August 23, 2011, 11:05 |
#21 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
OK, review the post #17 again, because I've updated once more the instructions. In bold are the new command instructions for the first part; in italic are the old instructions. This way, instead of having to download a heap load of megs, you only have less than 20kB to download! Best regards, Bruno
August 23, 2011, 11:33 |
hello sir
#22 |
sir error is arise it cant take wmset
~/OpenFOAM$ wmSET wmSET: command not found so problem cant solved sir plz tel me what m i do now? |
August 23, 2011, 11:39 |
#23 |
Bruno Santos
Rep Power: 128 |
OK, then do the commands again with 2.0.0 instead of 2.0.1.
wmSET should exist... if not, use: Code:
source /opt/openfoam200/etc/bashrc
August 23, 2011, 11:55 |
hello sir
#24 |
actually sir all the process going smoothly but at last when i entered the command ./allwmake then this type of error arise
~/OpenFOAM/jigsmoksh-2.0.0/foamToTecplot360$ ./Allwmake Making dependency list for source file tecplotWriter.C could not open file TECIO.h for source file tecplotWriter.C could not open file MASTER.h for source file tecplotWriter.C could not open file GLOBAL.h for source file tecplotWriter.C Making dependency list for source file vtkMesh.C Making dependency list for source file foamToTecplot360.C could not open file TECIO.h for source file foamToTecplot360.C could not open file MASTER.h for source file foamToTecplot360.C could not open file GLOBAL.h for source file foamToTecplot360.C SOURCE=tecplotWriter.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/home/jigsmoksh/OpenFOAM/ThirdParty-2.0.0/tecio/tecsrc/lnInclude -I/opt/openfoam200/src/lagrangian/basic/lnInclude -I/opt/openfoam200/src/finiteVolume/lnInclude -I/opt/openfoam200/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam200/src/OpenFOAM/lnInclude -I/opt/openfoam200/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/tecplotWriter.o In file included from tecplotWriter.C:26:0: tecplotWriter.H:39:19: fatal error: TECIO.h: No such file or directory compilation terminated. make: *** [Make/linuxGccDPOpt/tecplotWriter.o] Error 1 |
August 23, 2011, 11:57 |
#25 |
Bruno Santos
Rep Power: 128 |
What does this output:
ls -l /home/jigsmoksh/OpenFOAM/ThirdParty-2.0.0/tecio/
August 23, 2011, 12:01 |
#26 |
output is
total 48 drwxr-xr-x 14 jigsmoksh jigsmoksh 4096 2011-06-21 11:39 examples -r--r--r-- 1 jigsmoksh jigsmoksh 20726 2009-11-25 12:42 pltview.cpp -r--r--r-- 1 jigsmoksh jigsmoksh 2020 2009-11-25 12:42 readme.txt -rw-r--r-- 1 jigsmoksh jigsmoksh 9041 2009-11-25 12:42 Runmake drwxr-xr-x 2 jigsmoksh jigsmoksh 4096 2011-06-21 11:48 tecsrc |
August 23, 2011, 12:08 |
#27 |
sir
what can i do? how can i solved problem? Bruno sir plz help me to solve this problem. |
August 23, 2011, 12:50 |
#28 |
Bruno Santos
Rep Power: 128 |
Sorry, was busy here at work...
See the second part again on post #17... I forgot that Allwmake did have to be executed there.
August 23, 2011, 13:41 |
hello brunosir,
#29 |
2nd part done accurately but at third part when we entered last command that time i saw list of the statement like
jigsmoksh@ubuntu:~/OpenFOAM/jigsmoksh-2.0.0/foamToTecplot360$ ./Allwmake Making dependency list for source file tecplotWriter.C could not open file C__BASE.h for source file tecplotWriter.C Making dependency list for source file vtkMesh.C Making dependency list for source file foamToTecplot360.C could not open file C__BASE.h for source file foamToTecplot360.C SOURCE=tecplotWriter.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/home/jigsmoksh/OpenFOAM/ThirdParty-2.0.0/tecio/tecsrc/lnInclude -I/opt/openfoam200/src/lagrangian/basic/lnInclude -I/opt/openfoam200/src/finiteVolume/lnInclude -I/opt/openfoam200/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam200/src/OpenFOAM/lnInclude -I/opt/openfoam200/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/tecplotWriter.o In file included from tecplotWriterTemplates.C:29:0, from tecplotWriter.H:170, from tecplotWriter.C:26: /home/jigsmoksh/OpenFOAM/ThirdParty-2.0.0/tecio/tecsrc/lnInclude/GLOBAL.h:5038:46: warning: use of old-style cast /home/jigsmoksh/OpenFOAM/ThirdParty-2.0.0/tecio/tecsrc/lnInclude/GLOBAL.h:5057:41: warning: use of old-style cast /home/jigsmoksh/OpenFOAM/ThirdParty-2.0.0/tecio/tecsrc/lnInclude/GLOBAL.h:5071:47: warning: use of old-style cast /home/jigsmoksh/OpenFOAM/ThirdParty-2.0.0/tecio/tecsrc/lnInclude/GLOBAL.h:5085:47: warning: use of old-style cast SOURCE=vtkMesh.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/home/jigsmoksh/OpenFOAM/ThirdParty-2.0.0/tecio/tecsrc/lnInclude -I/opt/openfoam200/src/lagrangian/basic/lnInclude -I/opt/openfoam200/src/finiteVolume/lnInclude -I/opt/openfoam200/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam200/src/OpenFOAM/lnInclude -I/opt/openfoam200/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/vtkMesh.o SOURCE=foamToTecplot360.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/home/jigsmoksh/OpenFOAM/ThirdParty-2.0.0/tecio/tecsrc/lnInclude -I/opt/openfoam200/src/lagrangian/basic/lnInclude -I/opt/openfoam200/src/finiteVolume/lnInclude -I/opt/openfoam200/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam200/src/OpenFOAM/lnInclude -I/opt/openfoam200/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/foamToTecplot360.o In file included from tecplotWriterTemplates.C:29:0, from tecplotWriter.H:170, from foamToTecplot360.C:87: /home/jigsmoksh/OpenFOAM/ThirdParty-2.0.0/tecio/tecsrc/lnInclude/GLOBAL.h:5038:46: warning: use of old-style cast /home/jigsmoksh/OpenFOAM/ThirdParty-2.0.0/tecio/tecsrc/lnInclude/GLOBAL.h:5057:41: warning: use of old-style cast /home/jigsmoksh/OpenFOAM/ThirdParty-2.0.0/tecio/tecsrc/lnInclude/GLOBAL.h:5071:47: warning: use of old-style cast /home/jigsmoksh/OpenFOAM/ThirdParty-2.0.0/tecio/tecsrc/lnInclude/GLOBAL.h:5085:47: warning: use of old-style cast g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/home/jigsmoksh/OpenFOAM/ThirdParty-2.0.0/tecio/tecsrc/lnInclude -I/opt/openfoam200/src/lagrangian/basic/lnInclude -I/opt/openfoam200/src/finiteVolume/lnInclude -I/opt/openfoam200/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam200/src/OpenFOAM/lnInclude -I/opt/openfoam200/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed Make/linuxGccDPOpt/tecplotWriter.o Make/linuxGccDPOpt/vtkMesh.o Make/linuxGccDPOpt/foamToTecplot360.o -L/opt/openfoam200/platforms/linuxGccDPOpt/lib \ -llagrangian -lfiniteVolume -lgenericPatchFields -lmeshTools -L/home/jigsmoksh/OpenFOAM/ThirdParty-2.0.0/platforms/linuxGccDPOpt/lib -ltecio -lOpenFOAM -ldl -lm -o /home/jigsmoksh/OpenFOAM/jigsmoksh-2.0.0/platforms/linuxGccDPOpt/bin/foamToTecplot360 jigsmoksh@ubuntu:~/OpenFOAM/jigsmoksh-2.0.0/foamToTecplot360$ |
August 23, 2011, 13:55 |
hello bruno sir,
#30 |
thank you very much sir to give me ur valuable time & i m very happy because foamToTecplot360 is now run
Thanx again sir, if further query arise then definitely i will contact u because u r the encyclopedia of openfoam thanx again sir Yours sincerely Jignesh |
August 23, 2011, 16:32 |
#31 |
Bruno Santos
Rep Power: 128 |
Hi Jignesh,
I'm glad it's finally working! As for OpenFOAM, I'm very skilled in compiling/building it... but I'm still very inexperienced when it comes to the real CFD part of OpenFOAM I haven't had the time/opportunity to actually do real CFD with it... oh well, I can't know everything Best regards, Bruno
August 24, 2011, 03:43 |
hello bruno sir,
#32 |
sir i have find some problem when i run paraview
when i entered on case file like cavity.openfoam then 1 outbox msg generated the msg is p, li { white-space: pre-wrap; } Application asked to unregister timer 0x71000008 which is not registered in this thread. Fix application. so how to solve it? |
August 24, 2011, 04:15 |
hello every one
#33 |
plz solve my problem sir
sir i have find some problem when i run paraview when i entered on case file like cavity.openfoam then 1 outbox msg generated the msg is Application asked to unregister timer 0x71000008 which is not registered in this thread. Fix application. so how to solve it? Last edited by jignesh_thaker2007; August 24, 2011 at 14:47. |
August 24, 2011, 05:20 |
hiiiiiiii everyone
#34 |
plz anybody have any solution of above problem then plz tel me what can i do?
September 11, 2011, 04:25 |
hello everyone
#35 |
hi
i m new user of openfoam201 i phase one difficulty when i solved cavity tutorials then i cant found such like fluent after achieving conversion limit, the program didn't stop. but when it reach end time it stop. but i want to stop my program when it go beyond the conversion limit so what can i do for that? plz help me jignesh |
November 1, 2011, 18:44 |
#36 |
Scott Rumage
Rep Power: 17 |
Tecplot 360 2011 with the OpenFOAM © data loader is now officially released. The loader directly reads OpenFOAM results, and eliminates the step of converting OpenFOAM output to a Tecplot format.
One can upgrade their current license of Tecplot 360 to this new version at this link: http://www.tecplot.com/Downloads/SoftwareUpgrade.aspx One can obtain a 14 day evaluation of this new version of Tecplot 360 at this link: http://www.tecplot.com/Downloads/EvaluationSoftware/Tecplot360.aspx You are welcome to contact me if you have questions or suggestions regarding this new capability. Regards, Scott |
November 2, 2011, 06:34 |
#37 |
R. P.
Rep Power: 16 |
Hi Scott,
Thanks for this. I will upgrade my Tecplot and test it without convert my data. Cheers, Rodrigo |
November 22, 2011, 04:12 |
#38 | |
Peter
Rep Power: 15 |
I guess "wget "https://github.com/OpenCFD/ThirdParty-2.0.x/tarball/master" -O ThirdParty-2.0.x.tar.gz" should be "wget "https://github.com/OpenCFD/OpenFOAM-2.0.x/tarball/master" -O ThirdParty-2.0.x.tar.gz"
November 22, 2011, 04:27 |
#39 |
Peter
Rep Power: 15 |
Hi, Bruno.
I am following your instructions. But when I execute "./getTecIO", it says:"Can't open etc/tools/ThirdPartyFunctions". And then, when I execute "./Allwmake", it says:" ./Allwmake: No such file or directory". What am I gonna do? Last edited by palmerlee; November 22, 2011 at 05:20. |
November 22, 2011, 15:37 |
#40 |
Bruno Santos
Rep Power: 128 |
Greetings Peter and welcome to the forum!
OpenCFD was bought by SGI back in mid August or so. By day 23 of August, when I wrote that post, they had yet to transfer the ThirdParty-2.0.x repository. So, right now, instead of changing ThirdParty to OpenFOAM, it's OpenCFD to OpenFOAM Code:
wget "https://github.com/OpenFOAM/ThirdParty-2.0.x/tarball/master" -O ThirdParty-2.0.x.tar.gz By the way, have you tried the new version of Tecplot 360? A few posts above they mention that it can now open OpenFOAM cases directly! Best regards, Bruno
