaces with concave angle. I can converted it to polyhedra without errors, but the original edge between the concave surfaces becomes to several faces with polygon, so it loses the geometry information.
My problem is: how to convert tetra to polymesh avoiding concave faces without losing geometric infomation like such volume?
Thank you in advance.
Martin/Run Du
rdu
Martin/Run Du
chnrdu is offline   Reply With Quote
Old   July 7, 2009, 03:19
bfa
Björn Fabritius
bfa is on a distinguished road
Hello Martin,
I just recently read your post. Did you by now find a solution to your problem? 'Cause I'm having trouble with the same effect as you describe above.
Regards,
Bjoern
bfa is offline   Reply With Quote
Old   July 18, 2009, 13:58
Default trick with polyDualMesh
jbf
jb
jbf is on a distinguished road
Originally Posted by bfa View Post
Hello Martin,
Regards,
Bjoern
Hi ! I had exactly the same problem when using polyDualMesh, ie a loss of the geometrical informations... but I found a trick to avoid this problem : I use a mesh made of only one patch, then I use polyDualMesh with 0 angle, and finaly I divide the single patch with autoPatch. Now I have a good shape for my dual mesh... but I have a new problem using refineWallLayer. For some surfaces mesh I got the following message :
"achorpoints and nonanchorpoints are geometrically on same side!" Do you have an idea to solve this problem ? Does it come from the original mesh ?
Sincerely,
JB
jbf is offline   Reply With Quote
Why Differences between tetrahedra polyhedra and prism mesh pipe flow computation with sonicLiquidFoam chnrdu OpenFOAM Running, Solving & CFD 5 May 7, 2018 04:23
How to determine the type of an object in the object registry mwild OpenFOAM Running, Solving & CFD 8 June 8, 2010 21:58
PolyDualMesh crash caused by functions in contralDict zeliboba OpenFOAM Bugs 1 September 28, 2008 12:06
About the usage of polyDualMesh weijing OpenFOAM Running, Solving & CFD 3 June 15, 2006 08:54
problems with tight flow domain on object jemteo CFX 0 August 3, 2004 07:17
