Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Tecplot 360 2011 R2 preview with OpenFOAM data loader available for evaluation
Like Tree9Likes
Old   August 22, 2013, 05:21
CFDnewbie147 is on a distinguished road
Hello Bruno,
thank you for your reply.
I'm using Tecplot 360 2013R1.
This error message occurs only with some tutorials, like the motorbike tutorial.
Other tutorials like the 2D_airfoil tutorial are working and there is no problem importing the solution into tecplot with the fea OpenFOAM reader.
If i do the checkMesh -constan in my motorbike tutorial directory, i get the following output:
|  \\    /   O peration     | Version:  2.2.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.1-57f3c3617a2d
Exec   : checkMesh -constant
Date   : Aug 22 2013
Time   : 10:18:30
Host   : ...
PID    : ...
Case   : ...
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create polyMesh for time = constant
Time = constant
Mesh stats
    faces:            5780496
    internal faces:   5598136
    cells:            1861334
    faces per cell:   6.11316
    boundary patches: 72
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     1676920
    prisms:        29205
    wedges:        4167
    pyramids:      10
    tet wedges:    5827
    tetrahedra:    247
    polyhedra:     144958
    Breakdown of polyhedra by number of faces:
        faces   number of cells
            4   15231
            5   23915
            6   22422
            7   14045
            8   5598
            9   44101
           10   324
           11   129
           12   10472
           13   67
           14   57
           15   7043
           16   10
           17   12
           18   1201
           19   7
           20   3
           21   272
           24   49
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
                   Patch    Faces   Points                  Surface topology
            frontAndBack     1360     1476  ok (non-closed singly connected)
                   inlet      272      306  ok (non-closed singly connected)
                  outlet      272      306  ok (non-closed singly connected)
               lowerWall    15704    16210  ok (non-closed singly connected)
               upperWall      640      697  ok (non-closed singly connected)
    motorBike_frt-fairing:001%1    21797    40074  multiply connected (shared edge)
    motorBike_windshield:002%2      181      286  ok (non-closed singly connected)
    motorBike_rr-wh-rim:005%5      539      947  ok (non-closed singly connected)
    motorBike_rr-wh-rim:010%10     1453     2231  ok (non-closed singly connected)
    motorBike_fr-wh-rim:011%11     1746     2589  ok (non-closed singly connected)
    motorBike_fr-wh-brake-disk:012%12      256      316  ok (non-closed singly connected)
    motorBike_frame:016-shadow%13      413      763  ok (non-closed singly connected)
    motorBike_rear-susp:014%14     3636     6330  ok (non-closed singly connected)
    motorBike_rear-susp:014-shadow%15     2095     5304  ok (non-closed singly connected)
    motorBike_frame:016%16      257      631  ok (non-closed singly connected)
    motorBike_rr-wh-rim:005-shadow%17      347      812  ok (non-closed singly connected)
    motorBike_rr-wh-chain-hub:022%22      460      609  ok (non-closed singly connected)
    motorBike_rearseat%24     1345     1579  ok (non-closed singly connected)
    motorBike_frt-fairing%25     2200     2942  ok (non-closed singly connected)
    motorBike_windshield%26     1482     3161  ok (non-closed singly connected)
    motorBike_headlights%27      551      861  ok (non-closed singly connected)
    motorBike_driversseat%28     1601     2115  ok (non-closed singly connected)
    motorBike_rear-body%29     7324     8953  ok (non-closed singly connected)
    motorBike_fuel-tank%30     3049     4123  ok (non-closed singly connected)
    motorBike_exhaust%31     7972     9687  multiply connected (shared edge)
    motorBike_rr-wh-rim%32     4374     5554  ok (non-closed singly connected)
    motorBike_fr-mud-guard%33     3131     5973  ok (non-closed singly connected)
    motorBike_fr-wh-rim%34     2204     2886  ok (non-closed singly connected)
    motorBike_fr-wh-brake-disk%35     1733     2656  multiply connected (shared edge)
    motorBike_fr-brake-caliper%36      571      723  ok (non-closed singly connected)
    motorBike_fr-wh-tyre%37     4683     5982  ok (non-closed singly connected)
      motorBike_hbars%38     2031     2574  ok (non-closed singly connected)
    motorBike_fr-forks%39     4343     5489  ok (non-closed singly connected)
      motorBike_chain%40     1794     2027  ok (non-closed singly connected)
    motorBike_rr-wh-tyre%41     4489     5869  ok (non-closed singly connected)
    motorBike_square-dial%42       20       32  ok (non-closed singly connected)
    motorBike_round-dial%43       45       67  ok (non-closed singly connected)
    motorBike_dial-holder%44      343      440  ok (non-closed singly connected)
    motorBike_rear-susp%45     7080     8046  ok (non-closed singly connected)
    motorBike_rear-brake-lights%46      202      274  ok (non-closed singly connected)
    motorBike_rear-light-bracket%47      627      755  ok (non-closed singly connected)
      motorBike_frame%48     7407     8584  ok (non-closed singly connected)
    motorBike_rear-mud-guard%49     2554     4717  ok (non-closed singly connected)
    motorBike_rear-susp-spring-damp%50      430      818  ok (non-closed singly connected)
    motorBike_fairing-inner-plate%51     1534     1912  ok (non-closed singly connected)
    motorBike_clutch-housing%52     3809     4181  ok (non-closed singly connected)
    motorBike_radiator%53      433      722  ok (non-closed singly connected)
    motorBike_water-pipe%54      324      401  ok (non-closed singly connected)
    motorBike_water-pump%55      270      341  ok (non-closed singly connected)
     motorBike_engine%56     8714     9374  ok (non-closed singly connected)
    motorBike_rear-shock-link%57      114      205  ok (non-closed singly connected)
    motorBike_rear-brake-fluid-pot-bracket%58      155      279  ok (non-closed singly connected)
    motorBike_rear-brake-fluid-pot%59      203      234  ok (non-closed singly connected)
    motorBike_footpeg%60      345      424  ok (non-closed singly connected)
    motorBike_rr-wh-chain-hub%61      464      815  ok (non-closed singly connected)
    motorBike_rear-brake-caliper%62      574      645  ok (non-closed singly connected)
    motorBike_rider-helmet%65     1550     1983  ok (non-closed singly connected)
    motorBike_rider-visor%66      313      478  ok (non-closed singly connected)
    motorBike_rider-boots%67     3574     4659  ok (non-closed singly connected)
    motorBike_rider-gloves%68     1209     1536  ok (non-closed singly connected)
    motorBike_rider-body%69    13561    17361  ok (non-closed singly connected)
    motorBike_frame:0%70      141      197  ok (non-closed singly connected)
    motorBike_frt-fairing:001-shadow%74    13558    34602  ok (non-closed singly connected)
    motorBike_windshield-shadow%75     1026     2775  ok (non-closed singly connected)
    motorBike_fr-mud-guard-shadow%81     2009     5088  ok (non-closed singly connected)
    motorBike_fr-wh-brake-disk-shadow%83      930     2193  multiply connected (shared edge)
    motorBike_rear-mud-guard-shadow%84     1629     4071  ok (non-closed singly connected)
    motorBike_rear-susp-spring-damp-shadow%85      277      698  ok (non-closed singly connected)
    motorBike_radiator-shadow%86      231      610  ok (non-closed singly connected)
    motorBike_rear-shock-link-shadow%87       55      157  ok (non-closed singly connected)
    motorBike_rear-brake-fluid-pot-bracket-shadow%88       99      241  ok (non-closed singly connected)
    motorBike_rr-wh-chain-hub-shadow%89      246      631  ok (non-closed singly connected)
  <<Writing 20 conflicting points to set nonManifoldPoints
Checking geometry...
    Overall domain bounding box (-5 -4 -4.84483e-07) (15 4 8)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (-3.4857e-16 -2.23773e-16 -1.04613e-15) OK.
    Max cell openness = 1.14968e-15 OK.
    Max aspect ratio = 38.6977 OK.
    Minimum face area = 4.88783e-08. Maximum face area = 0.261402.  Face area magnitudes OK.
    Min volume = 1.31325e-09. Max volume = 0.128081.  Total volume = 1279.68.  Cell volumes OK.
    Mesh non-orthogonality Max: 64.9936 average: 8.76543
    Non-orthogonality check OK.
    Face pyramids OK.
 ***Max skewness = 6.16279, 18 highly skew faces detected which may impair the quality of the results
  <<Writing 18 skew faces to set skewFaces
    Coupled point location match (average 0) OK.
Failed 1 mesh checks.
End
And wenn I'm going to import the controlDict into tecplot, I get the same error message as before.
I hope this is enough info to solve this problem.
best regards
CFDnewbie147 is offline   Reply With Quote
Old   August 22, 2013, 06:29
Retired Super Moderator
Bruno Santos
Hi CFDnewbie147,
OK, then the last thing that comes to mind is whether you have the compression option turned on in "system/controlDict".
Another way to check this is to check the contents of the folder "constant/polyMesh/" and see if the "points" and other files have the extension ".gz". If they do, then that might be the reason why Tecplot is not being able to see the files
Best regards,
Bruno
Old   August 23, 2013, 05:10
writeCompression uncompressed;
So, that's not the problem.
All the files in the constant/polyMesh directory don't have the extension ".gz". What else can be the problem?
It's strange, because other tutorials run completely and I can import them correct into Tecplot.
Thank u Bruno.
Old   August 24, 2013, 20:49
Bruno Santos
Hi CFDnewbie147,
Are you certain that you get the same exact error message as anfho indicated in post #17?
Because only a few possibilities come to mind:
  1. Perhaps it's because the boundary patches that have names that the FEA Loader is not prepared to handle, such as "motorBike_rr-wh-rim:005-shadow%17" - the ":" and "%" could be the problem.
  2. Perhaps the problem is that this tutorial case relies on "#include" for including data from other files, which is done for most file inside the "0" folder.
Best regards,
Bruno
Old   August 26, 2013, 02:28
Hello again,
I checked if the error message is the same as you said (post 17 from anfho), and it is exactly the same.
I will now look for the names of the files and check them.
I will get back here to post, to say, what's going on...
Thank u for your help,
CFDnewbie147
Old   August 27, 2013, 07:47
You are right. There are lots of : and % in the polyMesh- file. Perhaps this is the problem.
Nevertheless, now i've installed ParaView to analyse the motorBike- tutorial. Some other tutorials do work with tecplot, as i mentioned in a former post...
Thank's to you,
best regards
Old   January 13, 2014, 09:54
Default Velocity at wall not zero
  #27
Daniel_P is on a distinguished road
Hello everyone!
I recently started working with OpenFoam and encountered the same problem with Tecplot as Johan_87.
I ran the icoFoam tutorial "Cavity" and used the openFoam dataloader in Tecplot 360 2012R1 to visualize the results. When I probe the wall coordinates the velocities are not zero even though the no-slip condition is set at the boundary.
Using paraFoam for visualization, I get the correct values of zero at the wall. The solution data files also show zeros.
Does anyone have a solution to this problem? Is there a bug in the Tecplot loader?
I hope you can help me with this, I would be very glad to continue working with Tecplot for postprocessing...
Thank you in advance!
Daniel_P is offline   Reply With Quote
Old   January 13, 2014, 18:04
Bruno Santos
Greetings Daniel_P,
I vaguely remember that this has already been answered before somewhere on a thread about Tecplot and OpenFOAM... but right now I don't feel like searching for it.
The quick answer should be: you're looking at the data for the cell centers (aka Cell Data on ParaView). You need to look at the data from the cell vertexes (aka Point Data on ParaView). But I have no idea how Tecplot does this.
Best regards,
Bruno
Old   January 14, 2014, 11:12
Hej Bruno!
Thanks for your response.
I did some research here in the forum prior to my post but I could not find a solution to the problem...
I try to give some more explanations in the following:
When I look at the solution data file in an editor, I find the no-slip boundary condition on the wall, e.g. zero velocity. This is also the case for visualization in paraFoam.
When I use the OpenFoam data loader which is integrated in Tecplot, the visualization software loads all the patches including the one for the wall. Each patch is attributed to a Tecplot zone. Now I only activate the wall zone in the Zone Style menu, so all other zones are hidden. With point probe Tecplot gives me the correct coordinates but the velocity is not zero. Furthermore it says that the value given at the node is interpolated. This is correct since openFoam gives the values cell-centered and Tecplot interpolates the data on the cell nodes. However, the wall consists of faces and hence an openFoam value which is zero should be given for the center of each wall face, right?
If I use Spreadsheet in Tecplot, it also shows the non-zero values on the wall zone.
A colleague of mine checked his calculation results in Tecplot and he also observes the non-zero velocities. So the problem is not limited to my computer/set-up. He uses the same versions of OpenFoam (2.1) and Tecplot (Tec360 2012R1), though.
Thank you for any help!
Regards,
Daniel
Old   January 26, 2014, 14:48
Bruno Santos
Hi Daniel,
I think you better ask about this at the Tecplot forum: http://www.cfd-online.com/Forums/tecplot/ - I don't have access to Tecplot, so I don't have any idea where I should suggest that you should look at/for
Good luck! Best regards,
Bruno
Old   February 22, 2014, 03:19
Default Convert Tecplot Data to OpenFOAM ??
  #31
anonymous
ankit171032 is on a distinguished road
I want to convert .PLT type file of TECPLOT 360 into OpenFOAM format so as to directly open the file in OpenFOAM. Is it possible ?
I know the utility foamtotecplot360 to convert the OpenFOAM file to Tecplot but is the reverse possible ?
ankit171032 is offline   Reply With Quote
Old   February 22, 2014, 06:25
Bruno Santos
Greetings ankit171032,
Are you certain you want to export to an OpenFOAM file? Don't you instead want to open the data in ParaView, for comparing with data from OpenFOAM?
I ask this because it's possible to open Tecplot data in ParaView 4.1.0.
As for the utility "tecplot360ToFoam": it does not exist, or at least not publicly. It's theoretically possible, but probably not easy to code.
Best regards,
Bruno
Old   February 22, 2014, 06:34
Default Convert Tecplot Data to OpenFOAM format ??
  #33
anonymous
Yes Sir,Actually I have .plt type Tecplot format file and I want to do further analysis on the data.So,I need to open the file in OpenFOAM and hence looking for any utility for conversion of .plt file to OpenFOAM readable format.
I have tried to write data in Ascii format from tecplot360 and opening the same .dat file in paraview but it was not possible.Can we give input to the OpenFOAM from .dat file(obtained after writing data in ascii format using tecplot) ?or how to convert the .plt file into OpenFOAM format
Thanks & Regards
Old   May 20, 2014, 13:54
da14 is on a distinguished road
Hello
I am using OF 2.2.1 and installed tecplot 360 2013
In OF when i try to use the comand foamToTecplot360 i get the message: "command not found"
what i'm doing wrong?
Diogo
da14 is offline   Reply With Quote
Old   May 20, 2014, 14:26
After a research i found this explanation to how install foamToTecplot:
https://github.com/wyldckat/localFoa...ADME.mediawiki
Then when i execute Allwmake i receive the error message:
Did not find tecio in /home/diogo/OpenFOAM/ThirdParty-2.2.1. Not building foamToTecplot360.
Old   May 20, 2014, 18:55
Default OpenFOAM loader in Tecplot 360 2013-R1
  #36
Straton Spyropoulos
straton is on a distinguished road
Hello Diogo, we have an OpenFOAM loader in Tecplot 360 2013-R1.
1. Run Tecplot 360 2013-R1 > click on the File menu > Load Data File(s) > select OpenFOAM (FEA) > click OK
2. In the OpenFOAM dialog > click on the "..." button to open your controlDict file in your system folder > click the OK button
Thank you, Straton
Straton Spyropoulos
Senior Technical Support Specialist
Tecplot, Inc.
wyldckat and da14 like this.
straton is offline   Reply With Quote
Old   May 21, 2014, 12:47
Hi
Thank you, works perfectly
Diogo
Old   August 14, 2015, 01:20
Default symmTensor in tecplot
  #38
Albert Tong
tfuwa is on a distinguished road
Dear Forum,
I found today that tecplot omits symmTensor (for instance, volSymmTensorField) while loading openfoam data. Anybody knows a solution? It is much appreciated.
I am using Tecplot 360 2013R1 and OpenFOAM 2.1.1.
Editing: it seems to me Tecplot cannot load any variables with more than 3 components.
Kind regards,
Albert
tfuwa is offline   Reply With Quote
Old   August 14, 2015, 03:11
Dr. Fabian Schlegel
fs82 is on a distinguished road
To my opinion the native Tecplot loader is quite nice, but still has some problems, e.g., with boundary conditions and the interpolation of fields. Hopefully, Tecplot will fix this in future. Very nice is the feature to load parallel cases without reconstructPar. However, always if I am not sure if everything is displayed correctly or when I miss some functionality I use foamToTecplot360, which still works very good and is included in OpenFoam Repository. To install it just do:
cd $WM_THIRD_PARTY_DIR
wget "http://download.tecplot.com/tecio/2013/tecio2013.tar" -O tecio2013.tar
tar -xf tecio2013.tar
cd tecio
./Runmake
wmakeLnInclude tecsrc
cp $WM_THIRD_PARTY_DIR/tecio/libtecio.a $FOAM_EXT_LIBBIN
cd $WM_PROJECT_DIR/applications/utilities/postProcessing/dataConversion/foamToTecplot360
wmake
Best regards
Fabian
wyldckat likes this.
fs82 is offline   Reply With Quote
Old   August 14, 2015, 03:31
Albert Tong
Hi Fabian,
Thanks for your swift reply on this. Your method works like a charm.
I hope Tecplot Engineers can see my last message and include the functionality into Tecplot loader (if it is true that "Tecplot cannot load any variables with more than 3 components").
Thank you again.
cd tecio
./Runmake
wmake
Best regards
Fabian
Kind regards,
Albert
Reading Additional Data Quantities from Fluent into Tecplot fremder Tecplot 9 December 16, 2016 16:35
CFX-Post and Tecplot 360 Rogerio Fernandes Brito CFX 2 September 28, 2008 15:45
extracting data in tecplot peter FLUENT 0 September 24, 2008 12:11
tecplot 360 vs. 10 compatibility N.R. Tecplot 6 December 12, 2007 14:23
Exporting data to Tecplot 360 Genesis FLUENT 2 June 6, 2007 18:53
