October 24, 2016, 04:43 |
update of constant/polyMesh/boundary
Simon Johansson
Rep Power: 15 |
I'm currently running a case where I use snappyHexMesh to generate my grid. The mesh is all good despite some small deficiencies at corners of my geometry but I can live with those.
I generate my case as the flange tutorķal and after the mesh generation I end up with one addidional boundary in constant/polyMesh/boundary. This extra boundary is the one created by blockMesh. If I try to run the case as is It complains about the missing BC in the 0 folder for U and p_rgh for the boundary created by blockMesh. In the flange tutorial this boundary is called allBoundary. The simulation do run if i manually delete the the allBoundary lines in contstant/polyMesh/boundary. Is there any why to do this from the commandline or any built in openFOAM tools? |
October 24, 2016, 05:13 |
Rep Power: 16 |
In the constant/polyMesh/boundary does the "allBoundary" patch have 0 faces? If that is the case then you can run createPatch to remove zero-sized patches, though I would expect snappy to have already taken care of that. Cheers, Antimony |
October 24, 2016, 05:21 |
Simon Johansson
Rep Power: 15 |
Thanks Antimony for at quick response.
Yes I guess it is zero since I got the nFaces 0; This was the solution to my problem. There are a lot of complicated examples of createPachDict in the tutorials. Since my case is simple without any moving parts i used tutorials/incompressible/simpleFoam/rotorDisk/system/createPatchDict. If I use this as is all the paches with zero faces will be removed For the ones to lazy to find that file I attach the code form that file Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object createPatchDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Do a synchronisation of coupled points after creation of any patches. // Note: this does not work with points that are on multiple coupled patches // with transformations (i.e. cyclics). pointSync false; // Patches to create. An empty patch list just removes patches with zero // faces from $FOAM_CASE/constant/polyMesh/boundary. patches ( ); // ************************************************************************* // |
October 24, 2016, 05:39 |
Rep Power: 16 |
Used the attached as your createPatchDict to remove zero size patches. Cheers, Antimony |
October 27, 2016, 04:48 |
Erlend Grotle
Rep Power: 10 |
This solved my problem nicely. I used the file shown in #3.
Then I copied polyMesh files from 0.01 folder to the constant folder and deleted 0.01. Nice..:!! BR Erlend |
October 27, 2016, 07:02 |
Simon Johansson
Rep Power: 15 |
I'm not familiar with the copy and paste procedure you are doing.
Maybe you could use createPatch -overwrite |
snappyhexmesh |
Change "Implicit Mesh Update Interval" using UDF | ASimonsen | Fluent UDF and Scheme Programming | 2 | October 12, 2017 10:38 |
Implicit mesh update restriction for faster calculation | burning_bert | Fluent UDF and Scheme Programming | 1 | May 28, 2017 17:59 |
libsampling for DyM solver exporting vtk patch. Problem to update geometry | be_inspired | OpenFOAM Post-Processing | 3 | October 9, 2015 08:58 |
[OpenFOAM] Update data in ParaView | hpon | ParaView | 18 | May 10, 2015 15:55 |
Using Workbench, CFX-Pre doesn't update mesh from upstream data | Shawn_A | CFX | 2 | November 25, 2012 14:06 |
