May 27, 2014, 13:19 |
Inlet of fluid
Lenzo
Rep Power: 12 |
Hello everybody!
It is not my first thread about it, but I have just some changes, so it means that, somehow it's like a new question. "Dictionary setField" sets the fields of fluids which exist inside the domain. So we use it in order to declarate: Here i have this fluid, there this other one. So let's see what happens. But my problem is: i have a constant inlet of fluid. From one boundary there is constantly getting into my domain one fluid. As far as I know this is not setField dictionary anymore. But i don't know how to do that. I hope you can understand my proble and u can help me!! Thanks a lot, |
May 31, 2014, 09:34 |
Lenzo
Rep Power: 12 |
People,
no one has any idea about how I can define it? Or at least could you give me some hint where to find such information? When it comes to openSource's material I feel abandoned... thanks a lot |
May 31, 2014, 11:19 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Lenzo,
There is a lot of information online on how to define an inlet in OpenFOAM. There are several tutorials in OpenFOAM's "tutorials" folder that demonstrate how this is done. Even the very first tutorial in OpenFOAM's User Guide hints at how this can be done, since it defines a fixed value on the top wall that is forcing the fluid inside to move. You only need to change the direction of the vector and it will start pouring inside the "cavity"... er, well, it won't work on that tutorial directly, as there would be no way for the fluid to later get out ... If you're not yet getting the idea, please read/study the OpenFOAM User Guide once again and then have a look into the tutorial "incompressible/simpleFoam/pitzDaily" and read the contents of all of the files present there. Best regards, Bruno |
May 31, 2014, 11:26 |
Lenzo
Rep Power: 12 |
Thanks Bruno,
I think I didn't explain myself properly. I know how to define initial conditions such an inlet. And I also know the folder tutorials and the openfoam's user guide, where i learnt all what i know of openfoam. What i don't know is how to define an inlet of a Different fluid. So, i have my fluid, which is defined in transportProperties dict. But, i wanna another fluid getting into all the time. As I said, this is not setField, because setField is only for fluids i have already on my domain, but i am talking about a new fluid which comes from outside. Obviously i also have outlets, but if i know how to manage one inlet i guess i will manage how to define the outlet.... I hope now i find my answer Thanks |
May 31, 2014, 11:31 |
Bruno Santos
Rep Power: 128 |
OK, then a few questions:
May 31, 2014, 11:51 |
Lenzo
Rep Power: 12 |
I know the dam break.
The dam break is something as i said before, two different fluids that already exist in the same domain. I don't know that one of waterChannel. I hope that what you are saying to me will help me, but i always thought that the multiphase solvers where useful when we had two phases of the same flow. But what i mean two different fluids. So, should i take a look on the waterChannel? |
May 31, 2014, 12:45 |
Bruno Santos
Rep Power: 128 |
Hi Lenzo,
I haven't given you a straight answer, because once you figure out the answer, it'll be less likely that you'll forget about in the future I'll give you a few hints:
Bruno
May 31, 2014, 12:49 |
Lenzo
Rep Power: 12 |
Dear Bruno,
thanks a lot for your explanations and for your time. Now i know where and what i should look and investigate. I will keep on that way and i will tell you how it's going. thank you again, |
dsmcFoam setup | hherbol | OpenFOAM Pre-Processing | 1 | November 19, 2021 01:52 |
define temperature fluid at the inlet | papteo | OpenFOAM Pre-Processing | 0 | March 28, 2013 06:37 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
Inlet diffuser of ramjet | Mohammad Kermani | Main CFD Forum | 25 | December 29, 2000 18:46 |
