[swak4Foam] FunkySetFields for OF 141
Like Tree1Likes
Old   March 17, 2009, 16:32
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Sorry to bother again.
But the solution with the bessel function did not turn out to be working.
Actually the new function in funkySetFields is working, but the result is not as planned. The function named in the paper mentioned above turns out to produce a different interface than I desired.
At this point I need an advice, which function the correct interface is representing.
Please refer to the two attached images from a previous post.
I want to set up this cosine-function in 3D on a square domain, meaning that the interface should be elevated at the walls and be lowered in the center of the domain forming this cosine-like 'tub'.
I'm not quite shure which function (in 3D) would represent such an interface, nor where to look at (or start investigating).
Please don't smack me for posting in the funkySetFields thread, as this this not directly linked to the tool but is rather basic.
But as this should lead to a condition statement for funkySetFields I thought it would be good place to ask for.
Many thanks for your ideas.
S.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   March 17, 2009, 16:46
Assistant Moderator
Bernhard Gschaider
Originally Posted by sega View Post
Well, Sorry to ask this, but I don't know what xxx ? xxy : xxz means?
It means "if the logical expression xxx is true for a cell use the value xxy, else use xxz"
Old   April 29, 2009, 05:18
Fabian Braennstroem
braennstroem is on a distinguished road
I am just trying to figure out, how this expression
'(grad(dist())^vector(0,0,-1))*mag(pos()-vector(0.05,0.05,0))/0.05'
creates a fild in a circle. I got trouble to understand it...
I would like to achieve something like:
u=2*y*(1-x^2), v=-2*x*(1-y^2)
It is probably similar!?
Thanks!
Fabian
braennstroem is offline   Reply With Quote
Old   April 29, 2009, 14:48
Assistant Moderator
Bernhard Gschaider
Originally Posted by braennstroem View Post
creates a field in a circle. I got trouble to understand it...
Not really. The first expression depends on the boundary of the mesh (dist() is the distance to the nearest wall). The grad gives you the direction away from the wall. The vector in the cross-product assumes that you are in the xy-plane and the cross product therefor gives you a vector almost parallel to the nearest boundary. The mag Assumes that the center of the mesh is 0.05/0.05 (basically it only works good for the driven cavity)
General circular field around a point in the xy-plane might be
'(pos()-vector(1,2,0))^vector(0,0,1)'
Bernhard
Old   May 3, 2009, 15:58
Fabian Braennstroem
Hi Bernhard,
thanks for the explanation!
Regards!
Fabian
Old   May 4, 2011, 08:11
Default fpos() and surf() synthax error
  #66
Antonio Liggieri
alfa_8C is an unknown quantity at this point
Hy funkyFOAMers,
I've generated an initial Field for an interFoam simulation by using funkySetFileds and it worked quite well.
Now I'm trying to smoothen the free surface by using the commands shown on this page:
http://openfoamwiki.net/index.php/Co...funkySetFields
But I can't get it working. I always receive the following error:
Parser Error at "1.9-12" :"syntax error, unexpected TOKEN_fposition"
"average(fpos().z <= surf(0.) ? surf(1.0) : surf(0.))"
Being in the case directory the executed command is the following:
funkySetFields -case ./ -time 0 -field alpha1 -keepPatches -expression "average (fpos().z <= surf(0.) ? surf(1.0) : surf(0.))"
Has anybody an idea, how to modify the command in order to do what desired?
Thanks in advance, Toni
alfa_8C is offline   Reply With Quote
Old   May 4, 2011, 08:13
Antonio Liggieri
this is my initial filed:pic.jpg
Old   May 4, 2011, 12:45
Assistant Moderator
Bernhard Gschaider
Originally Posted by alfa_8C View Post
Hy funkyFOAMers,
You're not REALLY using the 1.4.1 version, are you? If yes: that version of FSF is quite old and I can't help you on that. If no: why are you posting in a thread that implies that? (see also http://openfoamwiki.net/index.php/Ho..._Message_Board points 3 and 5)
Maybe the problem is that in newer versions of FSF what used to be called average was renamed to faceAverage (averaging over the faces of a cell. average is now the average of a whole field)
Bernhard
Old   May 5, 2011, 05:25
Antonio Liggieri
It seems that I didn't read the thread carefully - sorry for the inconvenience...
With the following link I switch now to a newer one, that implies a newer version of FSF.
http://www.cfd-online.com/Forums/ope...eld-patch.html
Old   June 11, 2014, 12:05
Jianxi Yao
jianxiyao is on a distinguished road
Originally Posted by gschaider View Post
Now it works (new version just went to the SVN. Get it from there)
The expression would be:
"average(fpos().y < surf(0.) ? surf(1.) : surf(0.))"
The surf-functions generates surface-fields.
Hi Gschaider,
I use the above expression to initial alpha.water in OF 2.3.0. error occurs such as :
Modifying field alpha.water of type volScalarField
Putting "average(fpos().z < surf(0.) ? surf(1.0) : surf(0.))" into field alpha.water at t = "0" if condition "true" is true
Keeping patches unaltered
--> FOAM FATAL ERROR:
inconsistent types: alpha.water is volScalarField while the expression evaluates to a surfaceScalarField
From function doAnExpression()
in file funkySetFields.C at line 361.
FOAM exiting
jianxiyao is offline   Reply With Quote
Old   June 11, 2014, 12:29
Assistant Moderator
Bernhard Gschaider
Originally Posted by jianxiyao View Post
Hi Gschaider,
FOAM exiting
See http://www.cfd-online.com/Forums/ope...tml#post306250 above: you probably want to use faceAverage
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   June 11, 2014, 12:34
Jianxi Yao
Thank you for your quick reply.
that is the reason. it works now.
[swak4Foam] groovyBC and funkySetFields married and got a kid named swak4Foam gschaider OpenFOAM Community Contributions 169 August 10, 2023 10:01
[swak4Foam] how to use funkySetFields function in muliregion case bryant_k OpenFOAM Community Contributions 15 October 15, 2021 03:50
[swak4Foam] funkySetFields and funkySetBoundaryFields zxj160 OpenFOAM Community Contributions 19 February 14, 2018 20:07
[swak4Foam] funkySetFields: problem with processor boundary nmikhailov OpenFOAM Community Contributions 4 May 26, 2015 10:48
[swak4Foam] numerical beach with funkySetFields?! maxonline OpenFOAM Community Contributions 6 June 17, 2011 05:59
